Old 09-25-2007, 08:27 AM
XtremeOverKill's Avatar
XtremeOverKill XtremeOverKill is offline
Racheting Tie Downs/Straps
Its time to buy some new tie downs - biggest thing I have to tie down is an ATV, but I've used straps in the past for just about everything else.
I admit I can't tie knots, so the rachet design has been a blessing and I will be sticking to the rachet design.
What would you reccomend on a tie down with good holding power, long life, exposure to sun only when in transit, and well taken care of?
Current tie downs are rated at 1400 lbs - not sure if thats static or dynamic strength but I would like to not go anything less than that.
New engine's finished: (Assembly Pics)
9.5:1 CR
Mahle Flat Top Pistons - Coated Skirts (Pictures)
Polished Valves and Chambers (Click Here for Pics)
Offy Dual Port intake
Barry Grant 625 Road Demon
K54 Engle grind on 112 LSA
RollMaster Timing
Polished Rods
Doug Thorley Headers
Customized Valve Covers
12/3/2010 - Rear Main Seal that doesn’t leak!
Old 09-25-2007, 11:08 AM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
For an ATV those are probably a decent size, but if you've got something bigger in mind, go with a minimum of 5000 lb per strap, 10,000 lb is obviously better if you're going to trailer your FSJ.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 09-25-2007, 11:23 AM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is online now
Hey watch this...
For ATV's, just go to Harbor Freight and get several of the 1400lb straps... They are by far the cheapest place to get them.. I have been using them for years, and have never had any problems. If in doubt, just use more.
I have even used them to tie down a ZJ on a trailer before. Granted, I used 9 of them, but they worked just fine.
Old 09-25-2007, 12:38 PM
Thanks guys,
I completely agree on the ATV being sufficient for the 'little' tie downs. But the Jeep will be trailered and strapped down with racheting load binders, or bigger straps.
9.5:1 CR
RollMaster Timing
Polished Rods
Old 09-25-2007, 01:11 PM
nepatternmaker nepatternmaker is offline
Sam's has a 4 pack of 1-1 1/2" wide straps that have way better ratchets than the HF cheapies, also where I get my car tie downs, they have 2" 10k ratchet straps for about $13-14 each.
better yet get to a industrial surplus store and buy the ratchets and straps and make your own or have an upholsterer sew them up for you whatever length you want.
dave
'86 GW 360 727 268 D44's BFG radial T/A A/T's, knocking motor and metal in the tranny fluid.
'97 F350 PSD CC 4x4 long bed.
'89 Volvo 740, 303,000 and still going
'91 Volvo 240 S/W
'73 f150 4X4 390 4 sp D44/9" pull anything you can chain it to.
Old 09-25-2007, 02:19 PM
grand_wag_85's Avatar
Murphy's Law Poster Child
Long time no see bro! I dunno what the load ratings are, thinking 10Klbs but I always use the trucker flat-bed style ratcheting straps. Secured the tow-bar to the J10 with 'em, wierd part is that's the way Reese designed that tow bar Held up well tho.
http://i23.photobucket.com/albums/b3...0/100_4703.jpg
Old 09-25-2007, 05:13 PM
HOOT's Avatar
HOOT HOOT is offline
If I'm holding something important like one of the Kawasaki street bikes then I use my Ancra straps. They are by far the best I've ever used.
On the car trailer I have 4 - 15,000 lb rated straps.
For straping down tree limbs and such on one of the trailers or Jeep parts in the bed of the truck I use those cheapy "off the shelf braand" ratcheting straps. Get the bright orange ones so you will be able to spot them easier in the dark.
I've never lost a load yet..
I will be going to chains and binders on the car trailer after this winter. I don't trust my straps much anymore they are 3 years old now.
and no
Tom Gibson
1981 J-20 "RED" 360/727/208,R.I.P. Undergoing major retrofit to be a 1980 Utility truck.
