Old 01-31-2007, 10:24 PM
Chrome's Avatar
Chrome Chrome is offline
Ph.D in Redneckology
Build your own door & interior panels
If you want to replace those worn or rotted interior door panels and rear quarter interior panels then here's a cheap way to.....Git-R-Done. You will need a sheet of 1/8" thick fiberglass, like the kind used to underpin mobile homes and subframe houses, a hot glue gun, a pack of hot glue sticks, and the material you entend to use to cover the panel with (preferably marine grade vinyl). Tools that are required are a jigsaw with a fine cut blade, a drill with assorted bits, and a black Sharpie.
Remove your old panel and remove any pieces that will keep it from laying flat on the fiberglass board. Now line up any square edges with the straight edge of the FG board then trace a outline of the old panel onto the FG board. Carefully cut out the pattern and then test fit it to the door/quarter that it will be attached to. Keep in mind the trim piece at the top of the door that the factory panel slides under and allow enough excess to fit back under it. Make sure not to leave any sharp edges on the FG board because this will cause premature splitting of the vinyl.
Once you have the desired fit you will need to go back and mark any holes that need to be cut into the FG board like speakers, door handle, window crank, power switches, arm rest, ash tray, etc. BE SURE TO MAKE THE HOLES THAT THE DOOR CLIPS FASTEN THRU TO HOLD THE PANEL ON. YOU CAN USE THE PLASTIC TYPE LIKE USED ON NEWER MODEL VEHICLES. THESE CAN BE FOUND AT MOST PARTS STORES. If you are adding something that was not orginally in the panel like speakers make sure the location you pick on the board will match the body of the vehicle and not be in the way of a lowered door glass or wheel well.
Now that you have your pattern finished double check to make sure it is clean of FG shavings or any type of trash that will show up on the finished product. Also, if the FG board has one side that is smoother than the other then it's best to use the smoothest side.
Take the material you plan to cover it with and stretch it out over the board. You will need to leave a 1 1/2 inch excess around the outside edge this will be used to glue the material to the board. Once you have the material trimmed flip the material up side down and place the board down on top. MAKE SURE YOU HAVE THE RIGHT SIDE OF THE BOARD FACING DOWN ON THE MATERIAL OTHERWISE YOU JUST MADE A SPARE. Take the hot glue gun and make a bead across the top edge of the board then pull the material over and press it down. This may take a few minutes of rubbing to get the material to stick but once the glue cools it will stick. Now gently pull out any wrinkles in the material and place a bead of hot glue along the bottom edge and lay the material over it making sure you do not leave wrinkles in the material. You can gently move the material if needed just don't try to give it a hard pull. Once the bottom has cooled double check the covered side to make sure everything is looking smooth. Now do the sides the same way. On the rounded edges you will need to make relief cuts on the back side so that the vinyl will not crease on the top side. This can be done by cutting a straight line from the outside edge of the vinyl inward towards the FG board edge and stopping at least a 1/4 inch from the edge where it wraps over to the top side.
Once the material is in place go back and take a new razor blade and cut out the holes that you made in the FG board. Be sure to put a small amount of hot glue under the edge of the cuts to help hold them flat. THERE IS NO NEED TO PUT ADHESIVE SPRAY ON THE COVERED SIDE OF THE BOARD. THE GLUED EDGES WILL HOLD THE MATERIAL IN PLACE.
Now place the newly covered panel on stand back and admire a job well done!
BEFORE:
AFTER:
..,=====,o00o
//__l_l_,\____\,__
l_---\_l__l---0
lllllll0
_(o)_)__(o)_)--o-)_)___
Old 01-31-2007, 10:27 PM
you had to know this was coming
Old 01-31-2007, 10:44 PM
Yea! Sounds like youve done this before...
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 01-31-2007, 10:50 PM
Chrome's Avatar
LOL After all that typing I wanted to make sure I had it posted before I started transfering pics. The way my luck goes I would hit the wrong button and lose everything then it would be a trip to the doc for a case of Carpel Tunnel.
..,=====,o00o
//__l_l_,\____\,__
l_---\_l__l---0
lllllll0
Old 01-31-2007, 11:34 PM
hey,that looks pretty dang diddly-doo-darned good!
sorry,the ned flanders in me came to the surface for a sec there.
