Old 07-25-2008, 05:44 PM
FSJeep13's Avatar
FSJeep13 FSJeep13 is offline
How to replace rear main seal?
Hey, I'm pretty sure my rear main is bad. I leak oil like there is no tomorrow at times especially now that the summer heat is beating on us. I brought the jeep in to get the oil changed and as I watched the oil puddle accumulate I wondered why I was even there...
I read the tech article here, but my question is, Do I have to take out the engine to replace the seal? or maybe transmission and Tcase? The "friends" I have at the jeep dealership told me it would be more worthwile to not fix the leak and just buy a new engine for what it will cost me. Sounds like a load of carp to me. So, can I just get under there and replace the thing? Thanks guys. Any pics would help too.
Johnny
2000 TJ I6, Borla header, 3.5" lift, 33x12.50 BFG ATs
1978 Wagoneer, 401. 2"BL, 7" SOA, chrome steel wheels/ 33x12.50 BFG ATs, and tachometer hopefully done soon.
Old 07-25-2008, 05:56 PM
crazydog's Avatar
crazydog crazydog is offline
You do not need to pull the engine or buy a reman to fix the leak. Just follow the instructions and you can change the seal with the engine in the Jeep.
1967 J3500 - Making plans
Old 07-25-2008, 06:00 PM
AlsChopShop's Avatar
they are blowing air up your skirt.
pull the oil pan, remove the rear main bearing cap, pull the old seal out, push the new one in, reinstall bearing cap, reinstall oil pan.
Al
Old 07-25-2008, 06:21 PM
FSJeep13's Avatar
dmnit! I knew I shouldn't have worn that in there.
I checked at the back of the valve covers to see if there were leaks there. I forgot to check at the heads. I found a red oily fluid on the back of the intake. Must be ATF. I know the filler is back there... I do leak enough of ATF as well. hopefully that is just another gasket or seal.
Johnny
Old 07-25-2008, 06:33 PM
bushwood44's Avatar
bushwood44 bushwood44 is offline
hopefully its the trans pan gasket instead of trans pump seal(probably both)
88 Grand Wagoneer
99 Camaro z28
73 Honda st 90
79 F250
Old 07-25-2008, 07:03 PM
superal30's Avatar
superal30 superal30 is offline
The rear seal change is a cake walk, if your half way mechanically friendly. On mine I just jacked the jeep up by the frame (lets the axle droop away from the engine for more room). Pulled the pan and rear main, changed seal retorqed and reassemble. The most challenging part of the whole thing is putting the pan and pan gasket back up. That's always easier when the engines out, unless you're in a gravity free zone . Good luck you'll do fine.
I'll take one 1976 wagoneer...Oh and hold the rust, please!!
Old 07-25-2008, 07:33 PM
intenseimages intenseimages is offline
these guys are halfway right on how easy it isnt. lol
here is the way it usually happens:
go to store buy parts,
stop at next store pick up drinks of choice
go home, drain oil
drop pan
drop rear main bearing cap
next step is to spend 3 days dropping crap on your face while trying to get the frozen in place rear main seasl out of engine.
once it is finally out though it is a matter of rolling new seal in and bolting it all back up (please remember te re-install drain plug) and filling wiht oil
eric
It's a long way to the top, if you wanna rock and roll.
Old 07-25-2008, 08:01 PM
FSJeep13's Avatar
sweet. I'm excited. I thought this was going to be a real downer! People were telling me, "yeah you better just rebuild the whole engine while you have it out to do the rear main..." blah blah blah. thanks guys
Johnny
Old 07-25-2008, 08:24 PM
srobertsfsj's Avatar
srobertsfsj srobertsfsj is offline
Shimniok and I did the one on my J20 a couple years back and it wasnt that hard. A couple of tips he gave me were to remove the rear bearing cap and loosen the next bearing cap. I also bought some soft brass rod and used it to drive out the old seal. The soft brass shouldn't score the block. And make sure you tighten the bearing caps down to the correct torque.
Scott R.
'86 Grand Wagoneer Super Chief 360 / TBI / WT conversion / 35x12.5x16 BFG Mud-Terrains (Project Link)
Old 07-26-2008, 04:46 AM
caionneach's Avatar
caionneach caionneach is offline
to make it easier...
Can't believe the guys aren't telling you this:
To make it easier to get the top half of the seal out, you need to drop the crank, otherwise it can be a PITA.
To do that not only do you need to follow the manual and loose the bolts on all the main journals, but you also need to LOOSEN THE BELTS ON THE FRONT OF THE ENGINE.
The belts maintain upward pressure on the crankshaft, and loosening the belts makes it all easy.
1982 Cherokee
258 cid/T-5 $15 Sunpro Voltmeter gauge
replacement; Quadratec Trailmax Thermal Pro
Seats! 4 inch SKYJACKER suspension lift, 33X12.5 in
BFG Mud Terrain Tires on 15X10 in ProComp Rims.
