02-11-2008, 11:06 AM
HELP baby blue stuck in Bozeman MT
Hey guy's anyone have any ideas on a mechanic in Bozeman ?
Baby Blue got backed off the trailer so the shipper could unload some boats, then has no start, no crank, solenoid clicks, and has had a jump but does the same, so either a solenoid or starter issue.
If someone local can recommend a local shop/mechanic ASAP that would be great.
Mike D.
02-11-2008, 11:44 AM
GrimJeeperReaper
Did he 'tap' or 'rap' the ignition module...sometimes a light tap gets them working again, or possible that the neutral safety switch is an issue..re-reading that your solenoid clicks...just a thought. Wish I could help yah out, but bumping this back up.
(oops,,,this is that manual trannied rig right?)...
2007 Pontiac G6...Vrrooooom!!!! (Don't get one!)
1963 Jeep J200 Gladiator. 230 OHC, T90, D20.
Too many hobbies! $$$
02-11-2008, 11:49 AM
I know they jumped it, but it still sounds like battery to me. Mine was doing the same thing summer before last. I went the whole summer hardly driving it because I was convinced it was the started and just didn't have time to change it out. Then, one day on a whim, I put the voltmeter on it... battery was dead. Put a new battery in it and it fired right up. Taught me a good lesson. Maybe the driver could borrow a battery to stick in it to get it back on the truck...
It's worth a try...
02-11-2008, 11:56 AM
Check the battery cable and ground connections and maybe swap a new fender solenoid. See if that helps.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
02-11-2008, 01:52 PM
Sounds like you're in the same situation I was in with one I had hauled here.
Wouldn't start for the shipping truck. A member came through for me and stopped by to get it running.
Of course the day the truck actually arrived, it wouldn't start again. They ended up paying a guy with a bobcat to push it on the truck for me. Pushed the bumper into the rear quarters for me. Nice job!
Dan
65 J200,98 ZJ 5.9, 99 TJ
02-11-2008, 02:00 PM
Rabble Rouser
Kinda odd the trailer guy doesn't have a winch, or at least a come-a-long? jeez.
good luck
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
02-11-2008, 02:41 PM
M&W Repair and Wrecker
(406) 587-5506
I used these guys once when i lived up there, they didnt shaft me, too bad its not in missoula then i could really help you with more connections, but in Bozeman they are the closest shop i know of that i would recommend.
i rarely send my rigs in but they didnt shang-high me, and they seemed like good guys. why not just call AAA or a wrecking company and have them winch it with a snatch onto the trailer deck
02-11-2008, 03:42 PM
Thanks dusty,
Same guy the NAPA guy told me about. I think it is covered, sounds like it was a loose starter wire. (PITA for such a small problem)
Mike D.
02-11-2008, 03:50 PM
