Old 08-05-2007, 06:17 PM
the cause of my headache.
i've been tryin' to track down a miss for a week.compression test came up good.pulled the valve covers,all the rockers were good,and had full lift.pulled the intake,found a lot of oil on the intake valves,thought maybe gummed up valves.i always suspected the cast iron square bore maniflod i had on was leaking from the underside,as it idled with the idle screw backed all the way out.the oil made me suspect it more,so i threw a non egr performer intake on,but still had the miss.
so,figured a badly burnt valve,was preparing to pull the heads,had the rockers off,when i leaned over the head,and felt a valve open under my hand.
found that #2 cylinders exhaust valve spring broke,one coil from the bottom.it was suckuing open on the intake stroke,causing the miss.
replaced the spring,runs like a champ.
Old 08-05-2007, 07:51 PM
baybilly's Avatar
baybilly baybilly is offline
cool. easy fix. now that you had them valve covers off, did you by any chance slap on them test covers ?? i wish someone would get back to me on how they worked out.
baybilly = dave
77 cherokee S ,parts
84 J10, parts
51 Willys
88 XJ, DD
1966 GT-350 mustang/ project
Old 08-05-2007, 07:53 PM
doh! no......
Old 08-05-2007, 08:07 PM
scantar's Avatar
scantar scantar is offline
Dang...good find.
I'd have given up long before I would have ever found that.
Old 08-05-2007, 08:12 PM
drlocke's Avatar
drlocke drlocke is offline
Roadside Mechanic
Lucky you! Been there, done that.... Glad you didn't wind up dropping a valve--that would've been messy indeed....
I had broken valve springs--exhaust on cylinder # one and intake on cylinder #2 of the old flathead 6 in my Dodge truck many years ago. They both happened almost at once! I decided that there were likely more to follow, and decided to do a bottom-up rebuild on the engine. Glad I did. What seemed to me like just another of Life's little sucker punches turned out to be a message about greater things. The rings on all the pistons save one were broken, and were overlapping themselves in lands that were burned wide enougn to accommodate double the ring thickness to allow such juxtaposition.
As for you trying to "track down a miss" I hope for your sake that Ristow II didn't catcha!
Old 01-27-2010, 09:46 PM
bill32 bill32 is offline
Thanks everyone for your ideas. I had not thought about a broken exhaust valve spring. Will pull the valve cover tomorrow and check valve train, rockers and the springs.
Bill
Old 01-27-2010, 09:53 PM
Tatsadasayago's Avatar
Tatsadasayago Tatsadasayago is offline
Nice Catch!
Who'd a thunk it?
Jim
KY7DX/6
76 401 Wagoneer *The Gag-O-Neer*
77 360 W/T Cherokee Chief *Blair Jeep Project III* http://www.ifsja.org/forums/vb/showthread.php?t=113707
Sacramento, CA USA
mattmopar440's Avatar
I think this is when mike still owned my G-wag
87' Grand Wagoneer
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Inferior Chevy
