towing and trans
What are the pros and cons of towing with manual vs. automatic trans? Is one preferred over the other? I am assuming the automatic has an external cooler, but everything else is stock. I want to use my TF727 Chero to tow my CJ7. I think this combo is fine, but it got me thinking about the differences.
For ther manual, you might go through clutches a little faster. I'm not sure if there would be any other issue, plus you get engine braking.
For the automatic, it will run hotter (which the cooler should take care of), but I can't think of anything else.
So, is it a matter of preference?
Thanks
Chris
Alcohol doesn't solve any problems, but then again, neither does milk.
1980 Cherokee Chief W/T, "Big Dog" 360-2v, 727, NP-219, 3.31, PW, PDL, AC, white w/ blue Western int.
