Old 04-20-2008, 10:01 PM
Dr Teeth Dr Teeth is offline
Is this spring doing anything?
So the truck had a lift when I bought it. Rancho, I'm guessing about 4" (all spring in the front and 2" spring/2" block in the back).
The question is about the extra spring in the rear pack... To me it looks like an Add-a-Leaf installed upside down. Does anyone think this spring is actually doing anything other than acting as another 1/2" block in the back?
The truck has a bit more of a rake to it than I'd like currently and so unless someone can tell me these springs have some benefit, they will go on the list of things to be removed.
Thanks,
Todd
Old 04-20-2008, 10:07 PM
Gambler68's Avatar
Rabble Rouser
I'd guess the PO was one beer short of an empty case at the point where that decision was made
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
srobertsfsj's Avatar
srobertsfsj srobertsfsj is offline
Its just an overload spring but it looks like its upside down to me.
Scott R.
'86 Wagoneer "Honey Badger" 360 / TBI / WT conversion / TT's Fabworks Shackle Flip and SOA / 35x12.5x16 BFG Mud-Terrains (Project Link)
'78 Cherokee Chief 360 / SOA / 35's (Son's Jeep)
Old 04-20-2008, 10:35 PM
hardbody1's Avatar
hardbody1 hardbody1 is offline
Its an overload spring that has probably been bent from overloading assuming they werent just dumb and installed it upside down.
Kyle
1982 Cherokee Laredo WT 360/727/208 SOA and Shackle flip 4.88 gears spooled rear lockrite front and 36in. sxs Rolled and still going!
Old 04-20-2008, 10:39 PM
FSJeep13's Avatar
FSJeep13 FSJeep13 is offline
looks like he barely got those nuts back onto the u-bolts too....
Johnny
2000 TJ I6, Borla header, 3.5" lift, 33x12.50 BFG ATs
1978 Wagoneer, 401. 2"BL, 7" SOA, chrome steel wheels/ 33x12.50 BFG ATs, and tachometer hopefully done soon.
Old 04-20-2008, 11:41 PM
shackwrrr's Avatar
seems right to me except the u bolts. I looked at a 2007 tacoma that the school has it is brand spankin new and the overloads look just like that. It doesent seem right to me but thats how it is. Me in my opinion i would turn it over. but I have a j20 and use it like a j20
Jeepless
In to Turbo crap now
Old 04-20-2008, 11:45 PM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
They look upside down to me... I personally have never seen any reversed arched overload springs before..
A major benefit when you get it off is that you will be able to get a resonable amount of threads on those U bolts..
Old 04-21-2008, 04:57 AM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Overload spring that's upside down. To answer your question, no, it's not doing anything.
I'd pull apart the spring pack, turn the leaf right side up and if you don't like the rake, then pull that bottom block out. That should drop it a couple of inches.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 04-21-2008, 07:05 AM
flatbackdragon's Avatar
flatbackdragon flatbackdragon is offline
don't know about the overload or add a leaf springs but the ones on the back of my wife's Toyota Taco look like that, factory.
The nuts look as if they the have threads all the way through (the front ones at least) you don't have to have lots of excess hanging through the bolt unless you want to double nut them.
"There's an inner idiot in us just waiting to climb out and romp about in unabashed stupidity, but most people retain just enough wit to keep the idiot bottled up."
Gary Harmon-writer for Grand Junction Daily Sentinel (newspaper)
Phil (or Flip, Dragon)
Draco-79 Cherokee 360/QT-4" lift-pretty much stock and trying to fall apart
Old 04-21-2008, 08:34 AM
Billygoat's Avatar
Most overloads are flat, but it is possible it is suppose to be that way.
Best guess is the ride was too rough, so he flipped the bottom over to reduce the rate of the pack, but keeped it for a "spacer". Or was trying for more lift with the same rate and installed that one. removing it should only lower that end the thickness of the spring since it has no weight on it.
