Old 04-28-2006, 03:27 PM
rampagefsj's Avatar
rampagefsj rampagefsj is offline
Drum to disk brake swap questions
I'm swapping one ton axles into my formerly 4 wheel drum braked J-4000. I was wondering if the stock braking setup would work all right with the front end now being disk braked an the rear being drum (for now).
Old 04-28-2006, 03:42 PM
goldhammer's Avatar
If you still have access to the donor grab the proportioning valve, or you can get an inline adjustable fro the local parts house. Might have to go to a bigger master due to increased fluid requirements on the calipers and rear cylinders.
Art
ASE Master Collision / Refinish Tech
"Beast" - 81 "S" W/T, 85 boneyard 360, T-18, Lock-rite,waggy alloys, 31-10.50 Pro Comp MT's, Warn 8274 in a homebuilt bumper/deer strainer(tested and approved)
88 XJ, 3" Rancho, 31-10.50's, custom bumpers and winch/tow bar mounts, Warn 9500HS, custom sliders/steps, custom camo paint, custom camo headliner
Old 04-28-2006, 08:29 PM
JAP JAP is offline
I did a front disc brake conversion on my "73 J4000. Would like to have gone your route with 1 Ton axles; however lacked the experience and funds, so instead, I used the same closed knuckle D44; added CJ-7 rotors to "81 Waggoneer spindles, calipers and (the part that might be helpful for you), I took the proportioning valve, brake booster and master cylinder form the Waggoneer as well, and bolted it all to my J4000. Have had plenty of stopping power. Will be putting "76 J20 axles under it next with a rear disc conversion. Used the backing plate from my "76 drums to make a "template" and managed to make a spacer to locate the rotor's under the calipers. Time will tell if it works or not.
1973 J4000 360 Howell Throttle Body fuel injection, Turbo 400, Dana 20 transfer case; D44 front axle converted to disc brakes, D60 rear,will be converting to disc.
Old 04-29-2006, 05:54 PM
rampagefsj's Avatar
I do have the power booster and master cylinder from my old parts truck, just no proportioning valve. Would one out of maybe a chevy pickup with front disks work?
Old 04-29-2006, 06:32 PM
Crazy_Jeepman's Avatar
Super Moderator
Sloppy Shifter
Probally would work, but Chevy plumbs them in pretty weird, you would have to change a lot to make it work. I have one off a J10 and a couple off Wagoneer, if you want something that will more or less bolt in.
Old 04-29-2006, 08:29 PM
rampagefsj's Avatar
If it is absolutly needed, there is an 80's J-10 in the junkyard that I could steal it off of. My problem there is that it is out of town, I have no time, and it is covered (literally ) in cars.
Old 04-29-2006, 10:07 PM
Super Moderator
Sloppy Shifter
Well I am sure there are other ways to do it. I am kinda partial to an aftermarket adjustable. If you want one, just PM me with your Address and I can toss it in the mail Mon
Old 04-30-2006, 01:05 PM
rampagefsj's Avatar
Thanks for the offer, but I don't really want to bother you with it too much.
