Old 11-15-2006, 09:38 PM
blakeusa's Avatar
blakeusa blakeusa is offline
FSJ Wiring Harness Recommendations??
Looking for recommendations on replacing the dash and engine wiring harness in my 71 J4000 w/ AMC 401, & electronic ignition.
Painless makes a waterproof unit 12 circuit, but the price is PAINFUL around $400. Universal units are still 300-$400. Z&M seems to make one for newer FSJ's, but again seem to be more universal??
No plug in solution yet???
Are they worth the money for the reduced install or hassle time?
How long does it take a mortal to install?
Recommendations please?
Thanks, Blake
1971 J4000 Gladiator w/AMC 401 Restoration Project
Old 11-15-2006, 09:52 PM
I just did a re-wire job with a universal harness. Check out the thread here:
http://www.ifsja.org/forums/vb/showthread.php?t=58393
It wont take long if you can muster up a few good days where all you do is work on the re-wire. However if your rig is your daily driver and you don't have another vehicle to drive while doing the re-wire then maybe you had best leave it alone. It is tedious work and time consuming and if you dont have patience then maybe you don't want to get into it. Secondly while under the dash you will probably notice other things that you dont like or would like to change etc. This will add extra time and the need for more parts runs.. I would say I invested about two weeks worth of time in the install, and that was working on weekends only so a total of about 12 days (For me) For a direct swap and install maybe a week??. Besides that I didnt invest all of my time to it when I did have free time, and to add to that I started getting into other projects like making a custom dash panel and I got sidetracked by that as well as other things.
Upgrades
2. Cs-144 Alt 10/1/11
(Wip)
1. TBI
2. New fuel tank
3. AW-4 Transmission
4. Aluminum condensor
5. Custom Gauge Panel
Old 11-16-2006, 12:30 AM
I rewired my '73 wag with '79 wiring from a truck I parted out.
VERY easy, everything goes to the same place, uses similar plugs etc. etc.
Personally I'd find a good donor and get the whole harness.
WAY cheaper and easier to install.
Converted to a GM alternator, and Duraspark ignition @ the same time as well.
Old 11-16-2006, 07:30 AM
95steel 95steel is offline
Just ordered the BJ's wiring harnes for my 79. Will let you know how it goes.
What we do in life echoes throughout eternity
Old 11-16-2006, 07:35 AM
Crazy_Jeepman's Avatar
Super Moderator
Sloppy Shifter
Almost have my 86 J10 rewired with this harness: http://www.gasalleystreetrods.com/Wiring.html It is very easy to work with and quality is very good.
Old 11-16-2006, 09:15 AM
donwag's Avatar
donwag donwag is offline
I re-wired my '82 Chero using a Ron Francis Wiring kit. They are a hod rod custom wiring outfit. I liked it, and it took me about 2 days for an end to end re-wire. Priced about the same as Painless Wiring kits. However, Ron Francis will customize the kit to your specs.
If you are good with automotive electronics, just go with any kit or harness that has good quality components.
If you are a rookie at this, go with a name brand or buy a replacement harness. Ron Francis, Centech, Painless all have very good instructions and a tech line.
Don
82 Cherokee
89 Grand Wagoneer
84 CJ7
Old 11-16-2006, 10:15 AM
letank's Avatar
letank letank is offline
this seems the most cost effective, check your local craigslist.org.... good late wagoneer, w blown engines or slipping trannies are always on sale.... i got my project for $250 for parts (and testing improvements) ..... and it is now a driver... it was just a few seals (RMS, TC seals), after 10kmiles... it is burning a lot of oil... so it will be a body donor for the 74 (too many holes, no watertight anymore)
Michel
74 wag, 349Kmiles on original ticker/trany, except for the rust. Will it make it to Moab without a rebuilt? Status: debugging a few electricals.
85 Gwag, 210 Kmiles. $250 FSJ test lab since 02, that refuses to give up but still leaks.
my jeep aid images
http://picasaweb.google.com/jeepmr/FSJ
Old 11-16-2006, 06:47 PM
Jubbs74's Avatar
Jubbs74 Jubbs74 is offline
I would say go Painlesss (that is such a lie of a name when talking about the price), I re-wired my old 79 J truck front to back with their kit. I did it on the side of the street out side of my apartment complex, only using a utility knife and needle nose pliers. The only problem I had was that i didn't take my time and I wired one of the rear brake lights to the running light so when I hit the brakes the light got dimmer, it was funny. I think that the Painless kit was well worth the money, the wires come labled and a good diagram is provided, you also get a new fuse box with plenty of extra termanals.