"Thumper" - 1981 J-20 Extended Cab/sportside, HB, Muscle Grill/round lights, Audiovox Cruise Ctrl, XCR-8000 winch/stk bumper
Extended Cab Build thread {click}
401-4L80E-242 conversion {click}
"Gonzo" - 1983 Cherokee WT 360/727/229 - DYI TBI w/TFI dizzy, HB, 3" SR/SF lift, Muscle Grill/round headlights
Build Thread {click}
Old 04-21-2008, 09:04 AM
There's full thread engagement in the nuts (even though it is tough to see in the picture).
Someone thought that it was bent from overload... I can't see that being it as both sides are the same and I can't imagine the load it would take to do that without breaking alot of other stuff too.
I think they were just added for a bit more lift in the back... so, I'll put them on the list of things to remove.
Always nice to have a few more sets of eyes look at things to make sure I didn't miss something. Thanks to everyone who replied.
Todd
Old 04-21-2008, 09:11 PM
Chris Barry's Avatar
Chris Barry Chris Barry is offline
Yeah, it's an overload spring, and it is installed correctly. It is designed for extreme overload. Very little to no give in it. . .mostly just to keep your springs from flexing so much that they blow out your shocks.
'85 Grand Waggy 360/727/NP229 33X12.5R15 2inch susp lift with 2inch body lift.(wife's DD)
'86 Grand Waggy all stock with custom sagging springs
'85 Baby Cherokee 2.5L(my new DD)
'89 Chevy K2500 flatbed
'87 Ford Ranger
'84 Renault LeCar
'84 Honda Passport
'66 Yamaha MG-1T
http://www.jpricefamily.org/joy/Chris-Cars.htm
Old 04-21-2008, 11:07 PM
hardbody1's Avatar
I said that because thats what my little nissan looked like after it hauled 3200 pounds of gravel in the bed. It needed new leafs after that but didnt hurt anything else. Those old hardbodys arebuilt tough.
Kyle
Old 04-21-2008, 11:37 PM
james1414d's Avatar
james1414d james1414d is offline
I had fun reading all the responses . its actualy called a torsion spring and prevents wheel hop and spring wrap. even with stock springs, you'd have to be WAY overloaded to get any use from them as "overload" springs. they appear pretty worn out regardless. I had a full new set of springs built at a professional shop. at their recommendation I decided to retain the tortion springs.
Super wagoneer gone!
Old 04-22-2008, 04:22 AM
Frank in Norway's Avatar
Frank in Norway Frank in Norway is offline
Sorry, but you'll have to school me on how that setup prevents spring wrap and wheel hop.
Frank in Norway
http://www.fullsizejeep.com
frank@fullsizejeep.com
'77 Wagoneer (360/TH400/QT, D60's, ARB's, 39,5's, Coil-spring)
Old 04-22-2008, 07:52 PM
Hammer's Avatar
Hammer Hammer is offline
Honestly, I would pull the block and keep that spring in there as is.
I know if I flex the rear springs on my chero out they can get negative arch, which is a bad thing if they are not designed that way!
78 Chero, 38"s and minimal lift
Old 06-15-2008, 06:58 AM
negative arch ain't so bad though...
It could snap a leaf someday, but it's not too big a deal to replace one.
All the leaves are long in that photo. I am thinking who ever did that may have wanted more flex and less stiff to flip the overload or torsion spring over. That is 1 cuppa java thinking at 7AM anyways.
Old 06-15-2008, 11:07 AM
Rainman's Avatar
Rainman Rainman is offline
the first thing I'd pull is the small spacer aka extra lift block. Stacked lift blocks are a no-no. And I'm will to bet its just a piece of steel with a hole drilled in it for the spring center pin, but no pin of its own to go into the real lift block.
Overall a less-than-optimal setup
John
'87 Grand Wagoneer
4" lift, 31s, 5.2L Magnum
Current Jeep status: Back on the road
Old 06-15-2008, 11:29 AM
I dont think that is another lift block. That actually looks like a wedge which rotates the axles to the correct angle.
Scott R.
Old 06-15-2008, 12:44 PM
That's not a stacked lift block. It's a shim to angle the axle slightly upward to reduce stress on the rear u joint. I'm gonna leave that in there.
Todd
