Old 06-16-2006, 08:01 AM
El Jefe's Avatar
El Jefe El Jefe is offline
dana 60 six lug?
i want a d60 for when my 44 dies, but iam going to keep my front 44, probably go up to 35, but can i convert a rear 60 to 6 lug?
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
4" lift, 35 inch retreads
Old 06-16-2006, 08:29 AM
badaboom's Avatar
badaboom badaboom is offline
I believe this can be done, although I would most probably switch over to disk brakes for D60 at the same time if possible - 6 bolt.
1981 Jeep J10 Laredo, 401-V8, 625 Carter Comp Series, Lunati Cam 262/268, Edelbrock Performer, MSD Ignition, Flow Cooler, Be Cool Aluminum Radiator, Doug Thorley, NV4500 5-Spd, NP-231D, 3.73 F/R Trac-Locs, Rustys 4" Lift, Vintage Red Metallic, Black Interior and 33X10.50X15 BFG, EXTREME MAKEOVER - IN PROCESS Bling Bling Cha-Ching
Old 06-16-2006, 08:32 AM
Brad W.'s Avatar
Brad W. Brad W. is offline
as long as it is a full-floater dana 60, you can get conversion hubs from dynatrac, and other similar companies. I would also recommend the disc brake conversion at the same time.
Brad W.
1979 wag "Nightmare"
**project shelved indefinetly**
m715 ex-firetruck
**project shelved**
2001 Dodge Ram 2500 "Project Juggernaut"
24v-CTD/NV-4500/quad-cab/4x4
4" straightpipe, rollin on beadlocked 37's.
Old 06-16-2006, 09:02 AM
El Jefe's Avatar
oh, itll get discs, i got discs on my rear 44 now and dont know how i ever lived without them.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
Old 06-16-2006, 11:08 AM
rustywagoneers_com's Avatar
rustywagoneers_com rustywagoneers_com is offline
might be a better pick if you are only going 35's to run the GM 9.5 inch 14 bolt... they are very common in 6-lug semi-floaters, and will leave you a hair more ground clearance than the 60.... and a dime a dozen, also..
just a thought..
peace
Dave
There is no way to rule innocent men.
The only power government has is the power to crack down on criminals.
Well, when there aren't enough criminals, one makes them.
One declares so many things to be a crime that it becomes impossible for men to live without breaking laws.
Old 06-16-2006, 11:51 AM
El Jefe's Avatar
just a thought..
peace
Dave
really? didn't know bout them. but here's a question, is it worth the work, and time and money and ground clearance for a semi floater? i dont know thats why i asked.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
Old 06-16-2006, 12:43 PM
if you are talking 35's, it might be a while before it is even an issue with the 44, depending on your typical level of skinny pedal...
the 9.5 14 bolt is in lots of later chevy 3/4 ton SRW trucks... and they were built as 6 and 8 lug axles...
i guess worth it depends on the likelihood of you going even bigger later...
peace
Dave
