Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Customer Corner: (Vendor product discussions)
Old 02-20-2007, 04:13 PM
jlewis's Avatar
jlewis jlewis is offline
Questions on a BJ's offroad 6 in lift kit
When I install a6in lift will I need to buy anything else or is the lift package complete to make a successful lift. Will my stock drive shaft or Steering need to be extended?
Old 02-20-2007, 05:05 PM
AMX factor's Avatar
AMX factor AMX factor is offline
I didn't have to adjust driveshaft or steering when I did mine. You will have to put new u-joints in it as the driveshafts will be operating at different angles. The kit has everything you need, unless you order it without shocks. I was very satisfied with the 6" kit I had. When I build another FSJ I'll buy another.
"I'm sick of this sickness, don't touch me you'll get this."
1984 GWag "orphan" for sale
2 x 1975 Matador "murder machines"
1970 SST390 Javelin 10 yr project!
Old 02-20-2007, 05:35 PM
jlewis's Avatar
how do you know what U-bolt to get? do you have a part number or info on the one you got?
Old 02-20-2007, 07:48 PM
Ghinmi's Avatar
Ghinmi Ghinmi is offline
Mine came with u-bolts.
1976 Wagoneer - Just an 11 second street car
1983 Cherokee WT - IFS, trailing arm rear, full cage, turbocharged AMC 429
http://www.cardomain.com/id/Ghinmi
Old 02-20-2007, 08:06 PM
shackwrrr's Avatar
he meant u joint. howd he change ujoints to get more angle.
Jeepless
In to Turbo crap now
Old 02-20-2007, 08:10 PM
nsanebiker's Avatar
nsanebiker nsanebiker is offline
Just get the replacement U-Joints from NAPA/Autozone/Parts+ etc..
James
1973 J4000 Custom Cab: 360/T18
My DD: DOZERCON
2012 Jeep Wrangler Rubicon Unlimited
Old 02-20-2007, 08:19 PM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
our full kits include the u-bolts. If you order springs separately and u-bolts separately, we'll determine the right size u-bolts based on the year / model rig you have.
BJ's Off-Road
ryan@bjsoffroad.com
Old 02-20-2007, 11:05 PM
jlewis's Avatar
I am a freaking dumb$$$. I meant U-joint.
Old 02-21-2007, 10:01 AM
billyrb's Avatar
BJ's Off-Road
ah, agreed
U-joints can be standard Spicer replacements from any Napa auto parts store. Stock is 1310 series.
BJ's Off-Road
ryan@bjsoffroad.com
Old 02-21-2007, 12:26 PM
kennyh's Avatar
kennyh kennyh is offline
Why wouldn't original u-joints be fine? Yeah, if they're almost shot they'll go away quickly, but if they're not new but intact they'll have some more good miles on 'em. I'd just buy a set and have 'em in the toolbox. They oughta be in there anyway.
KennyH '74 Wag, '80 Wag Brougham, '98 GC 5.9 Limited. Life is hard. It's harder if you're stupid.
Old 02-21-2007, 02:14 PM
billyrb's Avatar
BJ's Off-Road
you don't have to replace them when you install our lifts (as in, it isn't required).
BJ's Off-Road
ryan@bjsoffroad.com
Old 02-22-2007, 02:16 PM
FSJ-Earl's Avatar
FSJ-Earl FSJ-Earl is offline
Why would you need to replace the u-joints unless they are worn out? They will wear slighly faster due to the increased angle, but they don't need replaced as part of the lift.
FSJ-Earl
