Old 10-27-2005, 02:05 AM
robselina robselina is offline
I know some of you don't venture out much so thought I'd cross link...
http://www.ifsja.org/cgi-bin/ubbcgi/...c;f=2;t=037030
Rob
Old 10-30-2005, 06:01 AM
Is this a statement or a question?
If it is a statement, then I will take it a face value.
If it is a question, then please elaborate...not sure what you are pointing out or asking here.
Old 10-30-2005, 11:14 PM
rockjeep44's Avatar
The Advisor
I did this to my 727 quite a few years ago and I just went by trial and error. If I remember correctly I connected two of the wires together and grounded the third to the frame. Took a couple tries to get it right but after that worked great.
Buggy Buildup
Originally Posted by welchct
Old 10-31-2005, 07:42 AM
Joe, it was a question, but since most people in the offroad tech section don't venture much into general, I figured I'd post here with a link to the thread, that's all.
All solved at this point. I was using a solenoid with a single trigger post (it was grounded through the frame) so I was automatically thinking about two conducting wires to interrupt the 12V switched voltage, instead of lifting the ground like the switch does...
Rob
