Old 08-20-2004, 02:33 PM
okiefsj okiefsj is offline
Question
I might try to install the tfi this weekend assuming i get my motor mounts and exhaust done first.i have a couple of questions i need to find out before i start. ok i am doing the mild performance upgrade with the tfi coil but not the springs. On the coil socket there are 3 wires 1 red 2 green i only have 2 wires on the stock coil where do the wires go?also is reseting the timing after the upgrade a must?
Get down with the under ground
Old 08-20-2004, 03:34 PM
J10Mike's Avatar
J10Mike J10Mike is offline
Delightfully Incompetent
i did the tfi upgrade. i used the red and one of the green. i believe i used the outer green on the plug. the third green could be used for some kind of resistor or capacitor. but, i didn't use it nor did i have instructions to use it. anyway, mine turned out fine and is one of the best upgrades i have done to my j10.
i'm sure someone will chime in on the use of the third green wire.
www.j10mike.com
Old 08-20-2004, 03:54 PM
thanks mike..the resistor thats another thing that was kind of unclear. did you have to time yours afterwards?
Old 08-20-2004, 04:00 PM
J10Mike's Avatar
i didn't reset the timing. it just sounded so good, i thought "why fix it if it isn't broke" sort of thing. but, you could always check it yourself. also, don't forget to gap your old or new plugs to .045.
www.j10mike.com
Old 08-20-2004, 04:35 PM
yep prepared for that just not the timing. thanks agian mike that was the only thing keeping me from doing it(no timing light)
Old 08-20-2004, 05:37 PM
Steve H Steve H is offline
I did not use the second green wire either.
I checked my timing afterwards and it was about the same as before.
91 GW, TBI, TFI, & Filled w/ Dog Hair
Old 08-21-2004, 01:40 AM
viscacha's Avatar
viscacha viscacha is offline
Cool
I believe the other green wire is for a tach hook up. I didn’t use mine either.
steve
’86 J20
SOA, Dana 60's, F/R Lockers
Full High Steer, Ram Assist
Bunch of Other Stuff
Old 08-22-2004, 12:46 PM
thanks again havent hooked up the coil yet i am going to pull the bracket off an old t-bird this week but the rest of the upgrade has impressed the heck out of me cant wait to put the coil on
Old 08-22-2004, 12:49 PM
paddyp's Avatar
paddyp paddyp is offline
I just cut my old bracket w/ a hacksaw and made it work w/ the TFI coil, took me all of 10 minutes to cut it up.
78 Wagoneer "Trusty Rusty"
360/TH400/Part-Time QT/ D44 Locked Front/Welded Rear/31x10.50x15 BFG M/T
Soon to come: 4.09 gears, SOA/shackle flip, 33x12.50x15 Swamper TSLs
Old 08-22-2004, 01:04 PM
i was thinking of puting mine where the a/c compressor used to be...as far as the hacksaw mod i will avoid that if i can hand saws are for the omish i like grinders and portabands..thanks though paddy p hows the rear quarters doin
[ August 22, 2004, 07:05 PM: Message edited by: okiefsj ]
Old 08-22-2004, 11:52 PM
paddyp's Avatar
That was before I got my grinder, so the hacksaw was the tool of choice. I still haven't got around to trimming my rears yet, still have that nasty gash there.
CS-144 upgrade, charging wire question Jeepeta General FSJ Tech 37 02-09-2006 11:27 PM
specific TFI upgrade question Magnum CJ General FSJ Tech 7 10-27-2005 04:10 PM
Upgrade Question Chuck General FSJ Tech 3 06-04-2004 09:21 AM
