Old 11-06-2006, 08:01 PM
srobertsfsj's Avatar
srobertsfsj srobertsfsj is offline
WT Waggy?
I found a very clean, almost rust free 86 waggy for sale but its an odd one because it has, what looks like, WT flares on it. It all looks very original too. Did they ever make a WT wagoneer in 86? I am a little confused. I am going to try to snap a few shots of it tomorrow.
Oh yeah, I got the VIN off of it. 1JCNJ15U1GT187048
Scott R.
'86 Wagoneer "Honey Badger" 360 / TBI / WT conversion / TT's Fabworks Shackle Flip and SOA / 35x12.5x16 BFG Mud-Terrains (Project Link)
'78 Cherokee Chief 360 / SOA / 35's (Son's Jeep)
Old 11-06-2006, 08:06 PM
Jeep4myBoys's Avatar
Jeep4myBoys Jeep4myBoys is offline
The vin indicates model 15 - not a wide track (wide tracks were cheros only, up to 1983, after which chero went little). Probably someone added the flares and possibly w/t axles later. Was it 4 door? I'd like to see pictures.
Timothy
It's for my twin boys Sure, they're only 1 year old, but it's all for them!
Daily Driver: 04 F350 6.0 CC LB FX4 Lariat
Jeep: 88 GW 360/727/229, Rusty's 4", 33" tires, Holley TA, TFI **Razor**
Old 11-06-2006, 08:28 PM
It is a 4 door but the rear axle looks like an AMC 20. I will try to take a couple of pics tomorrow and post them.
Scott R.
Old 11-06-2006, 08:32 PM
mrtazwrench's Avatar
mrtazwrench mrtazwrench is offline
80-83 CHEROKEES had wide AMC 20'S
Chad
Quote from Bubbles, on Trailer Park Boys...
"Let's see that red blue green **** sucker build one of these without duct taping it together!"
88 wag
87 J20
82 J20
Parts vehicles: 4 Wags, 4 J20's, 2 J10's, 2 J4K's
Old 11-06-2006, 08:45 PM
Interesting, should I measure the axle? What's the width of a WT AMC 20? What do you measure from?
Scott R.
Old 11-06-2006, 08:53 PM
usually measured wheel mounting surface (WMS) to WMS if you do a search that spec should be here somewhere, or someone will post it.
Chad
88 wag
87 J20
82 J20
Old 11-06-2006, 08:59 PM
baja's Avatar
baja baja is offline
My 78, Chief, wide track rear measures 61" WMS to WMS.
(Wheel Mounting Surface)
baja
Hello, I am Brad. I have JOCD (Jeep Obsessive Compulsive Disorder) If you can admit you might have a problem, is it really a problem?
JEEPS-N-Stuff:
1998, Grand Cherokee, dd.
1987, Grand Wagoneer, Pimped, totalled by hail storm...
1977, CJ5
1976, J10
1949, Willys Jeepsterrr
1948, Willys Jeep truck
1942, Ford 1-1/2ton, Marmon-Herrington 4x4
Old 11-07-2006, 12:15 PM
Here are some pics. Notice the last pic of the rear spring. What the heck is that on there?????
Scott R.
Old 11-07-2006, 12:20 PM
goldhammer's Avatar
Air bag overloads from the looks of it. The fender "jeep" emblems are from a child chero (downsized version) From what I can see, does not look like they split the rear flare to put on the door. They cut the door instead?
Art
ASE Master Collision / Refinish Tech
"Beast" - 81 "S" W/T, 85 boneyard 360, T-18, Lock-rite,waggy alloys, 31-10.50 Pro Comp MT's, Warn 8274 in a homebuilt bumper/deer strainer(tested and approved)
88 XJ, 3" Rancho, 31-10.50's, custom bumpers and winch/tow bar mounts, Warn 9500HS, custom sliders/steps, custom camo paint, custom camo headliner
Old 11-07-2006, 12:38 PM
Wow Scott. Nice find! This is custom as Chrysler would have never done this. I just can't see it being a factory job. Looks good too. Also looks like WT axels installed. If you get by there again, it would be interesting to see how the rear door fits around the rear fender flare.
There was a company in SoCal that made some Super Chief WT Wagoneers in the mid 70s. That is the closest I have seen to any WT Wagoneers that sold "new". I have a black and white photo from what looked to be a magazine or newspaper article of some kind. I wonder where that image is anyways...
Old 11-07-2006, 12:54 PM
I havent bought it yet. I am not sure what they are even asking. The sign in the back use to say "needs work" but it has been sitting there for almost 3 years. Dont even know if it runs or not. What do you guys think that something like that might be worth??
Scott R.
Old 11-07-2006, 12:59 PM
goldhammer's Avatar
Depending on overall condition, running 1500 to 2000, not running 1/2 that. Just depends on what you want, and how bad you want it. Out here it would prob. go for a little more than that. Looks like it might also have around a 3-4 inch lift, judging by the block in the last pic.
Art
Old 11-07-2006, 01:26 PM
couple more questions. The year (86) would tell me it has a NP208? Is this a good TC? Is that the selec-trac? Does it have a 4x4 hi and 4x4 lo?
Scott R.
Scott R.
Old 11-07-2006, 01:32 PM
J4GRAND's Avatar
J4GRAND J4GRAND is offline
J4000 Restoration Specialist
Since it doesn't have manual hubs on the front, it probably has the NP228 that was used for only one year- 1986. Same case as the 229 but without the vicous coupler. It should have a hi-low shifter handle next to the driver on the side of the tranny hump.
Patrick V.
MEMBER #14
78 Cherokee Chief WT "Old Blue" 360 V8 4V TH400 QT
05 Jeep Grand Cherokee 3.7 V6 5 speed automatic with new QT
Old 11-07-2006, 01:33 PM
yeah,i like it.
a lot!
very well done custom job.
Old 11-07-2006, 01:34 PM
86 was the year of NP228. It could be a 229 depending on actual manufacture date. Since it is an AMC 20 in the back, I would guess 228 tho. The 208 was only available on special package GWs (police or gov't usually) and Jtrucks at that time.
Old 11-07-2006, 02:29 PM
goldhammer's Avatar
Bearing in mind since it appears the W/T axles were put under it, it could be a 208 and the donor axles could have come from a full time rig. If a 208 the shifter will be on the left side of the trans tunnel between the dash and seat. If the rear diff cover is a plain round dog dish then is a 20. If it looks like the front then a 44. Probably looking at either 2.72's or 3.31's for gearing unless a R&P swap has been done.
Art
Old 11-07-2006, 03:15 PM
DOH... yeah, being it has clearly got some non stock mods, no telling what is actually under it. Knock on the door and see if you can check it out Scott.
Old 11-07-2006, 03:38 PM
I plan on doing that in the next day or so. I will take a pic of the rear doors too. Not sure what a 228, 229 or 208 look like tho
Scott R.
Old 11-07-2006, 04:18 PM
TexTJ209's Avatar
TexTJ209 TexTJ209 is offline
The rear body lines above that flare look kinda funky..
But yeah, when you go back make sure to get some closeup pics of that rear flare.
'05 Chevy Silverado CC Duramax - The DD.
Texas A&M Offroad
