Old 02-11-2005, 12:01 PM
floater floater is offline
Frist look in my signature...now how can i build a subframe! I want 4 more inches of lift and my springs and blocks are a bit stretched as it is , so i thought of a subframe i want to fit 44-49s under it i can clear 42s now with a little rub. Does any one have any plans for it and , does any one know where i can get a supercharging kit for a 350 buick.
Thanks
79\' wagonner widetrack ... 7 in suspension , 3 in body , 350 buick stroked , camed , carbed , and snorkled with 3 1/2 pipes , ( 450+ horses) 39.5x16.50 boggers on black mickey thompson wheels. Hydraluic steering assiasnts , dana 44 frony dana 60s rear detriot rear ez front ..hopefull have some pics sittin on 44s and NOW a 5 1/2\" lift of sub frame thanks to the 3 people that gave info and not critzied me.. and yes my wagonner can eat yours...
Old 02-11-2005, 12:09 PM
Stuka's Avatar
Stuka Stuka is offline
What kind of lift do you have now? are those 7" lift springs (i sure hope you dont have 7" blocks...) or is it a spring over in front, and 4" lift springs with 3" blocks in back, or what?
Also: may want to be looking for a D60 front, and either 35 spline D60 upgrade in back, or a 14FF/D70 in back to keep from snapping axles like pretzels.
[ February 11, 2005, 07:10 PM: Message edited by: Stuka ]
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 02-11-2005, 12:11 PM
tomd's Avatar
tomd tomd is offline
I'm gonna say you have plenty of lift, possibly too much, need to bust out hte sawzall.... And get rid of the blocks. Just my opinion, and hope your D44 front holds up with the boggers, and it won't with 44-49s so hope you are in the market for some built tons or bigger....
71 J-4000 on a 76 Cherokee chassis with homemade flatbed
360/Th400/PT QT/3.07 D44s
Old 02-11-2005, 12:15 PM
sorry not to be specific ya i have custom built spring over front and i built my own springs with 4 in and 3 in with blocks. Also i have dana 90s comin for my rear and 60 for the front.
Old 02-11-2005, 12:19 PM
Mavawreck Mavawreck is offline
I am curious about some things
1. 1979 Wagoneer Widetrack? S?
2. 1979 with a buick 350?
3. 4.38s?
5. 3.5" pipes?
6. 450hp?
id like to hear some more about your rig, sounds truly custom.
1988 Jeep Grand Wagoneer - 'Willie Nelson'
http://www.ifsja.org/forums/vb/showthread.php?t=153928
1992 Volvo 240 - 'Whitney Houston'
- Wannabe freeway bruiser
Old 02-11-2005, 12:21 PM
Kris's Avatar
Kris Kris is offline
This is a bogus post.
450 hp buick 350 ?
3.5" pipes ?
Hydro steering ?
Built his own springs ?
Dana 90 ?
Unsigned ?
He said it himself...
"Frist look in my signature...now how can i build a subframe!"
He doesnt know ?
kris.
89 Waggy
Save the Hammers<--Click it!
AX-15 swap info threads...
http://www.ifsja.org/forums/vb/showthread.php?t=83102
http://www.ifsja.org/forums/vb/showthread.php?t=97262
http://www.ifsja.org/forums/vb/showthread.php?t=104163
Theres more but that should get you started
Originally Posted by JeepinPete
-If it wasn't for bad luck, you wouldn't have any luck at all-
Old 02-11-2005, 12:25 PM
Retro93's Avatar
Retro93 Retro93 is offline
Junk Collector
450 hp buick 350 ?
3.5" pipes ?
Hydro steering ?
Dana 90 ?
Unsigned ?
He doesnt know ?
kris.
YUP.. BSpost for sure.
79 Cherokee Chief WT "RDBLOK" warmed over 360, T-18/ "Dana 19"[Dana 18/20 hybrid 2.46:1 low range], 4.10 Truetrac F/Detroit Locker R, 4" Skyjacker Softride System, Rancho 9000 shocks with in cab adjust, Hydroboost brakes, 33" BFG Mud Terrains
Old 02-11-2005, 12:28 PM
tomd's Avatar
Glad our newbs really want to be here and all....Love to see this board turn into BS
Old 02-11-2005, 12:45 PM
HARDCORE pacer's Avatar
HARDCORE pacer HARDCORE pacer is offline
Not all us newbs are here to BS
78 pacer on 75 chero frame thats shortened 10\" and shackle reversal, D60 front with spool,14ff with detroit locker 4.56s in both,500 hp/500 ftlb torque 401,built 727,208 to divorced 205 doubler,on 46x21 ag tires
78 cj 360, 3spd, scout 44s with detroits SOAed with 36"tsl and beadlocks
Old 02-11-2005, 01:10 PM
hold up there nothin here is bs ... frist off i meant pounds of tourque ,stock the buick 350 that came out of the wagonner came stock with 350 when my dad frist got and put the 350 buick in it dynoed at 230 pounds of tourque and around 365 ft/lbs pounds of tourque thats with 3 1/2 exhaust pipes and headers ...let me put up a site for ya http://www.ifsja.org/tech/figures/engines.shtml second i have a alot more mods for the engine then shown includes modifed 350 edel brock manifold , custom cermaic hearders , port and polish heads and over sized valves.. this is mostly a frakenstein motor that ive moded the parts from bigger blocks with execption of couple diffrent aftermarket parts ... my 3 speed tranny has been build with stronger better gearing yokes and case. my t case is np 205 that i adapted to the 3speed. on the springs i build them at my shop next to my house.. its not hard you just have to have the equip.. i dont pay for any thing to get done to my rig.. its all me. Hydro steering also known hydraluic steering is when you have steering enhancers to help you turn big tires it pushes agianst the steering units kinda like an auto matic push or a super powre steering.. works off aa rock ram hydraluic steering asisant ...lastly why the Dana 90s? Ive seen many big rigs with dana 80s 90s and 125s... please come back with more specific questions , dont waste my time kittys if you dont know how to build a sub frame or have any dumb *** questionms
Old 02-11-2005, 01:11 PM
230 hp..
