Old 10-24-2006, 09:38 AM
JeeperJay's Avatar
JeeperJay JeeperJay is offline
Hood pins?
Hi all,
I tried searching real quick, but couldn't find what I was looking for.
Has anyone installed hood pins (like old musclecars have) on their FSJ?
My entire latch assembly is FUBAR. The cable snapped last year, and I've always had issues with the double-latch assembly not opening the hood.
So, I removed the right-side spring latch and now the hood floats up and down when I drive on the highway. The last thing I need is the hood coming up and kissing the windshield @ 70mph.
Short version:
I need to know what size (length/height) hood pins work for a FSJ.
Thanks.
Jason T.
'04 Grand Cherokee: Silver/ black. 2" lift
'02 Grand Cherokee: Black/black Laredo with a V8 and Selec-Trac- Totaled in Sept.'07
'90 Woody:White/maroon. TFI, BJ's 4" & 33" BFGs. Gone but not forgotten
http://www.cardomain.com/ride/2218533/1
Old 10-24-2006, 11:30 AM
baja's Avatar
baja baja is offline
I don't have any pictures of them, but I used to have hood pins on one of my old Cherokee's, worked great, but there is no saftey catch. If you forget the clips, the hood will fly open at speed, ask me how I know.
I used the basic generic parts store ones, like Mr.Gasket brand etc. The basic kit will have long enough pins, I don't think I've ever seen different length options for them. They are not hard to install on our FSJ's, and you've listed every reason to use them, stupid hood release cables
baja
Hello, I am Brad. I have JOCD (Jeep Obsessive Compulsive Disorder) If you can admit you might have a problem, is it really a problem?
JEEPS-N-Stuff:
1998, Grand Cherokee, dd.
1987, Grand Wagoneer, Pimped, totalled by hail storm...
1977, CJ5
1976, J10
1949, Willys Jeepsterrr
1948, Willys Jeep truck
1942, Ford 1-1/2ton, Marmon-Herrington 4x4
Old 10-24-2006, 11:40 AM
JeeperJay's Avatar
Thanks, baja.
Change of subject: Are you the guy who won the "Makeover" for your Jeep? Any progress of that?
Jason T.
Old 10-24-2006, 12:17 PM
jeepmj_tj's Avatar
jeepmj_tj jeepmj_tj is offline
you can use hood latches like found on a m715. I think there's a build up in the offroad tech with a truck with some.
01 TJ-Trail rig
91 MJ-Play toy and work horse
79 J20 Tow Rig- Cummins 6 cyl, DD since 07
Old 10-24-2006, 12:55 PM
BRUTUS's Avatar
BRUTUS BRUTUS is offline
I got mine from JC Whipme for $4.99 each plus shipping. They work... I can attest that they will keep the hood down at 90mph. My problem with them is that the springs squeaked really bad... even at idle. I still use them but only for cosmetic reasons now as I have installed a cable latch from the junkyard.
Here is a decent shot of one.. latched
Sorry for the gratuitious use of my lift pic... but I just love seeing it that way.
Old 10-24-2006, 01:47 PM
rockjeep44's Avatar
The Advisor
Just pick up a set at your local roundy round shop. They are less than $10/pair.
Buggy Buildup
Originally Posted by welchct
Old 10-24-2006, 04:05 PM
baja's Avatar
Yep,
I'm the "Yooper Pimp Daddy"
Here's an after shot,
I posted the results and such back in mid September, probably a few pages back now. How does a person go about linking to the original post?
Thanks,
baja
JEEPS-N-Stuff:
1977, CJ5
1976, J10
Old 10-25-2006, 07:30 AM
JeeperJay's Avatar
Baja, I found the post yesterday. Jeep looks great.
I picked up a set of 'pins from AutoZone for $11.99. They look long enough to mount where the stock springs go. If not, I'll figure something out.
Thanks for the help, guys.
Brutus, your J-Truck looks SICK!
Jason T.
Old 10-25-2006, 07:49 AM
PhilG's Avatar
PhilG PhilG is offline
Pimped Link
http://www.ifsja.org/forums/vb/showthread.php?t=56483
Originally Posted by baja
Yep,
Thanks,
baja
1971 J2000
In the sticks in Central Louisiana
Old 10-25-2006, 09:19 AM
710 Burner's Avatar
Its the CANYONERO!!!!
Mark B. Jones
'76 401 Wagoneer
'79 Chief "Junaluska"
Old 10-25-2006, 09:25 AM
BRUTUS's Avatar
What the he11 is a "roundy round shop?"
