09-23-2007, 09:26 AM
On a budget Tie rods J10 Pickup
Attachment 6356
I need to replace everything from the pitman to the hubs.
Where is there a good budget (cheap) source for these parts?
1982 J10
4.0 HO, FI from 1993 XJ
TF 727, NP 208
Hydro-boost
Flex-a-Lite Electric Fan
Dana 44 front 3.73
GM 9.5" rear 3.73
BJs 2 inch lift
33x10.50 BFG MT
09-23-2007, 10:04 AM
Ok, stating the standard "steering is the last thing to cheap out on" disclamer first, BJs is probably a good place to start looking:
http://www.bjsoffroad.com/cartgenie/...t.asp?scat=124
They only have Moog stuff so it's probably more than you could get stuff at a standard McParts store. That stuff is going to be standard McSteering stuff, too, though.
As with pretty much everything...you get what you pay for.
aa
Anthony
1983 J-10 - 4.6L(MPFI)/CS144/NV3550/D300/44/44/3.54/32
1983 Honda CB1100F
1983 Honda CB1000C
09-23-2007, 10:14 AM
Thanks!!!!! I should own Stock in BJs
Moog: Moog Steering Complete Tie Rod Kit Price: $290.00 with IFSJA discount
Top-Quality Moog steering complete tie rod kit. These are the complete kits for your FSJ! This kit includes all 4 Moog tie rods with hardware and 2 adjusting sleeves!
Lifetime Warranty on all Moog Steering Parts
Widetrack: 1974-1983 Cherokee (with Factory Fender Flares) and 1974-1988 J-truck (all)
1982 J10
TF 727, NP 208
Hydro-boost
Dana 44 front 3.73
GM 9.5" rear 3.73
BJs 2 inch lift
33x10.50 BFG MT
09-23-2007, 11:28 AM
Got mine at rockauto.com. don't know if the price is that much better than bjsoffroad (whom I am also a fan of), but I picked up all moog components for around $250.
I also second what was said above on buying quality parts, it will get real expensive real quick using the cheap stuff.
"Turdbot" 1978 J10 Golden Eagle AMC 401/QT/4" Superlift/35x12.5
09-23-2007, 12:39 PM
J just
E empty
E every
P pocket
Welcome to the club
79 J10/360 TFI Upgrade/TH400/QTwLo/Howell TBI
09-23-2007, 01:12 PM
spent 190 at a mcparts here, on all my stuff. i think most is Moog. would have been 19 dollars cheaper if the boss wasn't working.
80 J-10 with 3in RC lift,1 in. shackles, buckshot M/T 33's. dual glasspack exhaust,eldobrock intake/carb/valve covers/aircleaner k&n, autometer tach, spare tire mount w/ fullsize spare,tool box, 40gal spare tank, grant steering wheel, rhino grill,DPA (Not installed Doug T's Headers, Hi lift jack, cobra cb,tie rods, & dual timing chain
09-23-2007, 01:15 PM
autopartsgiant.com has moog,about 225.00 for everything.
free shipping too.
that's where i get all my parts i don't immediatly need.
09-23-2007, 03:11 PM
1982 JEEP J10 4.2L 258cid L6 2BBL
MOOG Part # ES453L {Tie Rod End} Frt Strg; Inner; LH; At pitman Arm; 4WD$35.79
MOOG Part # ES452L {Tie Rod End} Frt Strg; Outer; LH; Steering Arm To Steering Arm; 4WD$39.79
MOOG Part # DS896 {Tie Rod End} Frt Strg; Inner; RH; At Connecting Tie Rod; 4WD$47.79
MOOG Part # DS915 {Tie Rod End} Frt Strg; Outer; RH; 4WD$73.89
MOOG Part # ES362S {Adjusting Sleeve}
Frt Strg; LH; Pitman Arm To Connecting Tie Rod; 4WD
Frt Strg; LH; Steering Arm To Steering Arm; 4WD$13.34 x2=$26.68
Subtotal$223.94
Ground $18.14
Total$242.08
This looks like the cheapest so far. AutoZone & O'Reilly's are both more expensive.
1982 J10
TF 727, NP 208
Hydro-boost
Dana 44 front 3.73
GM 9.5" rear 3.73
BJs 2 inch lift
33x10.50 BFG MT
