Old 04-03-2007, 11:54 AM
gmarblestone's Avatar
gmarblestone gmarblestone is offline
Re-keyed or replaced?
i have a parts jeep with a key for all the doors. The jeep i want to have the key for i dont. Do you think it would be less to have a locksmith rekey them for the key i have OR should i remove the tumblers from one and install them in the other?
Thanks,
Grant
Old 04-03-2007, 11:57 AM
Free is free my friend...id swap em
Just to get my doors rekeyed was $20...woulda been $18 for the ignition
-Jon Barstow
1979 Cherokee Golden Eagle
360/TH400/D20
5" lift/33x12.5R15
Old 04-03-2007, 12:01 PM
well if its 20 i will do it.... but there are three right???
driver/passenger/tailgate... i have the ignition key...
how hard is the swap anyway?
60 is closer to not paying for it!
Old 04-03-2007, 12:56 PM
Tailgate and doors should be the same key. So just 2. The swap for the doors is as easy as can be. theyre just held in by clips, you dont even have to remove the door pannel...
-Jon Barstow
360/TH400/D20
5" lift/33x12.5R15
Old 04-03-2007, 01:06 PM
So if its that easy i will just swap em.... and leave the rear window or get it rekey'd eventually..
Thanks
G
Old 04-03-2007, 01:27 PM
for the rear window all you gotta do is remove the assebly, take a pin and push it in the hole on the housing, then push the tumbler out from the back.
-Jon Barstow
360/TH400/D20
5" lift/33x12.5R15
