Old 09-03-2007, 08:18 PM
toyotajeep toyotajeep is offline
Dana 44 Axle Weight?
Hello,
I am contemplating a new set of axles for a Cj build and I need to know the weight of some axles.
What is the actual weight of a complete front NT Dana 44 out of say a mid to late 70's Wagoneer?
Preferably seperate front and rear weights.
Anyone shipped any of these etc. and gotten a weight?
ROB
Old 09-04-2007, 06:58 AM
janie's Avatar
janie janie is offline
Dexron Impaired
Rob,
Not sure about the NT, but the WT front Dana 44 tips the scales at about 500 lbs.
Old 09-04-2007, 02:33 PM
cincyjeeprs cincyjeeprs is offline
I've got an exact set like that in my garage right now waiting for me to get them ready for my Willys. Let me get home tonight and I'll drop them on my foot. I'll let you know how heavy they feel. I know I can only pick up one end at a time. Those suckers are heavy, complete with drums.
What if I put a bathroom scale under each end and add them together. Will that work? (Seriously, will that work?)
'85 CJ8 Shiny but Rough
'54 Willys Aero Lark, 161 F-Head six
'90 SJ Everything works - sorta. (edit: most things...edit: some things)
'04 WJ Overland (Blue Pill)
Old 09-04-2007, 09:20 PM
Whoa! 500LBS..........I am making a lightweight CJ-5 with my students and I'm just shopping around for axles.
I may have to use axles after my namesake!
Thank you. Any one with NT weights?
ROB
Old 09-04-2007, 09:58 PM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
All axles are heavy, but D44's probably have the best weight to strength ratio..
What are the other specs on your CJ? That would help determine your best axle choices...
Old 09-04-2007, 10:13 PM
Here is the dealio. I am building a low weight DD capable CJ-5 that will get close to 20mpg and push 37-38 tires. Before you say I am nuts, here is how. I am using a toyota engine, tranny and t.case. I have the whole truck here now. It would seem logical to just use all the yota stuff.....I know.
The only reason why the Dana's are on the table is that I already have alot of the support parts, I have 5.38's already, and a Trac-Loc for the front etc. Two main reasons, cheaper and they would match my tow rig which uses Wagoneer 44's.
According to my limited research the solid-axle yota front axle weighs around 275 or slightly less, and the rear weighs 210 or so.
BTW- My screen name is derived from my earlier days when I made a Toyota powered CJ-5. It had 5.71's with 38" tires and got upper teens. I hoping to better that with much less weight and so forth.
I guess I am answering my own question right now.....
I would still like to know the weight just to help in the math process.
Thank you, ROB
Looking like the
Old 09-04-2007, 10:16 PM
TPICherokee's Avatar
Originally Posted by janie
Rob,
500?!!? That can't be right, can it? If 2 regular size people can lift one, it can't weigh that much...
Old 09-04-2007, 10:22 PM
shepherdskeep's Avatar
shepherdskeep shepherdskeep is offline
2 regular sized people can lift a D44 rear easy - but a FRONT D44 is another story. It took 3 guys to move my spare WT front into & out of the trailer - and we all nearly busted a gut doing so. The inner & outer knuckles make the extra weight, followed by the brakes.
I don't have exact weights though, sorry.
-Rob
Bluegill on www.4x4Grace.com
79 Cherokee WT
01 TJ Sport
It's a Jeep thing!
Old 09-04-2007, 10:29 PM
Dmntxn77's Avatar
Hey watch this...
I loaded a front and rear N/T D44 from an 86 Waggy, and a front and rear W/T D44 from my Chief on a trailer by myself, so I woudnt call them nut busting or anything..
BTW, neither had wheels and tires on them, and it wasnt easy, but i wouldnt be afraid to do it again..
Old 09-04-2007, 10:38 PM
malodin's Avatar
malodin malodin is offline
i pulled the front widetrack axle outta my fsj by my self with no one to help and moved it way out of the way of where i was working without much problems, yes its heavy but 500 does seem eccessive
Old 09-05-2007, 05:12 AM
Subic Jeep's Avatar
Subic Jeep Subic Jeep is offline
http://www.jpmagazine.com/projectbuild/
Speaking of weight, we decided to throw the stock axles and the Pro-Rocks on a scale to see how much weight we gained in the swap. A stock TJ Dana 44 rear axle tips the scales at 221 pounds versus the Pro-Rock 60's 338 pounds. Up front the factory TJ Dana 30 weighs in at 238 pounds and the Pro-Rock front a portly 473 pounds. Overall, the axle swap only added 352 pounds to our Jeep. That's less than what we added by switching from 30-inch tires to 37s. Besides, the added weight complements stability by lowering your Jeep's center of gravity to help prevent rollovers. Reducing unnecessary weight is a good idea, but a well-designed, heavier axle that always performs is better than a lightweight axle that breaks down frequently.
http://www.jpmagazine.com/projectbui...t_4/index.html
Lars
I am in the five bananas category!
