Old 05-17-2008, 09:55 AM
ThisGuyUKnow's Avatar
How far can you get?
I ran across a old Chero advert a while back. It said that the vehicle get 15 mpg. I have been trying to relocate the image on the google machine but can't. Anyhow i calculated out the fuel economy on my rig and it gets 8.5 mpg woot woot. Thats with stock gearing and 33" all terrains. I am curious to know what everyone else gets.
Oh and if anyone has seen the same advert please attach it
Old 05-17-2008, 10:10 AM
dngrs1's Avatar
dngrs1 dngrs1 is offline
Well, as my J10 gets about 11-12mpg, 34 gal. tank (which I don't fill up cause it seems to run out the filler hose, 30 gal., say), I can safely go 300-340mi.
'77 J-10 '79 CJ-7
Arizona-The Rust Stops Here
Old 05-17-2008, 10:19 AM
DieselSJ DieselSJ is offline
Stock 20 gal tank and I usually fill up between 320-340 miles.
Mark
87 Grand, 6.5L diesel, MHI TE06H turbo, Detroit Diesel single plane intake, Art Carr 700R4, CS-130, hydroboost. 21/24mpg and an almost dead 229 (*&^%$# viscous) [208 on the way]
81 CJ5, Bowtie 350, T176, 30, 20, 300, small lift, 285/75/16 MTRs courtesy of Goodyear.
Old 05-17-2008, 12:06 PM
JeepinPete's Avatar
JeepinPete JeepinPete is offline
With my 42g Suburban tank, I can get around 625 miles out of a tank...
Pete
Isuzu 6BD1, NV4500, NP241
Old 05-17-2008, 06:54 PM
Bama Burden's Avatar
Bama Burden Bama Burden is offline
Old 05-17-2008, 08:38 PM
stumpjumper3's Avatar
stumpjumper3 stumpjumper3 is offline
Originally Posted by Bama Burden
X2.lol
1978 Cherokee, 4 in and 33s
Old 05-18-2008, 09:35 AM
flatbackdragon's Avatar
flatbackdragon flatbackdragon is offline
well, ahhh
"In Finland Wagoneers (starting from late 70's) were usually sold with a Valmet 411 Diesel engine (4.4 Litres Max. power 82hp DIN/rpm 2200, Torque 306Nm DIN/rpm 1460). Typical mileage with this engine was around 29 MPG (8.2L/100Km) and if a turbo was installed by the owner, mileage improved even more (8L/100Km)."
"There's an inner idiot in us just waiting to climb out and romp about in unabashed stupidity, but most people retain just enough wit to keep the idiot bottled up."
Gary Harmon-writer for Grand Junction Daily Sentinel (newspaper)
Phil (or Flip, Dragon)
Draco-79 Cherokee 360/QT-4" lift-pretty much stock and trying to fall apart
Old 05-18-2008, 09:46 AM
bigwoody's Avatar
bigwoody bigwoody is offline
I can squeeze 200 miles out of mine if conditions are right and i keep my foot out of the 4 barrel.
I get on the nineish side of ten usually. Even if I would drive with economy in mind I don't think I would get to 11 mpg
HI MY NAME IS AL AND I'M A JEEPOHOLIC
83,87,88 GW..79 J10
Old 05-18-2008, 09:57 AM
Serious Johnson's Avatar
20-gallon Blazer tank -- not wise to use more than 18 of them if it's hilly. Last fill-up was at 298 miles -- 17.1 gallons.
S.J.
"Carpe Mañana".
'83 Wagoneer
Old 05-18-2008, 10:12 AM
Casey's Avatar
Casey Casey is offline
Jeep Polygamist
S.J.
That's 17.4mpg!!!
I didn't think that was even remotely possible! I guess the work to install the TBI has paid off in spades.
The best I ever got out of any of the dozen or more V8 SJs I've owned was 14mpg. Typically 11mpg. The best for a 258 was 17.5.
1994 YJ
1986 Comanche
'57 FC-150
Carolina Full Size Jeep Club
www.cfsjc.com
www.patriotguard.org
"Go forth and be a tool".
Old 05-18-2008, 10:21 AM
Towtruck's Avatar
Towtruck Towtruck is offline
I just got back from towing a 4500 pound car/trailer combo from DFW to Houston. Got 9 mpg on the trip down @65-70, and 13+ mpg on the return (no trailer) at a steady 75 mph. Not bad. Truck has 3.31 gears, 30 inch tires, and the 360 has an HEI and the Edlebrock "combo"...RV cam, 600 cfm, Performer intake. Bet it would have done 14-15 if I'd slowed down. Lots of stops because of small tank, in fact I carried a spare jug of fuel just in case.
By the way, it ran cool (no shroud/stock radiator) @ 80 degrees OAT, and it handled well...stock short bed suspension. No equalizer, no antisway on hitch.
___________________________
J10 - Body channel (3 inch drop @ front); dechromed; shaved side parking lights, antenna, and hood trim bar. Ford mirrors, roll pans, side exhaust, 16 inch wheels, custom dash, new interior, Edelbrocked 360, HEI, T18/208 (J20), rear disk brakes, fifth wheel and bumper hitches.
