Old 04-14-2005, 01:01 PM
CR CR is offline
ok so i bought this waggie for a tranny and axle doner for the wifes cj aney way i had planed on using the frame and floor for a buggie and well the body is in to good of shape to just send to the scraper and with out a tow rig at the moment we desided to just build it as i was going to only leve the body so here is the plan
[ April 14, 2005, 07:11 PM: Message edited by: CR ]
RAVENOFFROAD.COM the best club on oregon <br /><br />76 was 11\" of lift and 35s <br />soon 1tons and 38s
Old 04-14-2005, 01:10 PM
CR CR is offline
so the plann is
dodge dana 60
gm 14 bolt with a proto type mini spool
4-10s for now wating to see if spool holds up
amc 360
th400
dana 300
rancho 44044s up front with shackel reversal
stock fronts in the back with a shackel flip and springs mounted under frame
38 14.50 16.5 TSL SX
hummer bead locks
what ya think
Old 04-14-2005, 01:36 PM
jeepzilla47's Avatar
jeepzilla47 jeepzilla47 is offline
sounds cool, but are 4.10s going to be enough for 38s....i had 4.10s with 37s and it sucked...
Mike Hildreth...aka Tubby
"From nothing we have risen, and from nothing, we still rise!!" (Hatebreed)
84 GW in progress
fuel injected 454/th400/203/205/hpd60/ff14b 4.88/welded/4wdb/dbl/39.5 iroks/gm springs/rb shackle flip/ hydraulic assist
Old 04-14-2005, 01:37 PM
CR CR is offline
no but i dont want to trash my 5-38s if the spool dosent hold
Old 04-15-2005, 12:21 AM
full_hydro full_hydro is offline
sounds like fun.. can't wait to see it
Old 04-15-2005, 12:28 AM
waggin'ear waggin'ear is offline
Why are you going with the stock front springs in the back?
A lot of people have gone with the 56" chevy springs since they are longer with better flex.
Sounds like a nice build. I've got a bunch of those parts lying on the shop floor! hopefully yours will be running before mine.
adam
Gotta a lot of junk
" I may not be good, but at least I'm slow"
Old 04-15-2005, 01:13 AM
Stuka's Avatar
Stuka Stuka is offline
The stock rear springs are 56", which means better flex, why do you want to shorten them? Heck a lot of people switch to 62" chevy rear springs for better flex still. Although with the 14FF and the way the carrier is, even if the spool blew up, I dont think it could hurt the gears much, any pieces of size would stay inside the carrier center.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 04-15-2005, 01:24 AM
Merc69's Avatar
Merc69 Merc69 is offline
I used the 62" Chevy springs and gained about 8 inches of wheel base on a spring over. The springs are flat and have flex...a lot of flex.
I am running 4.56 gears and it appears to be a good combination with the 38.5 SX's.
Why go the spool and question it? I have a Detroit, and 4.56 gears from a spare military 14 bolt. The price will be right.
Old 04-15-2005, 03:24 AM
62" chevy (my bad)
adam
Gotta a lot of junk
Old 04-15-2005, 03:48 AM
redranger4.0 redranger4.0 is offline
63" chevy actually but close enough
Old 04-15-2005, 04:31 AM
CR CR is offline
ok i have buitl toyota for the last 5 years and i realy realy hate 63" chevies i got more axel wrap with a little punie 4cyl and one could ever think i broke the main leaf 9 times i will never ever run them agin espicaly on some thing as heavy as a fsj
Old 04-15-2005, 04:32 AM
CR CR is offline
and i realy dont want more wheel base in the PNW if your over about 125 total truck lingth you arent gonna make half the trails
Old 04-15-2005, 04:36 AM
CR CR is offline
The reason for going a proto type spool is because I work for a company who is building and im the test dummies always have been there will be a lot of test parts on these rig in the up coming months it
Old 04-15-2005, 03:05 PM
Sambo's Avatar
Sambo Sambo is offline
well a mini spool will hold up to 38's. i had one in a d44 with 5.38 gears and ran fine! so for a 14 bolt m/spool if you think you can blow one up,more power to ya! i have been pretty hard on my welded 14 bolt with 4.56's and aint even hurtin it one bit
oh i also run 38"hawgs or 39"boggers and trust me you should save for at least 4.56's...4.10's kinda lag!
77Chero,360,t400,231/d300,d60,c14bolt 5.13's 42"PBR's
84wag,360,tf727,208 stock for now! possiblities are d300 flipped and a ford d44 hp with coils
Old 04-15-2005, 03:38 PM
Jeep Doctor
That is just about the same combo I'm assembling, but with a different engine and transfer-case.
If you find an FSJ TF727, you can bolt up that D300 without any special adapters; may be just as easy as gutting the TH400 and getting the D300 adapter, if you're starting with the stock TH400/QT combination.
Old 04-15-2005, 04:49 PM
CR CR is offline
i have 5-38 r/p sitting here and being this is the verry first one produced by the bompney i realy dont want to get it installed and 10 mins later have it fail so i will up grad my diffs to 5-38s after i have a few months on it and know it will hold its all part of rand d
i am using a th400 off a qtrack and i have about 6 of them now so ill run it till i run out of parts
Old 04-15-2005, 10:44 PM
scotty's Avatar
scotty scotty is offline
sounds like a great plan for a trail rig,but i dont think id want to tow something with something with 38s and that soft of a suspension.
im not much for "multi-purpose" daily driver/trail/tow/etc. trucks,so build away,and get a more capable truck to haul it and/or the cj to the trail head
[ April 16, 2005, 04:45 AM: Message edited by: scotty ]
scotty
85 grand wagoneer
258/t18/d20/10 bolt/14 bolt
38" TSL SXs
chopped,bobbed and caged
Old 04-16-2005, 03:56 AM
CR CR is offline
oh i wont be towing with it i just half to leve the body for a bout 8 months till i can afford th etow rig i want
