Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Commercial Vendors:
Old 11-12-2007, 11:30 AM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Thank you Sir!
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 11-28-2007, 09:33 AM
TPICherokee's Avatar
Cool
BJ's Off-Road has added some new parts recently:
1963-1973 J-truck lift kits:
http://www.bjsoffroad.com/cartgenie/...lag=3&brand=48
TT's Fabworks Steering Box Brake:
http://www.bjsoffroad.com/cartgenie/...pid=889&cid=13
Robertshaw High Flow Thermostats:
http://www.bjsoffroad.com/cartgenie/...pid=890&cid=17
Genuine Gear Dana 44 Gear Sets:
http://www.bjsoffroad.com/cartgenie/...?pid=898&cid=7
Genuine Gear Installation Kits:
http://www.bjsoffroad.com/cartgenie/...?pid=899&cid=7
Staun Internal Beadlocks:
http://www.bjsoffroad.com/cartgenie/...pid=891&cid=29
Staun Automatic Tire Deflators:
http://www.bjsoffroad.com/cartgenie/...lag=3&brand=49
MAX AX Multipurpose Tool:
http://www.bjsoffroad.com/cartgenie/...pid=896&cid=30
Pro Comp X-Wrench Tire Wrench:
http://www.bjsoffroad.com/cartgenie/...pid=897&cid=29
More coming soon!
Old 12-29-2007, 05:06 PM
Cliffhanger Rear Bumper with Swingout Spare Tire Carrier NOW AVAILABLE!
Here it is, this is much more heavy-duty than all previous model. This is very cool:
http://www.bjsoffroad.com/cartgenie/prodInfo.asp?pid=500&cid=20
Thanks!
Old 02-06-2008, 09:50 AM
Cool Lots of New Parts Added!
700R4 to Quadratrac Adapter:
http://www.bjsoffroad.com/cartgenie/...pid=920&cid=25
AMC 20 Heavy Duty Differential Cover 3/8" Cast Steel:
http://www.bjsoffroad.com/cartgenie/...?pid=932&cid=7
Mallory HEI Distributor:
http://www.bjsoffroad.com/cartgenie/...pid=926&cid=12
Frame Repair Kits:
http://www.bjsoffroad.com/cartgenie/...?pid=933&cid=8
Old 08-07-2008, 09:39 AM
APPAREL ADDED!
We added a bunch of shirts and hats and stuff:
Shirts, Hats and Sweatshirts:
http://www.bjsoffroad.com/cartgenie/...st.asp?scat=13
Old 08-07-2008, 09:42 AM
Cool Jeep License Plates Added!
Jeep License Plates:
http://www.bjsoffroad.com/CartGenie/prod-925.htm
Jeep Parking Sign:
http://www.bjsoffroad.com/CartGenie/prod-931.htm
Old 02-13-2009, 07:28 AM
Electric Fan Kits for Aluminum Radiators!
These are really, really cool (no pun intended):
http://www.bjsoffroad.com/CartGenie/prod-934.htm
Thanks!
Old 02-13-2009, 07:30 AM
Dakota Digital Dashes!
Here is the 1973-85 Dash:
http://www.bjsoffroad.com/cartgenie/...pid=756&cid=12
Here is the 1986-91 Dash:
http://www.bjsoffroad.com/cartgenie/...pid=757&cid=12
Old 02-13-2009, 07:32 AM
New Parts Added!
Pro Comp Mud Terrains
http://www.bjsoffroad.com/cartgenie/...pid=936&cid=29
Dana 44 Spindle Bearing Kit:
http://www.bjsoffroad.com/CartGenie/prod-937.htm
Disc Brake Hardware Kit:
http://www.bjsoffroad.com/CartGenie/prod-942.htm
J-20 Rotor and Hub Assembly:
http://www.bjsoffroad.com/CartGenie/prod-941.htm
1976-1979 Y-Pipes Added:
http://www.bjsoffroad.com/CartGenie/prod-943.htm
Vinyl Flooring with Different Colors Added:
J-truck:
http://www.bjsoffroad.com/CartGenie/prod-945.htm
Wagons:
http://www.bjsoffroad.com/CartGenie/prod-944.htm
Interior Bulbs
Courtesy Light Bulbs:
http://www.bjsoffroad.com/CartGenie/prod-940.htm
Map Light Bulbs:
http://www.bjsoffroad.com/CartGenie/prod-939.htm
Dome Light Bulbs:
http://www.bjsoffroad.com/CartGenie/prod-938.htm
Old 05-03-2011, 07:51 AM
Lots of new parts added in the last 2 years!!
ECTED lockers are electrically actuated but when they are not locked, they act as a limited slip!
AMC 20 ECTED:
http://www.bjsoffroad.com/CartGenie/prod-973.htm
Dana 44 ECTED:
http://www.bjsoffroad.com/CartGenie/prod-975.htm
Hi-Lift Accessories Added:
http://www.bjsoffroad.com/cartgenie/...t.asp?scat=144
Old 05-03-2011, 07:52 AM
We now have Mickey Thompson MTZ Tires:
http://www.bjsoffroad.com/CartGenie/prod-985.htm
BF Goodrich KM2 Tires
http://www.bjsoffroad.com/CartGenie/prod-988.htm
Also, if you would like a tire or wheel that we don't have listed, let me know and I'll get you a price for it.
