Old 03-22-2007, 07:19 AM
86comanche 86comanche is offline
FSJ Leaf Spring Sizes (length, width and bushings)
I know I saw this somewher on her but i cant find it now after about a hour of searches. I was wondering if anyone knows where the list of sizes of spring for each FSJ is. Im looking for a chart showing the eye to eye dimensions and the widths and also the bushing sizes. I know it was on here that I saw this chart, but I cant for the life of me find it.
thanks
Jason
Last edited by Tad : 03-24-2007 at 08:06 AM. Reason: Title edited prior to archive move
Old 03-22-2007, 09:55 AM
I got the Willys....
Here is a cut and paste from a post made by Laher Spring Company on FSJN.
Wagoneers
"1962-73 Wagoneers use 22 x 22 x 2 1/2 inch front springs with 9/16 ID bushings on both ends, and 26 x26 x 2 1/2 inch rear springs with 7/8 ID bushings on the post and 9/16 ID bushings on the shackle.
1974-75 Wagoneers use 22 1/2 x 24 1/2 x 2 1/2 inch front springs with 9/16 ID bushings on both ends (the same as 1976 up), but 26 x 26 x 2 1/2 inch springs on the rear (the same as 1962-73). The kicker on the rear springs is that they have a 1 inch post mount instead of a 7/8 inch like the 62-73's - same spring - different bushing. The shackle bushing is the same 9/16 inch ID.
1976 and up Wagoneers use the 22 1/2 x 24 1/2 x 2 1/2 inch front spring with 9/16 inch bushings on both ends, and a 26 x 31 x 2 1/2 inch rear springs with 9/16 inch ID bushings on both ends. "
Trucks
"1962-69 trucks use 22 x 22 x 2 inch front springs with 7/8 inch post mounts and 9/16 inch shackle bushings, and 26 x 26 x 2 1/2 inch rear springs with a 7/8 post mount and 9/16 shackle bushings.
1970-73 trucks with a 119" wheel base use the same front spring and the 26 x 26 x 2 1/2 inch spring with a 1 inch post mount and a 9/16 inch shackle bushing.
1970-73 trucks with a 131" wheel base use the same front spring but a 26 x 31 x 2 1/2 inch rear spring with a 1 inch post mount and a 9/16 inch shackle bushing.
1974-75 trucks with a 119" W.B. use a 22 1/2 x 24 1/2 x 2 1/2 inch front spring with 9/16" bushings on both ends, but a 26 x 26 x 2 1/2 inch rear spring with 1 inch post mount and a 9/16 inch shackle bushing.
1974-75 trucks with a 131" W.B. use 22 1/2 x 24 1/2 x 2 1/2 inch front springs with 9/16 inch bushings on both ends and 26 x 31 x 2 1/2 inch rear springs with a 1 inch post mount and a 9/16 inch shackle bushing.
All 1976 and up trucks use 22 1/2 x 24 1/2 x 2 1/2 inch front springs with 9/16 inch bushings on both ends and 26 x 31 x 2 1/2 inch rear springs with 9/16 inch bushings on both ends.
All of this assums that your truck has rubber factory bushings. If your truck has brass bushings, well, that's another ball game. It seems as though the Jeep engineers set out to drive the aftermarket guys crazy. "
There is a good chance that your truck has brass bushings. According to Jeep the HD trucks got them, and your 7,000lb GVW truck would be considered a HD model. Jeep has been known to be wrong though. Best off to check and be certain.
1971 Gladiator
Old 03-22-2007, 10:33 AM
scantar's Avatar
scantar scantar is offline
That's an archiver fer sher...
Old 03-22-2007, 10:50 AM
thanks again
Old 06-02-2010, 06:34 PM
From Tom at Hell Creek:
J-20 rear springs (and some J-10 rear springs) measure 25-1/4" on the front of the spring and 31-3/4" on the rear of the spring. We make ours 26 x 31 to move the wheel a little rearward in the wheel well. Chevy 3/4 ton springs measure 26 x 30, so they are 1" shorter on the shackle end, which would account for the shackle angle. Moving the center pin on a 57 inch spring 3/4" to the front of the spring would have no effect on the shackle angle - just on the spacing of the tire in the wheel well.
-Tom
Old 09-08-2011, 05:26 AM
http://littlekeylime.com/MrN/mrnimages/leaf_springs.png
