10-09-2003, 12:57 AM
Super Moderator Ph.D. in FSJ
OK... been on the road for two days (today being 2nd day)
When I installed the new shaft with 1350 slip... I still have a bit of side-to side play between the yoke tabs at the ujoint caps.... I have inspected the yoke for obvious wear... THERE IS NONE THAT I CAN TELL.... but that is besides the point.
After installing and driving... she was smooth as silk....
on my way home last night.. I got on it....when she shifted from 1st to 2nd, I picked up a decent vibe from the drivetrain....
I went under and checked the rear joint at the 14ff yoke and sure enuf, the joint had slid to one side!
I took a brass punch and hammer and re-centered the joint and test drove... smooth as silk again... I just cant get on it WOT yet...
Now... am I missing something? this is the 2nd 1350 joint I have had in there and they both have the same slop.... it's a tad less than 1/8" total slop... so less than 1/16" on each cap
any ideas? thanks
I think I will just buy a new yoke.... but this bothers me... NEVER seen this before on ANY vehicle..
[ October 09, 2003, 06:58 AM: Message edited by: River Beast ]
10-09-2003, 01:49 AM
are you missing a c-clip on the caps? (not sure how your setup is though)
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
10-09-2003, 02:58 AM
caps are solid to the yoke... strap-type... c clip are on the slip side.... tight at the slip... sloppy at the 14FF yoke....
I'll take pic later....
10-09-2003, 03:00 AM
Super Moderator Dr. Rockcrawler
Todd, it sounds like your yoke is shot. you shouldn't have any side to side play. Maybe call Jess at highangle. If I remeber right he talked about this on POR.
Paul Hartman
79 waggoneer
AMC360/TH-400/203/205
www.cbioffroadfab.com
WWW.PLANET4X4.NET
10-09-2003, 03:15 AM
Paul,
Thanks... I will call around to get the best price on a yoke....
Is there is a crush gasket on the 14FF? Nevermind... I'll visit Billavista... AGAIN!!
10-09-2003, 03:17 AM
yes the 14 bolt has a crush sleeve.
Paul Hartman
79 waggoneer
WWW.PLANET4X4.NET
10-09-2003, 03:49 AM
Just found that out... but Billavista has a GREAT MILSPEC PDF file that tells you how to change the yoke and seal WITHOUT destroying the crush sleeve.
FYI... THE PRICE ON THESE YOKES IS FREAKIN OUTRAGEOUS!!! $112- $125
10-09-2003, 05:11 AM
OUCH !
Paul Hartman
79 waggoneer
WWW.PLANET4X4.NET
10-09-2003, 10:52 AM
Try Tom Woods. I got my 1410's for $75 a pop. Dennis
Starting to miss the addiction!
10-09-2003, 10:54 AM
Thanks Dennis!!! I'll give him a call now...
10-09-2003, 01:04 PM
Hey Jesse from highangle is having a sell on all yokes check his add on pirate in the vendors section... they are pretty good deals.... I didn't want to post earlier since RJ44 is trying to sell his yokes... lates
All It Takes Is Money.
I'm the reason why you can only have Jeeps for Avatars. You're welcome.
10-10-2003, 02:46 AM
didnt know this!!! I'll give him a look
10-10-2003, 02:48 AM
Where is RJ44 advertising his yokes at?
10-10-2003, 02:51 AM
Redneck in Remission
on here....
http://www.ifsja.org/ubb/ultimatebb....c;f=1;t=007258
hope this helps, RB
PS I AM NNNNOOOOTTTT A COPYCAT!!!!!
[img]tongue.gif[/img]
<b>Lucille</b> 1980 Chero 4-door<br />parting out<br /><br /><b>on a diet of rice</b> 67 Wag<br />want to get it running<br /><br /><b>The Reason</b> 83 Chero WT<br />$50 acquisition<br /><br /><b>no name yet</b> 76 Wag<br />what you know about free Jeeps?
10-10-2003, 04:46 AM
DANG... its for a D60... I need the 14FF thanks though...
YES YOU ARE!!!
10-10-2003, 06:45 AM
he HAD a 14, I think last time I checked, I just linked it, sorry.....
NUH-UHHH!!!! HOW IS A 1980 CHEROKEE 4-DOOR COPYING YOUR small 78 WAGGY?
JK LMAO
PS I'M NOT PUTTING WT FLARES, JUST AXLES, KEEPING 33'S, BUT ALSO GOING TO RUN SHEETMETAL SCRAP FROM MY G-PA'S HOUSE FOR 715 FLARES, ONLY IT'LL LOOK SMOOTHER, SINCE THEY'LL START FROM THE BOTTOM AS NOT THERE, WORK THEIR WAY UP TO ABOUT THREE INCHES, THEN BACK DOWN TO NON-EXISTENT. [img]tongue.gif[/img] [img]tongue.gif[/img] [img]tongue.gif[/img]
