04-05-2007, 05:24 PM
bad idea vs worse idea
so me and this other guy were having a discussion, upon having a leaking head gasket. Neither of us feel like changing it on this car. the gasket is only bad on the outside, no anti-freeze has gotten into the oil yet. it only leaks in the front of the 4 banger. SO (A) buy a stop leak for the radiator or (B) buy an engine block stop leak. Or C other. The car we were talking about only has to last a couple more weeks and it's toast. so (A) raditor or (B) engine or (c) other? any thoughts.
04-05-2007, 06:51 PM
It only has to last a few weeks more eh? Then why not just hit it with A and B just to be sure  Should do the trick I'd think.
Hi my name is Keith; I have Obsessive–Jeep Disorder (OJD) : a mental disorder characterized by intrusive thoughts that produce anxiety, by repetitive behaviors (buying parts and more Jeeps) aimed at reducing anxiety, or by combinations of such thoughts & behaviors such as but not limited to working on said Jeeps for extended hours.
04-05-2007, 11:12 PM
Why bother with A, B or C? If it only has to last a couple of weeks, why spend money?
And yes, my tire is only flat on the bottom.
'77 J-10 '79 CJ-7
Arizona-The Rust Stops Here
04-06-2007, 05:10 AM
lots of H 2 O
04-06-2007, 05:17 AM
I seen a bottle of this black syrup stuff at Napa Auto that says it fixes coolant leaks...even head gaskets.
Larry
88GW "Mississippi" 401,Edelbrock heads,and stuff,
4" Skyjacker, BFG AT's,OBA,Air Horn.
'89GW "Mutt" wood for now, 360, 1405, Edelbrock cam,
4"Rusty's,3"body,33"BFG. Detroit Truetrack Warn Hubs
The Metal Workshop
http://www.themetalworkshop.com/index.html
04-06-2007, 08:07 AM
black pepper
Dan G
91 GrandWag
MSD Mag Dizzy, MSD 6A
04-06-2007, 10:28 AM
What about breakfast? You know, throw an egg in and season it with some black pepper.
Meg - 1979 Cherokee WT, 360(Freshly built- upgraded most everything in it)/T18/D20, 3" lift, 33x12.5 BFG All-Terrain KO T/A, D44/D44 Detroit TrueTrac
1976 Cherokee Chief - 360/TH400
1978 Cherokee WT - 360/TH400
1985 AMC Eagle 4x4 stationwagon
04-06-2007, 11:55 AM
Originally Posted by backpack09
black pepper
Hey Tommy, in case you think they're pulling your leg, see this thread:
http://www.ifsja.org/forums/vb/showt...t=black+pepper
Rick
84 Custom GW
360/727/208/d44f/AMC20r/3:31
Manual windows/locks/seats
04-06-2007, 12:07 PM
So if the car only has to last a couple more weeks, then why is it leaking a problem? Is it spewing coolant out or just dripping? Perhaps just spray it with some carb cleaner, wipe it down and slather some goop glue over it.
04-06-2007, 01:19 PM
thanks for the advice guys. wow i would have never guessed pepper.
04-06-2007, 01:24 PM
Old farmer trick. used to seal their tractor cooling systems that way.
If you only need it for a couple of weeks, then forget the sealants, just carry extra water in a jug.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
