Old 08-27-2007, 06:00 AM
aus's Avatar
aus aus is offline
Broken axle
Hi, is it common to break an axle in a m 20 with 35 inch tyres as mine broke at the spline idling up a small rock step. also the transfer droped in and out of front drive all the way home(7 hr drive) . it has a 727 auto.
thanks warren.
Old 08-27-2007, 11:38 AM
Headhoncho's Avatar
thanks warren.
Too many possibilities....are you the original owner, has the previous owner abused it, is the axle housing bent, is your carrier cracked inside the diff housing? 35" tires should be ok for that axle. I ran 36's on my 20 for a long time without any problems.
JR
1966 mustang fastback
'07 Dodge Charger 3.5
Old 08-27-2007, 03:52 PM
unclethumbtack's Avatar
unclethumbtack unclethumbtack is offline
I run 35's hard and mine is welded, have had no breakages. KOW. (Knock On Wood)
Unclethumbtack
81' Cherokee the turdburglar (off-road project)
360 727 208 SOA 35" procomps
Ramsey Winch
77 J-10 258 QT (the restoration project)
Old 08-27-2007, 06:30 PM
Stuka's Avatar
Stuka Stuka is offline
How much skinny pedal were you giving it? Were you bouncing? Rocks, mud?
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 08-27-2007, 11:01 PM
aus's Avatar
aus aus is offline
not much skinny pedal at all ,no bouncing it was small rock step and when it broke there was no bang. it was the first trip out for me in the jeep ,the po had 255/85 16 bfg s. thanks.
Old 08-27-2007, 11:41 PM
Stuka's Avatar
Sounds like it was getting close for a while if thats all it took. And I have a feeling these axles are not a dime a dozen there in OZ as they are here. I am sure one of us here could ship some two you though, never hurts to have spares.
Old 08-28-2007, 05:22 AM
aus's Avatar
aus aus is offline
been trying to track one down for a few days now and just found one 800 kms away for $130. thanks for your help.
warren.
Old 08-28-2007, 05:55 AM
shimniok's Avatar
shimniok shimniok is offline
Good luck, hope the next one holds up. I think it probably will depending on how hairy the trails are. We've got more than a few folks here that run 33's and 35's on D44's and M20's. Other than Dome, I don't think I've ever witnessed or know of anyone who broke an axle shaft in one of these. (I think his was caused by a locker giving it up)
Michael
KØFSJ - 1986 Grand Wagoneer "Troubled Child" - tc.wagoneer.org - on facebook
Stock 360, 3" w/ Magnaflow, 727 with TransGo, NP208, 4" Skyjacker, 33" BFG MT, WT Axles, Lock Right & ARB, OBA
Jeep Status: Down for TBI Install
