04-09-2007, 01:47 PM
King Browless
Rough Country Lift Kit: 3" or 4"?
When I purchased my '86 Wagoneer, the PO told me it was sporting a Rough Country Lift Kit.
I assumed for the longest time it was 4".
Now, I think maybe it is 3", but I am not sure.
My Question:
How do I tell if I have a 3" or 4" lift kit.
A person would think measuring it would tell, but measure it against what?
Would the springs have any markings or part numbers?
Would a 3" spring set have "x" number of springs and the 4" have "y" number of springs?
Would a 3" spring set be green with blue stripes and the 4" spring set be blue with green stripes?
BTW, it I had $$$ to burn, I would take that Rough Country Lift kit off and sell it for scrap.
It rides like a tractor, very stiff, very harsh, not kidney/back friendly.
Bryan Smith
1982 J10: Replacement engine now sitting in the truck! No Cab Brow! Future DD
Originally Posted by Jayrodoh
Originally Posted by Lindel
because Ristow sez so
When the IFSJA forum has a problem go here:
www.fsjnetwork.com
04-12-2007, 01:51 AM
dontcha just hate it when no one replies?
My RC lift springs in the front are pretty close to 3"
I say this based on the rear RC blocks measure almost exactly 3", and my rear springs sag just a tad... put it all together and my front is SLIGHTLY taller than the rear.
So Id say RC springs are pretty close to 3"
Im pretty sure all RC spring packs have 4 leaf springs in them (ive read this is why they are so stiff)
This is in a J10 with 258.
1982 J-10
1977 J-20 - 360 4bbl / Wagoneer Interior
1979 J-10 (Parts), 1983 J-20 (Parts), 1988 Grand Wagoneer, 82 J-10, 77 J-10
2006 Grand Cherokee DD
Webshots Photos
"The J-series Jeep pickups are simultaneously the ugliest and the most beautiful trucks ever made."
04-12-2007, 04:22 AM
 But are your springs blue with green stripes OR green with blue stripes.
Bryan ....If you made this a pole I would of sworn Derek posted this.
I would say if you measured it at ( X ) body location to the ground,, then have others check that measurement at same point to compare. Then take into fact their tire size, what state they live in and their waggy color, you should figure out what you have. You don't even have to crawl under it , or ask someone else to do it just to see what color the springs are.
Tom Gibson
1981 J-20 "RED" 360/727/208,R.I.P. Undergoing major retrofit to be a 1980 Utility truck.
04-12-2007, 06:23 AM
King Browless
1st Note to self: Create and post no Poles!
2nd Note to self: Thank close friends for keeping me straight
I thought about this.
You need to recall, the front of my Wag has been hit and was repaired.
When the springs were taken off and then replaced, I think the eye bolts were tightened to much.
I want to believe this one cause of my rough ride.
It sits a little tall in the front, so what I need to do, is loosen the bolts and jump on it or take it for a short slow drive,
to let the front springs work themselves back to their correct height.
So, measuring may not work for me.
Besides, this really no big deal if I have 3" or 4" of lift.
I am more curious than anything.
Talking to folks about the Dunes and having been up in the area recently, has gotten me thinking about all sorta of projects that will get me on the sand!
WhooHooooo!!
Bryan Smith
www.fsjnetwork.com
04-12-2007, 01:17 PM
The Rough Country lift is 3". I'm pretty sure they don't make a 4" kit. I had that lift for about 7 years. It softened up and flexed pretty good after a while.
04-12-2007, 03:05 PM
I guess I got the odd set of springs becuase they are one solid color: HOT PINK
1982 J-10
Webshots Photos
04-12-2007, 03:33 PM
King Browless
Somewhere along the line, I either read or was told that Rough County did not make a 4" kit, but I could not back this info up.
Nor could I find the source that told me RC did not make a 4" kit.
I suppose the next next question: How do I tell if the lift I have was made by Rough Country?
My thinking is, that if RC stamps their name on their products and they do not make a 4" kit, then I have by default a 3" kit.
If I have Budda's Brand stamped on it, then I am back to the question, 3" or 4".
When it warms up and after I loosen the front eyes bolts to let the front springs settle out,
I will need to drive to a level parking lot to measure, look for markings and take pics.
So, how long did it take for your springs to soften up?
10K mikes? 25K miles? 2 years?
What shocks did you use?
Did you use a drop pitman arm?
Bryan Smith
www.fsjnetwork.com
04-12-2007, 03:39 PM
King Browless
LOL! Odd is NOT the word I would use!
Do you have any of these hanging from your rear view mirror?
Bryan Smith
www.fsjnetwork.com
04-12-2007, 04:34 PM
No, that's the tow strap!
James
1988 GW stock (work in progress)
2003 GC Laredo (family car)
Thought it would be simple, forgot it was a Jeep.
