Go Back   International Full Size Jeep Association > Tire Kickin' > Specialty FSJ Tech > Diesel Swaps
Old 03-24-2007, 11:00 AM
DieselSJ DieselSJ is offline
A little diesel porn for you all...
Some build pics to enjoy...
http://linderfamily.myphotoalbum.com...umName=album02
Mark
87 Grand, 6.5L diesel, MHI TE06H turbo, Detroit Diesel single plane intake, Art Carr 700R4, CS-130, hydroboost. 21/24mpg and an almost dead 229 (*&^%$# viscous) [208 on the way]
81 CJ5, Bowtie 350, T176, 30, 20, 300, small lift, 285/75/16 MTRs courtesy of Goodyear.
Old 03-24-2007, 11:09 AM
JeepBountyHunter's Avatar
GrimJeeperReaper
Nice, that's a lotta pic's...but I like it.
This thing runs good?
2007 Pontiac G6...Vrrooooom!!!! (Don't get one!)
1963 Jeep J200 Gladiator. 230 OHC, T90, D20.
Too many hobbies! $$$
Old 03-24-2007, 11:11 AM
Oh yeah. Go see my thread titled "22.4 mpg".
Mark
Old 03-24-2007, 11:15 AM
grand_wag_85's Avatar
Murphy's Law Poster Child
So you trailered the GW with the F150, then flat-towed a CJ-7 behind that?
Old 03-24-2007, 02:06 PM
Gadzooks2's Avatar
Gadzooks2 Gadzooks2 is offline
Hey Sparky, Is that a track bar on the front with Leaf springs?
How and why?
It's a driver side drop front end so it's newer than mine, but was that setup factory? Wouldn't the arc of the track bar push against the straight up and down motion of the leafs????
If it is factory maybe I could turn the bar around for my pass/side drop, build some mounts, toss the leafs and go 4-link/coil over like I've been dreamin about
PS. Great job keeping pics of the buildup. I'm really bad about that with all the projects I've done, now I wish I had more build up pics.
78' J-9, 96 XJ
Old 03-25-2007, 12:32 PM
CJ5. Nope, it got driven from San Diego to Phoenix when we moved. It was just parked behind the trailer in that picture.
Mark
Old 03-25-2007, 12:42 PM
How and why?
Driver's drop was factory from like 80- on. The track bar is also factory, and it has one on the rear also. Not sure how much it helps or hurts. With all that weight in the front it is kinda mushy. I do need to replace the bushings in the track bar as they are oil soaked and sloppy. I would imagine that they were trying to do something about the bump steer problem. Converting to coils has also crossed my mind - something like the setup from a new F250/350 with a simple set of arms and use the factory track bar. The factory frame mount for the track bar looks kinda whimpy though - I'm sure I'd have no problem tearing it off.
Back to the garage...since the Waggy isn't here to work on, I pulled the CJ into the garage and started a couple "small" projects and it has ballooned into rewire the engine compartment, install the serp belt setup, change motor mounts, trans mount, r&r oil pan and timing cover to fix an oil leak, etc.... I have pics of all this too. Funny thing - as I'm pulling some old wiring out I was thinking "who was the butcher that did this?"...oh, wait, it was me. D'OH! Now the engine compartment is looking much more like the work that I do.
Mark
Old 03-25-2007, 01:00 PM
Rogue's Avatar
Rogue Rogue is offline
thats a clean install Mark
ASE Master Auto Technician and full time auto enthusiast
Old 03-25-2007, 07:15 PM
shimniok's Avatar
shimniok shimniok is offline
Very nice!!
KØFSJ - 1986 Grand Wagoneer "Troubled Child" - tc.wagoneer.org - on facebook
Stock 360, 3" w/ Magnaflow, 727 with TransGo, NP208, 4" Skyjacker, 33" BFG MT, WT Axles, Lock Right & ARB, OBA
Jeep Status: Down for TBI Install
