Old 01-14-2008, 07:49 PM
j20brett's Avatar
j20brett j20brett is offline
360 AMC
FSJ t-case skid plate!
Got worried about dropping this long underbelly on a rock and breaking the tcase...so i eased my fears a little with this...
38" wide at top and 34" at bottom. 1/4" plate with 1"x1"x1/8" squre tubing for support bolted in place with 8 grade 8 3/8" bolts threaded into frame
What ya think?
dont worry about that one extra bolt hole in the top...thats where i broke a tap off in the frame rail...
Build Thread
Fight Crime...Shoot Back.
ΜΟΛΩΝ ΛΑΒΕ
Old 01-14-2008, 07:56 PM
Jim Webb's Avatar
Jim Webb Jim Webb is offline
Looks good!! Now we need some pics of it installed!!
Jim
1987 Grand Wagoneer - 6" BJ's Offroad Lift kit, NP208 swap.
Old 01-14-2008, 08:15 PM
misfittom138's Avatar
misfittom138 misfittom138 is offline
Jim
X2!
81 Wagoneer 360/727/208, lockrite rear/welded front,4.10s, 7"SOA/shackle flip,3" body,OBA,37" Iroks,chopped,caged,highsteer,hydro assist....
Old 01-14-2008, 08:30 PM
j20brett's Avatar
360 AMC
haha i need some daylight for that...i dont get off work til 9:30 pm
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
Old 01-14-2008, 10:51 PM
etjeep's Avatar
etjeep etjeep is offline
Nice work! Its on my list to do. I was beside myself when I scratched my Atlas on some rocks (that did'nt sound right...LOL).
Later.....
Eric
___________
Eric Terjesen
'78 Wag
'03 Silverado 2500 Tow rig
Old 01-14-2008, 11:01 PM
Gambler68's Avatar
Rabble Rouser
you should vend those nice work!
I worked for a fab place for a few weeks before they packed up and left for where they came from (mutter) and their rockcrawler had this white plasticy stuff on their skidplates..it'd slide right over rocks and barely scratch it. Sweet stuff.
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 01-14-2008, 11:06 PM
j20brett's Avatar
360 AMC
haha yessss those teflon pads, or cutting board material stuff, is great for sliding...but VERY expensive in bulk.
I would consider building these if there is any interest. no clue on a price as this was steel i had lying around...and its about 70#'s
Thanks for the comments!
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
Old 01-15-2008, 08:09 AM
janie's Avatar
janie janie is offline
Dexron Impaired
Looks great Brett
Old 01-15-2008, 08:15 AM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
Looks tough...
Do you plan to put any drain holes in it?
Old 01-15-2008, 10:20 AM
Dr Teeth Dr Teeth is offline
Looks good!
How far forward does the skid plate cover? I was thinking of making one of these at some point that included a hoop for the front driveline.... The guy that rebuilt my tranny says he's seen alot of these jeeps (with stock front driveshafts like mine) break loose the front driveline, then it whips over and takes out the aluminum that holds the pan on the tranny... tranny is now fubar and has to be replaced. I don't plan on heavy wheelin, but it sure got me thinking. Probably wouldn't really even need a full hoop, maybe just a vertical plate right next to the tranny pan as protection just in case.
Pics installed please!
Thanks,
Todd
Old 01-15-2008, 12:34 PM
j20brett's Avatar
360 AMC
Robert: No drain holes...i hate mud. And id rather a nice smooth surface underneath. Its really easy to unbolt if i need to clean it out.
Dr Teeth: Here is the area it covers. From the tranny crossmember back to just past the tcase yoke.
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
Old 01-18-2008, 05:06 PM
j20brett's Avatar
360 AMC
finally got around to mounting it today...
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
Old 01-18-2008, 05:11 PM
Charlie_B's Avatar
Charlie_B Charlie_B is offline
looks slick. Nice work!
I can say that I was impressed by the lack of components hanging low on my rig when I bought it. Funny seeing these Ford guys running around with the t-case hanging about a foot lower than the frame.
I guess you cant really have too much protection. Again, nice job!
'79 Cherokee "Goldie" - under the knife Part I; Part II
Currently: body is on, now finishing undercarriage
'92 Cherokee "Rusty" - 3" lift, 31s
'05 Evo MR "Eve"
Old 01-18-2008, 05:15 PM
j20brett's Avatar
360 AMC
Thanks! Its needed for the place that im going in a couple weeks...lots of sharp pointy rocks to hard up on...and i like my t-case without holes in it
Build Thread
ΜΟΛΩΝ ΛΑΒΕ
Old 01-18-2008, 06:54 PM
red mistress's Avatar
clocking
That's bulletproof & no clocking required to have a flat belly.
69 Jeepster 8701 convertible
80 Honcho Sportside
82 CJ-8 75K org SR decals
82 Cheroeke Laredo 24K
84 CJ-8 mud Scrambler
Old 01-18-2008, 10:13 PM
etjeep's Avatar
....works better that way too!
Looks nice...do you have enough clearance for the rear driveshaft? hard to tell from the pic at that angle.
Also, the drain hole comment is a good one. I have a 1/4" skid plate covering my rear mounted gas tank. My drain holes were not big enough and clogged up with mud causing a little surface rust on the under side. I caught it in time and I'll fix that before I re-install it. Your horizontal stiffeners will catch every bit of mud thrown up there.
Later.....
Eric
___________
Eric Terjesen
'78 Wag
Old 01-18-2008, 10:17 PM
FSJ Guy FSJ Guy is offline
Wow. With 1/4" plate, I don't think you needed those "stiffener" bars at all!
Ethan Brady
www.bigscaryjeep.com
Old 01-18-2008, 10:54 PM
etjeep's Avatar
I decide to put some stiffener bars on mine as well as some stops to prevent it from driving up into my gas tank if I land on a rock dragging over a ledge, but you're right, it is very strong. I'll have to get some pics to show you what I mean.
Later.....
Eric
___________
Eric Terjesen
'78 Wag
Old 01-18-2008, 11:15 PM
funwheeling's Avatar
funwheeling funwheeling is offline
Did you weigh it??
1991 Grand Wag "The Phoenix!" IS back from the ashes!!!
My Yahoo
BJ's 6" lift
Holley Truck Avenger 670CFM
Mickey Thompson Wheels
Dick Cepeck FC-II
Killer 32 Nurf Bars
Comp Cam 260H
MSD Distributor, Coil and Controller
Edlebrock Headers
Dual Exhaust 2 Flowmaster 50's
Old 01-18-2008, 11:41 PM
stumpjumper3's Avatar
stumpjumper3 stumpjumper3 is offline
Pretty sick skidplate brett. Me likey. If you ever decide to make them in quantities, let me know, i could definetly see one o them on mine. Nice work
1978 Cherokee, 4 in and 33s