Old 01-31-2007, 11:41 PM
etjeep's Avatar
etjeep etjeep is offline
Nice job....
Later.....
Eric
___________
Eric Terjesen
'78 Wag
'03 Silverado 2500 Tow rig
Old 01-31-2007, 11:54 PM
OH man I have been there LOL or switch sites to get corroborating evidence to prove your point and forget that what ever you typed won't be there when you get back
Old 02-01-2007, 06:13 AM
DAHoyle's Avatar
DAHoyle DAHoyle is offline
Yeah, looks ok, but what was wrong with the old ones? JK
67 M715
Old 02-01-2007, 06:30 AM
OBX-AUTOMOTIVE's Avatar
OBX-AUTOMOTIVE OBX-AUTOMOTIVE is offline
GRUMPY
YOU DO NICE WORK...I REMEMBER THAT POST FROM BEFORE...LIKE TO WORK WITH YOUR HANDS?...WOULD YOU LIKE TO BUY A FLOOR/PAN EMPIRE?
jeepfan93's Avatar
jeepfan93 jeepfan93 is offline
Hey Scott, only thing I would add is that you may want to use spray adhesive unless thos chrome srtip are going thru and also holding it down. When I used to work in the boat industry, we made our own panels, and lemme tellyou, when that sun warms up the vinyl, it will unloosen, (melt) the hot glue causing things to start popping off.
Looks great though, I'm gonna make panels like that for my 715 soon.
Jeeps are Jeeps, keep Jeepin
>It's not about the ten hour drive to get the rust bucket jeep, it's about where your your going when it's done
87GW 99 Durango 5.2 drivetrain, SOA 35in Falken Wildpeak. MT rims
1997 Ram 1500 5.2 33in Falken Rocky Mounts for haulin
Old 02-01-2007, 07:14 AM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Good write-up Scott, but where can I get sheet fiberglass?
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 02-01-2007, 07:18 AM
What he said and NICE JOB!!!
-Jonny B.
Old 02-01-2007, 07:48 AM
gmarblestone's Avatar
gmarblestone gmarblestone is offline
Agreed, i will be venturing here soon!
Old 02-01-2007, 08:09 AM
janie's Avatar
janie janie is offline
Dexron Impaired
Awesome work Cuz!
Old 02-01-2007, 08:54 AM
Bama Burden's Avatar
Bama Burden Bama Burden is offline
sha-zayum! any solutions for my POS armrests?
Old 02-01-2007, 12:28 PM
goldhammer's Avatar
Check with the bigger building supply places for the panels. They are available for bathroom walls in 4x8 sheets.
Art
ASE Master Collision Tech
Old 02-01-2007, 12:34 PM
chrisnsarah's Avatar
Are you referring to FRP (fiberglass reinforced panel)? It pretty good stuff and I see where it would work. There is also a polypropylene sheet available that is practically indestructible, but I don't think the big box stores will have it.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Old 02-01-2007, 12:39 PM
67Wagoneer's Avatar
67Wagoneer 67Wagoneer is offline
Looks awesome!
The fabric on my panels is still in good shape, but the boards are warping.
Thanks for the tip!
-Steve-
FSJ's owned:
1967 Wagoneer Custom 327 4bbl 3-speed (my pride and joy!)
1968 Wagoneer Standard 327 4bbl 3-speed (RIP )
1984 Grand Wagoneer 360 with all the toys
Backup: 2015 Patriot. Not really a Jeep but it's cute.
http://fsjworld.tenmagazines.com/gal...e327/82132.jpg
Old 02-01-2007, 12:51 PM
goldhammer's Avatar
I'm pretty sure it is the FRP stuff. Been about 15 years since I was in the floorcovering business and saw it at a show and in our catalogs. If you go to a major store restroom you will probably see it on the walls. Usually a pebble finish, but the back side is smooth IIRC
Art
Old 02-01-2007, 02:19 PM
Chrome's Avatar
That's it. Some of the supply stores in my area call it canidate sign board since everyone running for office like making signs out of it.
..,=====,o00o
//__l_l_,\____\,__
l_---\_l__l---0
lllllll0