New BJ's chrome-moly rear axle shafts, 3.73:1 diffs and ARB Air Locker!
Old 07-26-2008, 05:51 AM
JERSEY JOE's Avatar
REAR MAIN SEAL REPLACEMENT
Also you can back off the main cap screws to drop the crank a few thousands. Also the most important thing is to make sure the rear main cap is clean and put silicone sealer in the chamfer between the cap and the block. If you do not do tis you will be doing the job twice.
READ THE INSTRUCTIONS IN THE JEEP SERVICE MANUAL AND FOLLOW THEM TO A TEE. SOMEONE HERE CAN POST THE PAGE FOR YOU.
It is easier with the motor out or if you leaving it in beg borrow whatever, get access to a lift. Doing this job on your back is more of an adventure than you want especially for a novice.
1987 J-20 401 90% COMPLETED.
1970 AMX CURRENT PROJECT
Old 07-26-2008, 07:04 AM
Gil's Avatar
Gil Gil is offline
I did the rear main seal...took 5 hours and it still leaks. My mechanic would have done it for $185...would have been worth it. But, I learned a lot -- like I have no business under a Jeep!!
Hey, if your Jeep place can replace an engine for $185, go for it
Gil
1980 Cherokee Chief
Old 07-26-2008, 07:16 AM
caionneach's Avatar
Ditto what Jersey Joe said
Following the instructions assiduously (also known as "to a tee") is very important.
--the rear main journal area must be clean (use brake cleaner as needed, so have several cans ready)
--if the rear main area isn't clean the RTV on the areas as specified (joints of the upper and bottom seal, chamferred areas on the rear main cap) will not make a good seal.
But other than that it's easy. If it looks clean, assume it's not and use brake cleaner to make sure.
1982 Cherokee
Old 07-27-2008, 07:38 PM
Sbonley Sbonley is offline
Also make sure it is not the oil galley seal at the back of the block. Those are notorious for leaking and it looks like a rear main seal leak because of its location.
\'79 Cherokee Golden Eagle<br />Mostly Stock (for the moment)
Old 07-27-2008, 10:26 PM
4x4fEvEr's Avatar
4x4fEvEr 4x4fEvEr is offline
what? you guys are making it sound hard! its not. your mechanic friends saying rebuild or get a new engine must think it has a one piece rear main seal and in that case you would need to pull the tranny or pull the engine, but AMC's are two piece seals so like most have said just drop the pan take off the main cap and loosen the next one. pull off the bottom part of main seal and then use a punch or something similar to start the top half of seal . then do the reverse for putting it back on. make sure u get the lip on the seal facing the correct direction and be sure to torque all bolts back to specs. the biggest pain is getting the pan back on for sure.
Old 07-28-2008, 07:14 AM
CROCKETTBOONE's Avatar
CROCKETTBOONE CROCKETTBOONE is offline
My only suggestion it to let the oil drain overnight or longer. Nothing worse than oil dripping on your face.
An opinion is just that, an opinion. A fact is a fact, and thought to be true. Please dont confuse an opinion with a fact. Life: Its sexually transmitted and always Fatal.
Old 07-28-2008, 08:13 AM
FSJ Guy FSJ Guy is offline
Also, depending on our Y pipe configuration, plan on dropping the Y pipe in order to remove the oil pan AND access the rear seal. If they haven't been off recently, the manifold studs and nuts will be frozen together. PB blaster those suckers for a good week before you start. Otherwise, you'll be removing your manifolds to take them into the machine shop to have broken studs removed. AMHIK.
Watch your seal orientation and lube the seal with fresh oil when you install it SLOWLY.
Have fun!
Ethan Brady
www.bigscaryjeep.com
Old 07-28-2008, 08:46 AM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
And bring LOTS of rags/cleaning supplies to the show! You'll spend more time cleaning before you put it back together than you did fixing it!
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 07-28-2008, 09:10 AM
Driftwood's Avatar
"READ THE INSTRUCTIONS IN THE JEEP SERVICE MANUAL AND FOLLOW THEM TO A TEE. SOMEONE HERE CAN POST THE PAGE FOR YOU."
Soooooooooooo, can someone please post the Service Manual Instructions. That way we can all be in the know!
Old 07-28-2008, 11:54 AM
Casey's Avatar
Casey Casey is offline
Jeep Polygamist
Yeah...what he said. The pan removal and installation is the hard part.
DO NOT use a steel drift to drive out the upper part of the seal. Even if that's all you have on hand. Plastic or brass ONLY. If you knick the crank it will leak at the RMS forever.
1994 YJ
1986 Comanche
'57 FC-150
Carolina Full Size Jeep Club
www.cfsjc.com
www.patriotguard.org
"Go forth and be a tool".
