10-03-2005, 11:53 AM
I am going to take the carpet out of my Jeep to put some sort of lining on the inside. Does anyone have any GOOD suggestions? Want to try and do it myself since its just a hunting rig!
81 Wagoneer 360 2 BBL Upgraded the distributor and wires with the stuff from the Ford 460. 2" AAL all the way around. Cheap tires that are smaller than the 31's in the picture. Bone Stock except for some sheetmetal replacement.
79 Wag 360 2 BBL Added rear 2" blocks and Shackles up front. Just need some decent tires!!!
10-03-2005, 12:40 PM
here's what I did...
1. remove seats
2. remove carpet
3. cut and fit metal to replace interior walls in the back, riveted them in
4. go to home depot or lowes or some hardware place
5. find roll in liner you like
6. roll it on and replace seats when dry
Worked out great for me. just be aware that the colors will dry somewhat different from how they look in the store.
Tee-
1986 G-Wag- New 360, Headers, MSD ignition/wires, Cam, 4\" skyjacker, detroit lockers: front and rear, 456 gears, custom front and rear bumpers, roof rack, advantage wetlands, 33*12.50 super swamper boggers on eaton beadlocks, Custom Carhartt seats
10-03-2005, 03:40 PM
Just don't get any on your huttus ? (Sp ??)
10-03-2005, 03:53 PM
ROFL, avoid any hootus contact while applying bedliner. That story still cracks me up.
Be sure to follow the directions for prepping the surface, most roll-ins require you to scuff the hell out of the surface, then wipe it down with Naptha, or a similar metal-prep solvent.
Brad W.
1979 wag "Nightmare"
**project shelved indefinetly**
m715 ex-firetruck
**project shelved**
2001 Dodge Ram 2500 "Project Juggernaut"
24v-CTD/NV-4500/quad-cab/4x4
4" straightpipe, rollin on beadlocked 37's.
10-04-2005, 12:45 PM
if you ever want to use the service panal I would remove the bolts in it. I didnt and now I have to gring the BL off to get to the top of the trany. it sucks. I did the walmart stuff.
FSJ buggy
5.3/4l60e/flipped 300
60/70 locked with 6.16's
4 link/flipped waggys
PSC hydro
42" Iroks/ double bead locks
79 cherokee WT
390/401 heads/727/208
60/60 locked 5.15's
spring over/shackle reversal
38" sx's
00 TJ unders the knife
6.2 gen4/4l60e/doubled 4:1 231's
60/60 35 spl. detroits/5.13
coilovers
42" tsl's
10-04-2005, 01:44 PM
I was SO close to forgetting that story! Dam you.
Am actually doing mine this weekend. Already have everything stripped out and prepped. That's a good point about the inspection cover for the tranny, I'd overlooked that.
A better quality product will yield a thicker finish and therefore better replace some of the sound deadening properties that the 1-1/2" of carpet and factory underlay offered.
81 Cherokee WT [258 and staying that way]<br /><br />*Currently under the knife getting a frame off resto-mod*
10-04-2005, 02:13 PM
I used herculiner, on the entire floor and on some of the exterior, i love it
77 cherokee w/t, built401, th400, QTw/ptkit, d44f, d44r w/detroit, 35\'s, 4in lift...and some other good stuff...dents, and whatnot
10-04-2005, 02:14 PM
by the way, if you get it at chucks/checker/kragen, you can usually get a $20 rebate, so it ends up being $60 per kit
10-05-2005, 06:52 AM
I just replaced the rear panels with sheet metal (14 guage, a little too thick!!). Next I plan on removing the carpet and other items from the floor of the interior and then put down some lining. I hope it works as well as it did for youg guys.
10-05-2005, 11:45 AM
You can use a $15 undercoating gun to spray it in yourself to, (try Harbor Freight). It will give a thicker and more professional sprayed type finish to it compared to rolling it on, and it goes on so much faster. I've done the roll on Herculiner before on a truck bed, but next time I'm using a gun instead.
90 YJ,350 Chevy,700R4, NP231CHD with SS-SYE, SOA, HPD44 locked, 14B locked, 4 wheel disc,<br />38\" TSL/SX on H1 beadlocks
10-11-2005, 09:49 AM
I really like the duraback do it your self bedliner. I did one of my YJ's with that and it want on great and lasted without a problem untill the day I sold it. I also used the herculiner and the duraback was much better IMO.
B&B Customs
Off Road & Diesel Performance
Rockaway& Paramus, NJ
(973) 760-9135
1972 J2000 1 ton Running gear(soon to be 4 linked)
1994 ZJ 6" and 33's tera 4:1 low
1988 MJ /w Complete 99 Cherokee Drive train, dash and sheet metal (working in progress)
10-11-2005, 12:09 PM
duplicolor in a gallon sprayed with a undercoat gun from harbor freight. found at walmart for 40 bucks a gallon. i used it for undercoating on my GW.
1975 J-10 360 t18<br />1970 Duster magnum 360<br />1988 Grand Wagoneer<br />1997 Dodge Dakota Sport 318 4x4<br />2001 Yamaha SRX 700 Snowmobile/
10-20-2005, 05:18 AM
My room mate and I have both considered doing this. My only complaint with some bed liners is that they are pretty thin and extremely rough. Line-x for instance. I don't know, these may only be local names :-p There are some other liners that seem more rubbery, yet very strong. That's what I would prefer, so that if I'm lying on my back or shoulder rewiring something I can barely reach, I don't look like I was trying to slide across asphault when I'm done. Any brand specific opions would be great! Thanks guys!
87 Grand Wagoneer AMC 416/727/229/D44s "Sheila"
62-89 K-30 333/465/205/D60-GM14 "Mable"
83 Eagle SX/4 ???/AX15/NP242/D44-Corp 9.25
No more money.....
10-20-2005, 10:00 AM
Any one try using the spray kind as an undercoating?
10-20-2005, 02:12 PM
don't use undercoating. that's ghetto.
I had a wag with herculiner all through it, it was nice. great stuff when applied properly. I've also seen the durabak come out very nice. I'll be using durabak with the UV resistance additive to do the roof and shortbed area on my wag once I cut the roof off and make it a crew cab, unless I can con line-X into spraying it really cheap.
[ October 20, 2005, 08:12 PM: Message edited by: Brad W. ]
Brad W.
m715 ex-firetruck
**project shelved**
10-21-2005, 12:33 AM
I used the Dupli-color bedliner on the inside of the j10, and basicly did exactly what TheWag did. It was very easy to apply and came out looking great.
I can get some photos today if you like.
10-21-2005, 05:06 AM
LS, photos would be cool.
No more money.....
10-21-2005, 05:53 AM
One thing that I found with the Dupli-color...use the heavy rust primer from Rustoleum on trouble spots. The vinyl coating will stick better on rust properly primed. IMO
10-21-2005, 05:58 AM
That's something I've been wondering too. What surface is best for the liner to stick to? Paint? Bare metal? Primed metal? Water it is, paint or sound dampening from under the carpet is kinda funky. Plus there are a couple places in the back where I must have spilled something that started to eat it? *shrugs* I guess short question. What does it stick to best, besides hands.
No more money.....
10-21-2005, 09:42 AM
Perhaps I need to re-phrase my question. Has anyone used spay-on bedliner on the undercarriage of a Jeep?
