Go Back   International Full Size Jeep Association > Tire Kickin' > Specialty FSJ Tech > Fuel Injection
Old 08-04-2006, 09:10 AM
mike gw's Avatar
mike gw mike gw is offline
Question fuel injection wiring
Doing FI swap on my 89 wagoneer. Where is the best place to put the wiring through the firewall? Just looking for suggestions, at the beginning of what looks to be a big project, but I have collected most of the parts and have put it off long enough. thanks for your suggestions....
1989 Grand wagoneer
Upgrades: TBI(with ebl ecm), TFI, CS144, 33 gallon bronco tank, 6" BJ's lift, 33" tires, s10 steering box, taurus electric fan,
AMC360 bored .040 over, light porting on heads, balanced, Summit K8600 cam. Bulltear increased pressure cam bearings, completed (May, 2010)
Custom dash and center console with 9 VDO gauges.
Old 08-04-2006, 09:14 AM
derf's Avatar
derf derf is offline
I ran mine through the firewall under the heater box. It's hard to get a hole saw in there but it can be done.
Try out my gear ratio calculator (In metric too)
My Jeeps: Truck Norris, Woody (page coming), and CJ
Old 08-04-2006, 09:40 AM
Chevelleguy's Avatar
Mine has a plate that covers the clutch rod hole under the brake booster. I cut a hole in the plate.