Cherokee 1981 officially 1974 huh local irony
Gen 1 GM-SB 350 V8 TBI - TH400 - Klune V - Twin stick NP205 w. Nippon shifter
Dana 60 w. ARB locker, hydraulic assist + GM 14FF w. Detroit locker.4-link rear on LC80 19mm coils
Rancho 5036 Shocks 14 inch travel. 39.5x15.5x15 TSL
Old 09-05-2007, 06:14 AM
It seems like I had heard at one time that a GM 60 SRW weighed 618 or so. I know it was way heavier than any 44..........way heavier.
Currently I am looking at the spring thing. I'll post up on that.
Thanks people, ROB
Old 09-05-2007, 08:04 AM
LTS06 LTS06 is offline
I have picked up a front D-44 (mine...from a wagoneer) by myself. I'm a big guy but I agree that 500 seems excessive even for a complete axle. (***I didn't really move it anywhere but I can/did pick it up***)
I had an XJ D-44 rear shipped at about 275#...I doubt the knuckles/hubs/spindles add 225#. I could believe 400 but if I can lift 500# I am stronger than I thought.
1973 J2000 360/T15
1978 CJ-5 304/T-150/D-20 STOCK
1987 MJ 10B/14B axles with 5.13's
1967 M-416 1/4 ton trailer
1974 Scout II 345/T-18/D-20
Old 09-05-2007, 08:36 AM
SCscoutguy's Avatar
SCscoutguy SCscoutguy is offline
There is no way a front widetrack dana 44 weights 500lbs. I took one out of a J-10 and picked it up by myself and lifted it a few feet up into my trailer. Then I took it off the trailer and walked about 15 feet with it to put it on jackstands.
John
Old 09-05-2007, 08:58 AM
janie's Avatar
Dexron Impaired
Fellas, I know something was posted about the weight of the WT 44 not to long ago. I'm a doing a search now to try and find it. Obviously, I've never picked one up, but I know I saw on here where someone mentioned the weight being right at 500 pounds.
Old 09-05-2007, 09:17 AM
BLiP's Avatar
BLiP BLiP is offline
Ok the front is W/T d44 axle is DEFIANTLY heavy took myself and another guy to load it up in the back of my stepdads truck and I am a pretty strong guy I can pick the rear W/T d44 up by myself from off the ground pretty easily if I am warmed up cant go much higher than chest height though. The front one I can barely drag around on the ground and my back will be killing me afterwards. I would say the front is about 400lbs maybe slightly more And the rear is maybe 200lbs maybe slightly more. Oh and who cares if will drive around on 38 inch tires I wanna see it able to wheel around on 38s without breaking
81 Cherokee W/T T18 D20
http://www.myspace.com/blipondarader
Shallow Pockets Racing Team
That Blowed up Real Good
Old 09-05-2007, 09:44 AM
Cecil14's Avatar
Cecil14 Cecil14 is offline
There is no freakin way a front D44 weighs 500#. My rear mog 404 weighs 500# and lemme tell ya the D44 is nowhere even close. I would guess 350-400 tops. I'm not a huge guy and I can move the danas around without too much hassle.
aa
Anthony
1983 J-10 - 4.6L(MPFI)/CS130D/NV3550/D300/44/44/3.54/32s/42 gallon 'burb tank
Old 09-05-2007, 10:03 AM
Mikel's Avatar
Mikel Mikel is offline
I once lifted a Dana 70 housing all by myself. Now, excuse me while I go to the chiropractor...
1969 M715 6x6
1963 J300 Swivel frame
Old 09-05-2007, 11:07 AM
Dmntxn77's Avatar
Hey watch this...
I have loaded a rear D60 on a trailer by my self.. It wasnt that bad either. It was a bit harder than the D44 though.
Now on the otherhand.. I loaded a front HD44 on the trailer at the same time. I am surprised that I have been able to make babies after that one... I dont remember the exact differences besides the 8 lugs and thicker tubes, but that thing was HEAVY...
Old 09-05-2007, 02:10 PM
AlsChopShop's Avatar
i've never lifted a complete 44 before, just a wt front with no knuckles and shafts so it was pretty light with only the housing and gearset. but the wt 44 rear is not comfortable to lift by ones self when its complete drum to drum.
i just bought a corporate 14b full floater, while trying to load it into the back of the truck (with 31" load E rollers!) with help from my bud he said it weighs 750lbs... i believe it! it took two of us to load it, thank goodness joe is a big guy. i didn't unload it, but it took 3 regular sized people to unload it from the truck. pansies.
Al