Old 05-18-2008, 12:59 PM
Originally Posted by Casey
That's 17.4mpg!!!
Actually, the ol' gal's not running quite right just now -- I've gotten a good bit better. Remember, altitude makes a pretty big difference, and EFI automatically adjusts. Back in S.C. I was getting 13-15.
Fellow I met recently who twiddles wrenches at the local 4x4 shop says that he could usually crack 20 MPG with a 360 Wagoneer with little more than a Holley 500 two-barrel and advanced timing. But the thing would barely run down in Denver.
S.J.
"Carpe Mañana".
'83 Wagoneer
Old 05-18-2008, 01:43 PM
nicsfsj's Avatar
nicsfsj nicsfsj is offline
Well running down I-26 and to my office I get about 12mpg. I did take a trip to Savanah about a month ago and got 16mpg on the highway. Some of that was in town but not much!
90 Waggy Auto Stock
NJ
Old 05-19-2008, 01:14 PM
scotty1998's Avatar
scotty1998 scotty1998 is offline
I'd still like to know how people are getting over 14 mpg on a v8 Wag
It would be great to modify this thread and tell us whether you're running stock or have modified ignition, timing, carb etc.
I can get 14.5 on an open highway using cruise the whole way from gas station to gas station. No better.
I usually average 10 - 10.5 around our hilly town. No better, no worse. Doesn't matter if I feather the pedal or stomp on it. Soooo what's that in terms of "how far can I get?" Roughly 240 miles on a tank on open highway and 170 around town if I'm lucky
Old 05-19-2008, 04:03 PM
AlsChopShop's Avatar
One-man wolf pack
with my 360 i ALWAYS got 10mpg around town, and 10mpg on the freeway. ouch.
Al
81 Toyota longbed - SOLD
91 Chevy K1500 - Over 300k!
90 XJ - 4.0/AW4/NP242, 5.5" lift, bushwhacker cutouts, sliders, bumpers, winch, 33's - FOR SALE -
08 Mazda CX-9, 273 hp - SOLD
07 Mazdaspeed3 - 263hp, 280ft/lbs tq - Zoom zoom!
Old 05-19-2008, 04:53 PM
86Wag's Avatar
86Wag 86Wag is offline
Driving my '87 home from Ohio I got about 12-13 on a bad carb (needs to be rebuilt) and badly in need of a tune up. Now I tool around town with it occasionally (only fixed the carb) and still get around 12. My '86 pulled 14-15MPG coming back from NYC, and mechanically that thing was in pretty bad shape.
Had an '82 quadratrack and I would only get maybe 10 around town. That was my first car; got me addicted to these things
Andy
Live free or die
Old 05-19-2008, 06:50 PM
nicsfsj's Avatar
Scotty,
I am runnin a 90 Waggy "SCHWEETY" as the kids named her. Stock 360, stock everything even the Jeep Logo foglamp covers with get ready wait for it, wait for it, wait: 231,000 miles. I dont use cruise, I drive like I have sense and take it easy. I am however tryin an experiment this week. I have a buddy and he is a huge tree hugger and constantly rides my tail about the WAGGY and the crap gas mileage she gets. He sent me a link on this "hypermiling" crap and Im trying it as we speak. Hee Hee, tryin to Hypermile a 90 Waggy. I should get a free IFSJA tee shirt just for trying it. I mean hell this battle tank runnin in neutral with the engine shut off and no power breaks, reminds me of the beater $100 F100 POS truck I had in high school. Now dont get all wiggy, Im not doing it light to light with that Hypermiling crap just in parking lots hee hee. I do turn it off if Im gonna be sitting at some of the long Charleston sit and wait stop lights or crap traffic conditions. Just tryn to squeeze any and every drop out of the tank baby!!! I will advise on the results from this week. However in theory, I bet I get 1 MPG better and a crap load of work for that! But Im startin a new revolution "Hypermiling Waggys Baby" hee hee.
NJ in SC
Old 05-19-2008, 08:02 PM
Gambler68's Avatar
Rabble Rouser
with 33x12.50 MTs, 3.54 gears, Th400/QT, Holley Street Dominator intake ,Edel 600 offroad carb, dual exhaust, and a KN filter I get 10mpg. I also run the diesel oil in..too tired to remember the name of the crap.
ehh its all about the smiles per gallon, not miles per gallon.
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 05-19-2008, 08:39 PM
Every Q-trac I've owned that was complete, averaged 10.5 at ALL times. The j-10 I dd is QT, but I dont have the front shaft in and get about 11.5. Thats flat land and stop sign to stop sign. Need to do some tuning on the rest befor I can brag on them...
Old 05-20-2008, 05:14 AM
Lordsburg, NM to Tucson, AZ
156 miles, 12.5 gallons
Like SJ I can run the Blazer tank to about 18, but with no gauge I don't really try to do this.
A little over 12mpg, 4.10's-34.5's-Welded 14-Bolt.
Used to be about 14mpg, 3.54's-33's-Open D44.
Could be worse.