Old 05-03-2011, 07:54 AM
Adjustable Proportioning Valves
http://www.bjsoffroad.com/CartGenie/prod-986.htm
Hubber Tool
If your Warn Premium Hubs are hard to turn, these give you a handle and make it easy!
http://www.bjsoffroad.com/CartGenie/prod-987.htm
Old 05-03-2011, 07:55 AM
Chevy V8 to Jeep Automatic Transmission Adapters:
This is great for those of you who want to run your stock AMC transmission behind a Chevrolet V8:
TH400 Adapter:
http://www.bjsoffroad.com/CartGenie/prod-995.htm
TF727 Adapter:
http://www.bjsoffroad.com/CartGenie/prod-994.htm
Howell Fuel Injection Kits:
One is emissions and CARB legal, the other is not:
http://www.bjsoffroad.com/CartGenie/...lag=3&brand=56
Old 05-03-2011, 08:22 AM
1963-1973 Disc Brake Conversion:
This kit is a complete kit to convert your stock front drum brake axle to disc brakes!
http://www.bjsoffroad.com/CartGenie/prod-967.htm
We have fuel fill hoses for 63-77 J-trucks and 78-88 J-trucks (78-79 front fill only).
The 1963-1977 is here:
http://www.bjsoffroad.com/CartGenie/prod-1020.htm
The 1978-1988 is here (78-79 front fill only):
http://www.bjsoffroad.com/CartGenie/prod-1019.htm
Old 05-03-2011, 08:26 AM
Grand Wagoneer Logo Option Added on Floor Mats:
Floor Mats:
http://www.bjsoffroad.com/CartGenie/prod-196.htm
We now have chromoly axle shafts made by Dutchman!
Inner Shafts:
http://www.bjsoffroad.com/CartGenie/prod-1022.htm
Outer Shafts:
http://www.bjsoffroad.com/CartGenie/prod-1023.htm
All made in the USA, all custom built! We have 99% of all measurements so you just need to tell us your vehicle and we would have your axles in stock in about a week!
Dana 44 Small Parts:
Need small parts for your Dana 44? We have a lot of them here now:
http://www.bjsoffroad.com/CartGenie/prod-1029.htm
All parts are Dana Spicer parts.
Note: not all number are available but most are. Just click the webstore link and you can see what is available.
Complete Polyurethane Bushing Kits:
http://www.bjsoffroad.com/CartGenie/prod-1035.htm
Buick 350 Engine Parts Added:
http://www.bjsoffroad.com/cartgenie/...st.asp?scat=29
Powermaster Alternators and Starters Added:
http://www.bjsoffroad.com/cartgenie/...lag=3&brand=61
Old 05-03-2011, 08:29 AM
Dome Light Assemblies:
1963-1978 Wagoneer and 1974-1978 Cherokee:
http://www.bjsoffroad.com/CartGenie/prod-1056.htm
1963-1988 J-truck:
http://www.bjsoffroad.com/CartGenie/prod-1057.htm
Vent Window Division Bars Added:
These are for the front edge of the front roll-up window.
http://www.bjsoffroad.com/CartGenie/prod-1058.htm
LubeLocker Differential Gaskets:
These Lube Locker Gaskets are a reusable gasket and are very cool:
Dana 44:
http://www.bjsoffroad.com/CartGenie/prod-1086.htm
Dana 60:
http://www.bjsoffroad.com/CartGenie/prod-1087.htm
Old 05-03-2011, 08:36 AM
fullsizejeepfreak's Avatar
fullsizejeepfreak fullsizejeepfreak is offline
Thanks
Regardless of my problems with the delayed shipping and not having been offered the discount, everything I bought from you fit and functioned perfectly. I am thrilled with the performance of the Howell TBI, the HEI, the aluminum radiator is great, etc. The overflow tank "teeters" back and forth a bit, but nothing that can't be fixed with a 3rd mount tab. Thanks for carrying quality parts to keep our rigs alive! Mine now feels like it's had multiple organs replaced and is lovin it.
87 grand waggy (wife's DD) 360, hei w/ msd 8.5 wires, alum. radiator, doug thorley tri y's, Howell tbi/edelbrock performer, Duratrac 31's
96 F350 460 mpfi ZF 5 speed 1 ton dually 4x4 hankook dyna pro studdables mild lift (my DD)
Old 05-03-2011, 09:04 AM
A Bunch of AMC Engine Parts Added:
Transdapt Slam-Guard Oil Pan:
http://www.bjsoffroad.com/CartGenie/prod-1088.htm
Polished Finned AMC V8 Valve Covers (decals sold separately - see below):
http://www.bjsoffroad.com/CartGenie/prod-1089.htm
Black Powdercoated Finned AMC V8 Valve Covers (decals sold separately - see below):
http://www.bjsoffroad.com/CartGenie/prod-1090.htm
Decals for Valve Covers:
http://www.bjsoffroad.com/CartGenie/prod-1091.htm
Old 05-03-2011, 09:05 AM
I am glad we could help out. Hopefully you are set up for the discount now, if not, let me know.
The best upgrades I have ever done to an AMC V8 are the HEI and the Howell, it makes it feel like a completely different animal.
Old 05-03-2011, 09:09 AM
Teraflex Dana 20 TeraLow Low Range Kits:
We have both kits, one for a Manual and one for an Automatic:
http://www.bjsoffroad.com/CartGenie/...lag=3&brand=65
Posi-Quiet Brake Pads:
Semi Metallic:
http://www.bjsoffroad.com/CartGenie/prod-1081.htm
Ceramic:
http://www.bjsoffroad.com/CartGenie/prod-1080.htm
Stage 8 Locking Spindle Nut System:
http://www.bjsoffroad.com/CartGenie/prod-1082.htm
CTM U-Joints:
We now carry CTM ujoints that replace the 5-297x and the 5-760x u-joint:
http://www.bjsoffroad.com/CartGenie/prod-1083.htm
CSI Winches:
These are a great winch for the money and come with a 1-year warranty!
http://www.bjsoffroad.com/CartGenie/...lag=3&brand=68
