Old 12-13-2007, 01:27 PM
red mistress's Avatar
Gateway Buckshot tires
what happened to the Gateway Buckshot's mudders? Can't find them on web.
I ran a set ( Q's -35"? seems to jog memory) on an old Ford 3/4 ton with 16.5 in the mid 80's.
The tread was like over an inch in depth, howeled like the coyote's on a full moon.
Only lasted about 5,000 miles, well the Ford had built 460 and I was young with a real heavy right foot.
old school tire if I ever saw one.
69 Jeepster 8701 convertible
80 Honcho Sportside
82 CJ-8 75K org SR decals
82 Cheroeke Laredo 24K
84 CJ-8 mud Scrambler
Old 12-13-2007, 01:30 PM
J4GRAND's Avatar
J4GRAND J4GRAND is offline
J4000 Restoration Specialist
I remember those tires too; a neighbor used to have a set on a VERY lifted CJ-5. Here are some Maxxis Buckshot Mudders; don't know if they are the same or not:
http://www.offroaders.com/tech/AT-MT...hot-Mudder.htm
Patrick V.
MEMBER #14
78 Cherokee Chief WT "Old Blue" 360 V8 4V TH400 QT
05 Jeep Grand Cherokee 3.7 V6 5 speed automatic with new QT
Old 12-13-2007, 01:40 PM
Buckshot's
hopefully Maxxis didn't take over production.
Not that Maxxis is a bad tire as I've got some on trailer.
tread only 19/32" and no 16.5 rims at all.
Dang, I thought I had tires picked out.
Those Gateway's, although narrow by today's standard, ruled.
Probably softer than competition tires, they sure didn't last, but were cheap and effective.
It took big HP to spin them they gripped so good.
I rememeber the treads being way deeper than anything I've ever seen including the 39.5 Boggers I ran on Scrambler for while.
When they were new you could really feel the tire give & flex going around corners.
80 Honcho Sportside
Old 12-13-2007, 04:56 PM
shadowjeep's Avatar
the maxxis buckshot mudder is a pretty soft tire. i run 33's on my wag. i really like them, they will dig bigtime. if you want a mostly on road tire the maxxis bighorn wears better on the highway. most to the oil well service trucks in my area are switching to them over the buckshots in order for them to last longer. although i do like the look of the bighorn better than the buckshots, the buckshots go better offroad due to the softer rubber and more sipes. IMHO
bighorns http://www.maxxis.com/products/autom...il.asp?id=5477
Rick C.
www.kymc.org
shadowjeep
2003 Chevy Silverado
Old 12-13-2007, 05:55 PM
AlsChopShop's Avatar
i'd disagree on the difference between the buckshots and the bighorns. i'm running the bighorns on my full size chevy pickup, and while they aren't too noisy, i'm sure the buckshots would have better road manners because the side lugs of the bighorns are so far apart. i'd rather run the buckshots on the road and the bighorns offroad. the bighorns grip like crazy too, and are a pretty soft compound.
Al
Old 12-13-2007, 09:46 PM
shackwrrr's Avatar
they were made by interco under the gateway design and they prolly stoped making them in 1992 when this happened
http://www.uspto.gov/web/offices/com...1998/96404.pdf
goodyear sued interco saying that the tread design was similar
Jeepless
In to Turbo crap now
Old 12-13-2007, 09:48 PM
shackwrrr's Avatar
nevermind on that i read more and the gateway was just used as an example in the case sorry
Jeepless
Old 12-13-2007, 10:16 PM
malodin's Avatar
malodin malodin is offline
ive got a set of them, gateway buckshots, q's something everything ive found says there 35" tall but next to my 35 swampers i had on my cj5 frame they stood at least 2-3" taller...they are nice tires and mine only have about 100 miles on them right now as they are wating for me to build a rig for them
Old 12-13-2007, 11:29 PM
shackwrrr's Avatar
could you get pictures? I looked online for pictures and it seems that nobody has any of them
Jeepless
Old 12-14-2007, 01:35 AM
jeeping1974's Avatar
Denman Tire Corporation use to have them listed a few months back but do not any more. one of the 4 wheeling mags did a write up on the gateway tires. they were a Q-78 tire (35.5" tall, 10.5" wide).
i did find the tire but in some other sizes.
http://www.ok4wd.com/index.php/catal...ders_bias_ply/
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 12-14-2007, 06:49 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Dennis, you may know this but I'm pretty sure you can still the TSL Super Swamper in a Q78.
I think it's the SAM-28 you'd want for the 16.5" rim: http://www.intercotire.com/site33.php
***edit, well maybe the TSL Q78 is only in 15 & 16" rims... that ain't gonna help since you just bought them nice 16.5" rims.
Old 12-14-2007, 09:13 AM
Unhappy Buckshot's
The OK tire place show's the real Gateway Buckshot's.
Looks like Maxxis made a reproduction and used Buckshot name but not anywhere close to origional tire. 19/32 is just 1/2" tread.
I looked in my old bronco file and found where tread depth was indeed
1" in depth.
I'm mostly going for the old school look these give, they're really terrible street tire's. But Glad prob won't get 5000 miles in 15 years.
I need/want a tall narrow tire 35 x 10.5 on Kaiserman's 8.25" wide slots.
Real Buckshots must be discontinued, probably why don't see on trucks in magazines anymore.
80 Honcho Sportside
Old 12-14-2007, 12:43 PM
shadowjeep's Avatar
Al
my only reasoning behind the differences are the size of the space between the lugs on the buckshots compared the the lugs on the bighorns. the lugs on the buckshots are farther apart than the bighorns on the 33" tires. i personally like the looks of the bighorn more than the buckshots. i havent had the bighorns on the wag but i have done a side by side comparison. that was the reason i chose the buckhots. i just wish the buckshots had the side biters that the bighorns had, that would be cool.
on a side not with the name, i think maxxis got away with the name because they added mudder to the name.
Rick C.
www.kymc.org
shadowjeep
Old 12-14-2007, 03:08 PM
Gateway Buckshot
No longer made , some inventory still floating around in 15".
Maxxis took over production and tread is similar but lugs are 1/2" instead of 1" deep.
Guess - I gotta pick another tire (Swamper or BFG) or do another
worldwide NOS tire search...
I like finding the impossible.
80 Honcho Sportside
Old 12-14-2007, 03:30 PM
malodin's Avatar
i will get some pictures tomorow of mine
Old 12-14-2007, 03:50 PM
buckshot's
35" x 16.5 rim?
Lets make a deal!
80 Honcho Sportside
Old 12-15-2007, 02:43 AM
energyhutch's Avatar
energyhutch energyhutch is offline
I know it is not the gateway but I thought i would pass this onto this thread
http://lubbock.craigslist.org/pts/507345530.html
-hutch
-Hutch
1994 Cherokee, the daily driver ...
1976 Wagoneer, 401 complete with original vacuum disaster and electrical nightmare, both of which have been fixed prior to the sale of this rig
1978 Cherokee, " Roadie " recently driven back from Phoenix to Texas ... no trailer involved!
Old 12-15-2007, 03:47 AM
noflyzone's Avatar
noflyzone noflyzone is offline
http://www.intercotire.com/site32.php
SAM-22 34x9.5 on 16.5
Have you thought about Michelins Their Mil specs are cheap and look old school.
Old 12-15-2007, 11:37 AM
shackwrrr's Avatar
wanna go old shool then this is the tire for you
Jeepless
Old 12-15-2007, 11:49 AM
old school tires
are those Ground Hawgs?
your photobucket link no worke.
80 Honcho Sportside
