06-23-2007, 07:10 AM
Tow dolly question...will a GW pull a GW?
Will it fit on a dolly and will a Wagon be able to pull another Wagon safely?
Steve
06-23-2007, 07:31 AM
Roadside Mechanic
I wouldn't do it. Murphy is waiting.
06-23-2007, 08:51 AM
I don't like tow dollys but my Cherokee pulled pretty much anything I wanted it to without any issues. I pulled GW's on trailers with it so it can be done...
06-23-2007, 09:05 AM
Not the best method, but I have done it three or five times. How far are you going? I never went more than 50 miles.
FSJ-Earl
06-23-2007, 09:20 AM
Find another one already?
James
1988 GW stock (work in progress)
2003 GC Laredo (family car)
Thought it would be simple, forgot it was a Jeep.
06-23-2007, 09:26 AM
Perfesser of Jeepology
As others have said, I wouldn't use a tow dolly, but it'll pull another FSJ without much trouble. Rent a car hauler from U-Haul instead of using a tow dolly.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
06-23-2007, 12:59 PM
tell the rental place it is for a CJ7 or XJ Cherokee...
06-23-2007, 01:02 PM
i pulled my j10 on a tow dolly with a dodge dakota 4x4 with no problem. heck i use my tow dolly to pull my j10 everywhere i wheel and i have never had a problem. it follows nicely.
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
06-23-2007, 02:22 PM
It would be about 40 slow miles...not much more. It's only another $10 or so for the whole trailer so I might go for that
 You know how I hate that hole in the driveway. Besides...it just feels weird driving around in a Chrysler instead of an AMC
06-23-2007, 06:31 PM
...dollied a Cherokee pulled by another Cherokee from Dallas to Green Bay. The towing vehicle was a 258/automatic. No problems except for one small jack knife on an icy patch in a parking lot. Did just fine on dry roads.
___________________________
J10 - Body channel (3 inch drop @ front); dechromed; shaved side parking lights, antenna, and hood trim bar. Ford mirrors, roll pans, side exhaust, 16 inch wheels, custom dash, new interior, Edelbrocked 360, HEI, T18/208 (J20), rear disk brakes, fifth wheel and bumper hitches.
06-23-2007, 07:32 PM
OK...next question
Would you disconnect the drive shaft or just leave it in neutral and close your eyes.
06-23-2007, 07:38 PM
Originally Posted by scantar
OK...next question
For the small effort it is to just take the shaft out I would go ahead and do it.
John
06-23-2007, 08:05 PM
BJ's Off-Road
For the extra $10, the auto transport is the best option. If you say that you are towing another FSJ, they won't rent it to you as the two vehicles are the same weight (a no no according to most insurance companies U-haul and others use). I typically say that I'm towing a 1987 Ford Escort. Make sure that you have the rig properly centered before taking off, as that will cause the most problems. If you don't know how to center one to distribute the weight properly, the guys at u-haul can give you a crash course (pardon the pun). The FSJ's are capable of towing that much and more, provided you use common sense. Don't try to win any land speed records, and give plenty of time to slow down. Oh, another benefit of the auto transports is that they have their own braking system, making it much easier to tow. I've towed around 12 or 13 FSJ's using the auto transport trailers with another FSJ doing the pulling, and never once had an issue. Oh, and if you use the big trailer, you don't need to pull a d-shaft.
BJ's Off-Road
ryan@bjsoffroad.com
06-23-2007, 08:48 PM
Steve, i have used a tow dolly to pull 3 waggies/ a m-715 and a j-10 with my cherokee with no problems. and a auto transport is about 3 times the weight of a dolly and if your not set up for elec brakes in your rig the less weight the better. 4 small bolts. pull the D . and load er up.
baybilly = dave
77 cherokee S ,parts
84 J10, parts
51 Willys
88 XJ, DD
1966 GT-350 mustang/ project
06-23-2007, 09:00 PM
BJ's Off-Road
dave, the auto transports now don't require your rig to have elec. brake set-up. They use a surge-system. Not the best, but definitely works well enough for the short drive he's using.
All this talk about trailers is making me want to get one! Maybe I'll beg to use GaWag's!
BJ's Off-Road
ryan@bjsoffroad.com
06-23-2007, 09:15 PM
Thanks for the input!
Sounds like a resounding...uh...either would work
Now if I can pry this Wagon away from the owner.....
06-23-2007, 10:36 PM
go get it, you no you want it  trailer/ dolly who cares. that oil spot in the drive way is fadeing out, it needs to be refreshed with a new leaker rig  red is on it's way mon.
baybilly = dave
84 J10, parts
51 Willys
88 XJ, DD
06-24-2007, 07:09 PM
Originally Posted by baybilly
...red is on it's way mon.
You da best, Dave. I don't care what Mike says about you!
06-24-2007, 07:18 PM
HAHAHA, wait a minute--------------------------- what he say
baybilly = dave
84 J10, parts
51 Willys
88 XJ, DD
06-24-2007, 07:23 PM
If you say a 87 Escort you might get a autotransport that is too small . . . don't ask me how I know that
I would say for a grand cherokee of an XJ or something of that sort.
