where to find stuff to finish 360??
I am on the downhill slope finishing the 360 rebuild in my GW (fire loss). I only need (think I need) a few more things and I’ll be done. My problem is finding what I need, and I thought you all could HELP.
First thing I need is a new distributor drive gear (the one on the cam) cus although I have two used gears, I bought a new dizzy and have been told the drive and driven gears need to be replaced at the same time. Auto parts counter jockey says they are listed as obsolete and can’t be had??????
Next, is for the vacuum advance I need (per the diagram) two spark advance vacuum delays and a nonlinear valve. Where can they be found????
And for the evap system, I need the vapor separator that comes off the carbbowl vent and goes to both the charcoal can and the pcv inlet on the carb.
Any suggestions would help.
Ben
1988 Jeep Grand Wagoneer (rebuilt)
2003 Jeep Wrangler Rubicon (built)
1998 Dodge Ram 3500 diesel dually 4x4 (tow rig)
