Old 10-03-2007, 08:31 PM
mic63's Avatar
mic63 mic63 is offline
Another FSJ, On the road again, again.
Now that I've missed every car show for the season. The old 230 is screaming down the road again. First test run went good. Made a few adjustments, and second test run produced LEAKS. Coolant and oil, expected, not suprised, remained calm. Retorqued head and intake manifold to fix coolant leaks, been holding for the last 300 miles. Oil leak bites. I'll have to remove the timing chain cover for the fix. It leaks about a quart every 150 miles, I'm going to drive it till the snow flies, then the fix in a heated garage. Runs smooth, no more smoke cloud. With the exception of 2 red lights, I held a steady 70 mph for 23 miles. I don't have to stick to the back roads anymore.
Thanks to Kaiser-Willys, they had everyting I needed.
Hardened seats. Valves, seals and springs. Timing chain. Distributor cap, dizzy, points, condenser. Complete engine gasket set. Clutch slave cylinder. Steering bell crank, and other odds and ends.
1963 Wagoneer. 230 OHC Tornado. Three on the tree.
http://s146.photobucket.com/albums/r...63%20Wagoneer/
Old 10-03-2007, 08:42 PM
j20brett's Avatar
j20brett j20brett is offline
Thats a beautiful wag you got there. Excellent work!
"Kaiser" - 1981 J20 113" WB - 360 w/ hei/727/208-d44hd front aussie/d60 rear welded - CS144/Taurus fan/flatbed and roll bar
Future mods - 6.0l chevy, hp60, 14-bolt, NWF Black Box/NP205, 5.13's, SOA, 42's
Build Thread
Fight Crime...Shoot Back.
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 10-03-2007, 08:59 PM
those 230s' are a beautiful engine.
Old 10-05-2007, 06:24 PM
jeepmandan's Avatar
jeepmandan jeepmandan is offline
And to think I was bidding on that truck on Ebay. I gave up because I didn't need another
Dan
65 J200,98 ZJ 5.9, 99 TJ
Old 10-05-2007, 07:25 PM
Millerluck's Avatar
Congrats and.....Holly smokes what a sexy timing chain.
Larry
88GW "Mississippi" 401,Edelbrock heads,and stuff,
4" Skyjacker, BFG AT's,OBA,Air Horn.
'89GW "Mutt" wood for now, 360, 1405, Edelbrock cam,
4"Rusty's,3"body,33"BFG. Detroit Truetrack Warn Hubs
The Metal Workshop
http://www.themetalworkshop.com/index.html