Good luck what ever you choose.
RJ
You can tell A LOT about a man by the size of his JEEP
Old 11-16-2006, 09:44 PM
PlumCrazy's Avatar
PlumCrazy PlumCrazy is offline
Location: Just S. of Branson (in Beautiful Razorback Country)
Look for a CJ wire harness kit from Painless or on da'Bay. I did mine from scratch with just a PartsMaster fuse panel and I would not suggest that route if your not fond of "electric spaghetti"
I found a CJ harness on da'Bay for 50 bucks, new a box for the 65/6J
Wayne S
My license plate says "Crazy" not stupid
*STATUS running while I'm gathering parts*
1966 Pontiac LeMans Convertible "Un-Named"
*STATUS on hold for shortage of fundage*
http://community.webshots.com/user/fsjplumcrazy
Old 11-17-2006, 08:18 AM
Kimbrough's Avatar
Kimbrough Kimbrough is offline
Check out Z&M Jeeps. Here ya go:
http://www.zmjeeps.com/harness.php
1991 Hunter Green Grand Wagoneer. Chevy 350 TBI. 4-inch lift. 31-inch BFG AT's.
Old 11-17-2006, 08:23 AM
Pete, didn't you also use one once from EZ Wiring with good results?
-Geoff Hill
Old 11-17-2006, 08:31 AM
Super Moderator
Sloppy Shifter
Nope only one I had is from Its a Snap, I had a set of Quad Gauges I bought from an EZ wire distributor and posted that web addy several times though. I do know one member that bought and used one from EZ wiring and it is pretty much the same as what I have. It worked very good for him as well.
Old 11-17-2006, 03:21 PM
8379qtj10 8379qtj10 is offline
I pulled one from my 79 parts rig
Paid 150.00 for the whole truck
so I got all three harnesses
Tyler Johnson
1987 Grand Waggy
It's been real...it's been fun...but it ain't been real fun.
Old 11-18-2006, 04:39 PM
blakeusa's Avatar
Thanks for the ideas
Painless @ $450 vs Ez2wire @$200-- big price difference...... any comments-
PS thanks for all the other ideas.
Old 11-18-2006, 05:20 PM
Poley's Avatar
Poley Poley is offline
Painless for $365 for the 10104 kit 12 curcuit is pricy but maybe worth it?
would like to find one cheaper and user freindly
Fullsized Gets it DONE!!!!
Old 11-18-2006, 05:32 PM
Super Moderator
Sloppy Shifter
Well mine cost 128.00 and wires everything from front to the rear and everything in between. It comes with instructions and diagrams as to what pin is what on the steering column and light switch, every wire is marked every 4" as to where it goes. Only thing I see that is going to take extra work is the switch to heater and switch to wiper motor wiring, as this harness does not take the wiring to them. It only wires to the switch, though I have not uncoiled the last coil of wire, so maybe it is there, I just have not gotten that far yet. I don't think wiring is going to be EASY or Fun on a good day, but paying big $$$$ for a harness would make it worse.
Old 11-20-2006, 09:03 AM
blakeusa's Avatar
$128 harness- where
Where did you get the inxepensive harness? The cheapest I have found is $200
Old 11-20-2006, 04:34 PM
Super Moderator
Sloppy Shifter
I posted this a few posts up, but here it is again. http://www.gasalleystreetrods.com/Wiring.html
I see EZ has a comparable one for about 150.00
Old 11-21-2006, 06:57 PM
Herk's Avatar
Herk Herk is offline
Do the later instrument clusters have the same connector/pinout? Column switch ignition will have a different connector, headlights will be the same, wipers (pre-delay) should be similar. 73 and later dash harnesses were saddled with the ammeter wiring. At some point didnt Jeep go to a bulkhead connector and seperate engine and dash harnesses? A later harness would gain you a fuse block as opposed to the inlines (really nice if you have A/C). If you decide to adapt a universal harness to your existing instrument cluster connector, solder and shrinkwrap all the wire splices. Dont even think about crimp connectors. In fact if I could offer one piece of advice it would be to avoid crimp connectors whenever possible. Just how far gone is your original harness? If you start out by fixing the hackery of previous owners you may be able to save most of it.
