03-08-2007, 07:39 PM
www.Bulltear.com Chief
Bulltear Industries-New Items Added
 Thats right guys we sent the knobs all the way to the right and some fool ordered two times the material we needed so we have roughly 150 #626 plates to blow out. Here is the final draft and what they look like and a description.
"626 replaces the oil filter adaptor and does away with the oil filter bypass while retaining the pressure bypass spring and plunger. This plate has generous .704" through hole for maximum oil flow to and from remote oil filter adaptors, oil coolers...ect. Tapped to a 1/2-14 NPT on the "in" and "out" of the plate. Fits all AMC 67-91 and we also offer this in kit form with hose, fittings and remote oil filter adaptor (we also offer dual filter adaptors and oil coolers, see store for details).
This plate features marked engraving for easy hook up of oiling lines.
$85 shipped
We take paypal using jeepsr4ever@yahoo.com or money orders to
Bulltear ind
30401 Neal ave
Lindstrom MN 55045
AMC/Jeep Forum
03-12-2007, 03:30 PM
Reman Edelbrock carbs with offroad seats $230 shipped
Thats right we have hundreds of these Edelbrock carbs for sale. These are remanufactured, pressure tested, flow tested and guaranteed to work perfectly. Each on comes with offroad needles and seats installed, gaskets and a instruction booklet. $230 shipped ea (choose either 600cfm or 750cfm)
Each carb will have an electric choke unless you specify other.
We take paypal using jeepsr4ever@yahoo.com as the payee or money orders to
Bulltear ind
30401 Neal ave
Lindstrom MN 55045
oops
AMC/Jeep Forum
03-13-2007, 08:32 AM
We also make 8qt oil pans as well. These pans are Yellow zinc plated and feature a 2 stage baffle design. Check our webstore for pricing www.Bulltear.com
AMC/Jeep Forum
07-31-2007, 09:02 PM
HUGE TOW HOOKS!!!!
These are from Sterling truck chassis!
This is the bad boy of tow hooks! Features a bolt pattern of 4 3/16"s uses a 3/4" bolt for the first hole and a 5/8" bolt for the second. These are found on firetruck chassis and 10-40 ton chassis, definately a great upgrade!! Sold in black only.. 9LBS ea
$22 ea
Quick link.. http://www.bulltear.com/catalog/prod...roducts_id=152
AMC/Jeep Forum
08-17-2007, 01:19 PM
This just in for engine builders
Perfect for testing block bore thickness, for extreme head porting or finding tube and frame thickness. These Ultrasonic thickness testers are one of the ultimate tools to have. Never before have they been this affordable. This testing unit measures the thickness of virtually any part and any shape.
Main Processor with Calibration block (5.0 mm) Standard Probe: end diameter: 8mm for measuring range of 1.20 - 200 mm, or 0.047 - 7.874 inch, display in both mm and inch. A Bottle of Coupling Paste Operation Manual Carrying Case Features
This unit is a handheld microprocessor-controlled ultrasonic thickness gauge specifically designed to measure the thickness of metallic and non-metallic materials e.g. aluminium, titanium, plastics, ceramics, glass, plastics including rubber and other good ultrasonic wave conductors, as long as they have parallel top and bottom surfaces. With applications in many areas of industry, this unit can perform precise measurements on various types of raw materials, components, parts and assembled machinery. It can also be used to monitor all types of pipes and pressure vessels for loss of thickness due to corrosion or erosion. This unit is easy to use and, after a simple calibration to a known thickness or sound velocity, the gauge will give accurate readings to an accuracy of 0.5%.
Sound velocities for 11 different materials can be pre-set and thickness readings can be stored in the memory and downloaded via the optional RS232c output.
The microprocessor allows fast data acquisition and analysis. This new tester features a wide measuring range, high accuracy, ease of operation, low power consumption (Four 1.5V AAA batteries), and convenient data display.
Metal Materials: Al, Fe, Stainless Steel, Cu, Brass, Zn, Ag, Au, Sn,.... Acrylic Resin, Water Glass, ... Other materials with known sound velocity values. Specifications
Measuring method: Ultrasonic pulse echo Measuring frequency: 5MHz Measuring range: 1.2 - 200.0 mm or 0.047 - 7.874 inch (steel); Actual range varies with the types of material measured Accuracy: +/- (0.5%H ± 0.1) mm Sound velocity range: 500 - 9,000 m/s 4 digit large LCD display (in both mm and inch) Automatic power-off after being idle for 4 minutes Probe contact indicator Resolution: 0.1mm or 0.001 inch Working temperature: 0 ºC ~ +50 ºC Communication between tester and computer via RS-232 port (optional) Size: 120mm x 62mm x 30mm (4.72 in X 2.44 in X 1.18 in) Power supply: Battery: Four AAA alkaline batteries (total 6.0V) Weight: 160g (main unit); 40g (probe)
AMC/Jeep Forum
08-17-2007, 07:11 PM
We now offer replacement small chamber heads, single rocker and ported Edelbrock cylinder heads!
http://www.bulltear.com/catalog/index.php
AMC/Jeep Forum
09-06-2007, 06:56 AM
The future of AMC oiling is about to change
AMC/Jeep Forum
09-12-2007, 12:35 PM
Coilovers at Bulltear
We are offering coilover shocks from Radflo and coils from QA-1 as of 9-4-07. Pm me on pricing and application.
Shocks from 2" to 2.5" up to 16"s of travel and up to 7/8" thick chromed hardened steel shaft.
Coils from 1.75"-4.50" Inside diameter and rates from 45 to 400lbs and lengths from 6" long to 14"s long.
AMC/Jeep Forum
09-12-2007, 01:57 PM
http://www.bulltear.com/catalog/images/groover.jpg
This is the tool for serious tire grooving. Whether your taking a 1" wide by 1" deep cut on your boggers to get ultimate traction or regrooving your trail tires with 1/16" wide cuts this tool is the top dog! Far superior to other types of tire grooving tools this *patented tool quickly removes material easily. Rework or groove your new tires this groover will eat them up like its cutting butter! Fast, smooth, uses less heat and is precise.
PM ME FOR A PRICE
AMC/Jeep Forum
09-14-2007, 08:21 AM
Pullies to 50% underdrive! Up to 3 groove for stock AC!
AMC/Jeep Forum
10-09-2007, 12:31 PM
-edit
AMC/Jeep Forum
10-16-2007, 11:01 AM
.007" oil pump gaskets back in stock in two weeks!
AMC/Jeep Forum
10-22-2007, 08:18 PM
BACK IN STOCK!
AMC/Jeep Forum
10-31-2007, 08:42 AM
.007" oil pump gaskets back in stock!
AMC/Jeep Forum
02-23-2008, 06:03 PM
We are proud to announce our .000 timing covers. These covers are alignment pin tested, tested for proper distributor/camshaft gear alignment, setup on a block for proper height and also checked in one of our CNC's. If your looking for a timing cover/oil pump or are have had issues with aftermarket replacements let us know we can definately help you out!
AMC/Jeep Forum
03-09-2009, 09:13 AM
We make both press on and bolt on (keyway) for the 2 groove or 3 groove water and crank setup. We also do custom pullies in any diameter or over-under drive you want.
More options added very soon
http://www.bulltear.com/catalog/prod...roducts_id=226
AMC/Jeep Forum
