Old 11-15-2006, 05:49 PM
4x4fEvEr's Avatar
4x4fEvEr 4x4fEvEr is offline
tick tick tick
ive got a really annoying tick coming from the right head on my 360, im guessing its the rockers or something to that effect. the ticking gets faster as the idle increases and the pushrods seem to be oiling like they should and they rockers are torqued to specs so what do i do to stop the ticking?
Old 11-15-2006, 06:06 PM
Am4wag Am4wag is offline
Check for exhaust leaks,as a small leak has same ticking sound.
88GW,360,3 angled valves,K8600,1406,TFI,MSD,727,<br />Hurst,NP229.D44\'s,3:31\'s,BJ\'s 4in.,31in.Generals,ProComp alloys.S-10 box,"Swissed" rockers"
Old 11-15-2006, 06:30 PM
GWChris GWChris is offline
Absolutely! Been there before!
Old 11-15-2006, 07:17 PM
4x4fEvEr's Avatar
i never thought about that. ill have to check it out
Old 11-15-2006, 10:02 PM
j20general's Avatar
j20general j20general is offline
its possible that it might have a bad lifter....but with you saying it getting lots of oil...its hard to say it you cant find a exhaust link it could be a lifter
88-j20
bjs 6in lift on the way...
Old 11-15-2006, 11:21 PM
jode's Avatar
jode jode is offline
JB Welder
I was thinking exhaust leak too - it's real easy to see if that is the prob if you have a length of garden hose or surgical hose or something - just hold one end near your ear and pass the other end around the manifold while the engine is running - if you pass the one end over the area with the leak, you will definitely be able to hear it - actually, I think it's kind of a cool trick...but I am fairly easily amused so....
No FSJs for the time being - "I'm working on it, I'm working on it" (think Mike Meyers' SNL skit about the gut)
Old 11-16-2006, 05:20 AM
4x4fEvEr's Avatar
ok great jode ill try that and see if its the case. would a really small leak not leave any black sut like a larger one? its a pretty clean area
