Old 12-13-2007, 04:15 PM
Burn Victim's Avatar
Burn Victim Burn Victim is offline
Chevy S-10 Steering box???
Ok so I just heard about this.
What are the pros and cons????
Is this a direct bolt on????
Adam
Formally known as BigBlueJ-10
1980 Jeep J-10 5in.of susp.lift,soa,inboarded rear,shakle flip,hd44 front,d60 rear, 4.09 gears,1 1/2in body lift
33in rollers
360 AMC,4speed
razor grill
1969 Caddy sedan deville future donor
1950 IHC chopped 8in to much to list..............
Old 12-13-2007, 04:17 PM
Does it mater if the box is for a 2wd or 4wd S-10???
Adam
33in rollers
360 AMC,4speed
razor grill
Old 12-13-2007, 04:59 PM
armyfsj's Avatar
armyfsj armyfsj is offline
Try the search here for s10 box you will find out anything and everything you think you want to know about this swap and probably more.
JEEP STATUS: Currently Jeepless But looking!
http://www.militaryjeepers.com/
Old 12-13-2007, 05:16 PM
ok found out alot, but will my drop pit man arm work on the s-10 box?????
Adam
33in rollers
360 AMC,4speed
razor grill
Old 12-13-2007, 05:24 PM
armyfsj's Avatar
I cant say for sure as I have yet to install the box in mine but I would think so they are both GM boxes but i would measure just to make sure.
Old 12-13-2007, 06:53 PM
flatbackdragon's Avatar
flatbackdragon flatbackdragon is offline
mine did
"There's an inner idiot in us just waiting to climb out and romp about in unabashed stupidity, but most people retain just enough wit to keep the idiot bottled up."
Gary Harmon-writer for Grand Junction Daily Sentinel (newspaper)
Phil (or Flip, Dragon)
Draco-79 Cherokee 360/QT-4" lift-pretty much stock and trying to fall apart
Old 12-14-2007, 01:31 AM
-Bluegill-'s Avatar
-Bluegill- -Bluegill- is offline
Yes, I have a BJ's dropped pitman bolted on my '98 S-10 4x4 steering box (on the Cherokee) - it works great.
The only real "con" to the swap is that only 3 of the 4 frame bolt holes will be re-used. I installed Tad's steering brace to compensate. Other than that, it is a nice upgrade IMO.
Old 12-14-2007, 07:13 AM
Originally Posted by -Bluegill-
...The only real "con" to the swap is that only 3 of the 4 frame bolt holes will be re-used. I installed Tad's steering brace to compensate. Other than that, it is a nice upgrade IMO.
Rob,
Send me some pic's if you can please I'd like to update the page over the holidays. I think you and Sitting Bull are the only two on S10 boxes.
BTW:
I have one unclaimed FSJ steering box brace to get rid of before the 20th (see link below) at a discount.
http://www.ifsja.org/forums/vb/showthread.php?t=78791
Old 12-14-2007, 10:08 AM
-Bluegill-'s Avatar
Originally Posted by tadsal
Rob,
The way my frame looks? You sure? I'll snap some............but it'll be like watching Janet Reno wear a beautiful thong. (the brace = the thong) LOL
Remember, mine's a trail beater.....don't need no stinking paint on da frame! LOL your brace, BJ's extended shackles, and the F350 front shock towers are the most beautiful parts on it.
Old 12-14-2007, 12:08 PM
I just need the pic of the brace on the S10 box, I don't have any.