Old 02-11-2005, 01:17 PM
Ive also noticed most of you only have 3-5in and range from 27-35s in tires , ive got 10in of lift and 39.5 boggers.. only talk if you know whats comin out of your mouth
Old 02-11-2005, 02:02 PM
Earthmonster Earthmonster is offline
Hey floater,
I for one would like to see some pics of your rig, and I am sure most others would 2. As of right now all the talk is in the numbers. If you pulled it off, good for you! A picture speaks a thousand words though.
1971 Wagoneer, Buick 350 bored .030 over with all new guts, aluminum intake, RV cam, Truck Avenger carb. All new A/C 134a system. Finished resto under hood. Next is the suspension and axles.
Old 02-11-2005, 02:03 PM
tomd's Avatar
Okay, so why do you need 10" of lift for 39.5" boggers, does that make you "cool" or something? I know myself and many others, if were wanting 39.5" tires wouldn't want 10" of lift, the sawzall can give you plenty of clearance with a lot less lift meaning more stability...
One of the problems we are having, is you can go and build springs, build up a motor, hydro assist, etc, yet you can't figure out how to build a subframe?!?!?! Also, where didya get the 4.38 gears? What kind of 3spd ya got? Whats the buick stroked out to?
Final question for now, do you wheel?
[ February 11, 2005, 09:04 PM: Message edited by: tomd ]
Old 02-11-2005, 02:25 PM
78indian 78indian is offline
heh...just gonna wait for a pic!
78 Cherokee WT
Old 02-11-2005, 02:44 PM
Jeep Doctor
Things that I never knew existed before this thread:
* An Edelbrock intake for the Buick 350
* A D90 rear axle (knew of the Rover by that name, but never heard of the Spicer product with that designation)
* 4.38 gears for a Dana axle
* Steel Mickey-Thompson wheels
* A Widetrack "S" version of the Wagoneer
But as for help with a subframe, I'm afraid I won't be able to tell you much; I've only got 38" tires with SOA and the stock springs.
Here's a page where you might find some examples and ideas about building a subframe:
http://128.83.80.200/taco/scarysteering.html
Good luck!
Old 02-11-2005, 02:50 PM
tomd's Avatar
Oh bob, i love it..... hehehe
Old 02-11-2005, 09:50 PM
scotty's Avatar
scotty scotty is offline
yikes! dr bob,i wouldnt want to be sitting in that thing when a strong wind came by [img]tongue.gif[/img]
on the subframe building,i agree about the lift. if you want to pimp it around town and climb a rope ladder into it,build away. space the body and frame way up there. i saw a chevy at haspin acres once with 2 spaced up frames,way tall,made the 42s look small.had a 6" spring lift,a 3" body lift between frame 1 and frame 2,and another 3" body lift between frame 2 and the body.
that truck was just about the dumbest,most useless thing ive ever seen in my life. all he could do was run thru the mudholes in the open fields,could not actually go on any of the trails great for the "look how big i am" cool factor at cruise ins at the local frishes,but really crappy for any kind of real world trail riding.
nothing wrong with wanting to run 49s,but if your rig is being built to wheel and not just for show, keep lift to a minimum and remove some sheetmetal to fit them
i run 38s with a 3" SUA lift spring and 3" body lift.
my $.02
[ February 12, 2005, 04:58 AM: Message edited by: scotty ]
scotty
85 grand wagoneer
258/t18/d20/10 bolt/14 bolt
38" TSL SXs
chopped,bobbed and caged
Old 02-11-2005, 09:59 PM
Crazy_Jeepman's Avatar
Super Moderator
Sloppy Shifter
Buick 350 did not come stock in a 79
There is no Edelbrock intakes available for the Buick 350.
Old 02-11-2005, 10:14 PM
Yup and as Dr Bob said there are no 4.38 gears for a Dana axle.
The 230hp you dad had dyno'd is BS. 230 is the factory HP rating and back prior to 72 HP was gross hp as in the motor was tested with an external water pump, external oil pump, no alt etc. In 72 the industry changed to more realistic testing using net hp with the engine turning it's own water/oil pump, w/alt, fan etc. It's usually about 30-35% less than gross hp so if your dad really did have it dyno'd he should have gotten around 150hp reading.
-Geoff Hill
