04-20-2007, 10:25 AM
trans temp sending unti
i want to install a transmission temperature sending unit do i install it before of after the cooler. Also did the rigs that came with the tow package have a seperate tranny cooler or was it incorporated into the radiator?
1976 Cherrokee 360 borgwarner with mile maker part time conversion. 7inch lift 33x12.50 baja claws howell fuel injection msd dizzy ignition headman headers 3in custom exhaust custom bumpers 12000lb mile marker wench
04-20-2007, 12:07 PM
If you want to install a trans temp sending unit, then one of the best mounting locations is the trans pan. That way you get accurate readings of the temp inside the actual trans. Many vendors out there sell trans pans with port/holes already pre cut for the installation of trans temp gauges and or drain plugs. Some have ports for both. Check around on the net and you will find companies that already make such items. I actually already have my trans temp and oil temp gauges installed but have not installed the sending units yet. I of course will be installing the oil temp gauge in the oil pan.
Upgrades
2. Cs-144 Alt 10/1/11
(Wip)
1. TBI
2. New fuel tank
3. AW-4 Transmission
4. Aluminum condensor
5. Custom Gauge Panel
04-20-2007, 12:09 PM
the extra tranny cooler was used a long with the one on the radiator on the tow rigs.
04-20-2007, 02:15 PM
I've always heard that you want to put the trans sender right at the output line on the tranny, that way you get the temp of the fluid coming right out of the tranny. The fluid in the pan is cooler because it just got back from a round trip to the radiator and trans fluid cooler if equipped.
Honey?? What happened to the savings account? You bought a Jeep what??
86 Grand Wag Stock with Bulltear HEI
04-20-2007, 07:09 PM
putting a gauge in the pan is more work than its worth to me if just looking for a ball park figure that being said what temperature range were these transmission desinged to run in?
04-20-2007, 08:18 PM
I don't remember where it's located but there is at least one test plug in the case of the transmission, usually near the pan rail. They are intended for diagnostic pressure testing but are usually the same size as the sending unit. Screw out the plug, screw in the sender. You can also put a "T" fitting in the cooler line. Pick a line. Some say to put it in the output line from the transmission. B&M recommends the return line but I don't know why.
Lou
04-20-2007, 10:31 PM
JAYRODOH has it right ... logic intimates that the hottest fluid will be coming OUT of the tranny towards any outside cooling sources and then back IN to the pan.
CHAZER didn't specify which tranny he is running so I'm not sure if his trans has this "test plug" that LOUM is referring to. I'd really like to know if the TH400 has one for sure. After suffering a trans fire once before I care NOT to go through that EVER again!!
Hi my name is Keith; I have Obsessive–Jeep Disorder (OJD) : a mental disorder characterized by intrusive thoughts that produce anxiety, by repetitive behaviors (buying parts and more Jeeps) aimed at reducing anxiety, or by combinations of such thoughts & behaviors such as but not limited to working on said Jeeps for extended hours.
04-21-2007, 09:09 AM
i think i have the t400 but not sure is there an easy way to tell?
04-22-2007, 02:10 AM
if it's stock and an auto it should be a th400 going by the jeep in the sig.
04-22-2007, 06:15 AM
chazer,
If its a T-400, the pan should look like the State of Texas (sorta). There is a test plu in the drivers side which is whre I plan to install mine.
Later.....
Eric
___________
Eric Terjesen
'78 Wag
'03 Silverado 2500 Tow rig
04-22-2007, 02:26 PM
 RIGHT AWN ... now thats easy to understand no nonsense information ... I just might be able to figure this out too.
