Old 05-18-2003, 11:07 AM
Big Blue J-10 Big Blue J-10 is offline
Question
Right now I have 35X12.50's on it.i am not sure what the ratio is now but Iknow I will have to re-gear before going with any larger tires.I would like to this if it will not be to expensive.
Danna 44 (front)
AMC 20 (rear)
Adam
1980 Jeep J-10<br />AMC 360 (stock except some chrome)<br />Dual exhaust<br />Dana44 front AMC20 rear<br />4\" inch Trailmaster susp.lift<br />Chevy shackles front,extra leaf rear=5\"inches total lift for now<br />35x12.50 15(no fender triming)<br />body lift coming up soon<br />SOA not far off<br /><a href=\"http://www.fsjworld.com/BigBlueJ10/\" target=\"_blank\">\'80 J10 BigBlue</a><br />\"It\'s not that life\'s to short...<br />It\'s just that your dead for so long\"
Old 05-18-2003, 11:18 AM
netbear netbear is offline
I would stick with the 35" tires with the axles
you have. If you drive the truck on the highway
much I would go with 4.11 gears. If this truck is
mostly for around town and off-road with very
limited highway then I would go with 4.56 gears.
Both of these gears sets hold up well if installed
correctly. The 4.89 gears seem to be a bit weak
(tiny pinion) so I would avoid going that low.
If you are doing the gears it is a good time to
install your choice of traction differential
be it Detroit rear/ ARB front (My favorite
combo) or at least limited slip diffs front and
rear to get the most out of your tires and
gears.
netbear
Old 05-18-2003, 11:26 AM
It sees alot of highway time.do you have to change the axles to or just the ring and pinion? I dont want to upgrade to much until I figuer out if I want to go with the dana 60 and GM 14 bolt.
Adam
Old 05-18-2003, 11:37 AM
You will not be changing the axles, but might be changing the carrier if you have 2.73's in there.
If you have 3.54's, and decide to change them out, I might be interested in your used rear AMC 20 gears.
AMC 20 Gears
AMC 20 Axle/Gear ID
Old 05-18-2003, 11:50 AM
thanks for all the info!!!!it might be acouple of weeks before I get the funds(just killed my acount on NEW ball joints this weekend) to even get this started but I will keep you in mind tadsal!
Adam
Old 05-18-2003, 12:01 PM
Cool Adam,
Are you planning to go to Ouray in July?
We are coming right thru Show Low on our way up.
Actually if you find you have 3.73's (which I am not sure were even offered in a J10 in 1980) I would be interested in both the front and rear.
Right now I have a front Dana 44 with 3.54's and a rear AMC 20 with 3.07's (not sure, still covered in grease) one or both are getting changed at some point.
Old 05-18-2003, 12:09 PM
Don't know if I will make it, i would really love to though!!!
Adam
Old 05-18-2003, 01:10 PM
Max Power's Avatar
Max Power Max Power is offline
you've got 3.31 if you'vr got a manual tranny, w/ auto tranny 2.73 was standard, 3.31 was an option. If yer runnin 35s you must have 3.31.
good luck with the upgrade... I know you're on a budget like we all are, but if you goto a 37 inch tire and like to 'wheel.. you might want to consider the new stronger axles too, better than fixing it on the trail.
good luck,
Robert
______________________________________
Cheers,
Robert
www.rbk3.com/fsj
1980 Jeep Cherokee Laredo WT 360/727/208
1980 MBZ Euro 300D 4-speed manual - Oil Squeezer
1984 MBZ Euro 300D 5-speed manual - Oil Squeezer
Old 05-18-2003, 04:43 PM
Super Moderator
Ph.D. in FSJ
I would go with a 4.27 to a 4.56.... the carrier in the 44 will have to be changed for sure... not sure where the break is for the 20....
IF ball joints broke the pocketbook... you may need bigger pockets for the gear upgrade.....
Gears will run you around $300 plus master overhaul kits..... then you have to think of the carrier upgrade as well..... on top of that... who will install them....$$$$$$$$$$$$$$$
I spent almost $2K on upgrading my 44's with Detroit lockers and 4.89 gears only to bend them in Ouray.....
My advice.... use what you got... get you a 14FF and D60 and and build them the way you want.....
I have less money in my 14FF and D60 than I spent upgrading my 44's...
Todd
www.ttsfabworks.com
Old 05-18-2003, 05:12 PM
Brown Bear's Avatar
Brown Bear Brown Bear is offline
Break for the 20 was 3.08 and higher, 2.73 and lower. 44 carrier will def. have to be replaced, and if you've got 3.31 then the 20 will be ok. I figured about $650 for new dana gears, kits, and carrier. Not cheap, by any means.
NathanielButts
IFSJA Member #18
RIP-USS Minnow-The three hour tour is over.
MacGuyver - 1985 Grand Wagoneer
TFI, Edel Intake, Holley 80457S (yeah, it's shiney), K8600, K&N, Taylor Wires, Ford HD springs, and way freakin' cooooooool
Old 05-18-2003, 10:54 PM
Midnightwagon Midnightwagon is offline
id go with the 4.27's they are good for leverage with the 35's and correct the overall ratio to turn those tires to speed and not over speed your motor. but personally ill be going with 4.88-5.13 maybe 5.38 in the new axles for my uses.
[ May 19, 2003, 04:55 AM: Message edited by: Midnightwagon ]
my jeep has gone to that great big salvage yard in the sky
Old 05-19-2003, 06:33 AM
The ball joints really broke me because I had a shop do them.I have some friends that should be able to handle the swap for me.save some$$$$.So the 4.27 is my best bet.Is it avalible for the AMC 20?Since all I want to do is swap the gears will I need the master over haul kit?
Adam
[ May 19, 2003, 12:36 PM: Message edited by: Big Blue J-10 ]
Old 05-19-2003, 06:56 AM
Brown Bear's Avatar
Yes, the kit is necessary. You'll need to bearings and crush sleave and other stuff. Really shouldn't ever do a swap without one.
NathanielButts
IFSJA Member #18
Old 05-19-2003, 07:03 AM
Are the bearings and crush sleave very $$$$??
Adam
Old 05-19-2003, 07:12 AM
SAustinwag SAustinwag is offline
nah,
the whole 4.10 kit for my AMC 20 rear was like 400$ including everything. I went ahead and installed positrac while I was in there, I think it cost me an additional 400 er something. But it was well worth it!
83 \'Wag<br />AMC 360/ MSD/ Cam/ 650 Holley 4bl.<br />4\" Skyjacker w/35\" MTR\'s<br />plasma cut fenders <br />4.11 with posi<br />Durabak interior<br />Custom front bumper/tank
Old 05-19-2003, 07:31 AM
Did the 4.11s work out good for you or would I be better off with 4.27s??
Adam
Old 05-19-2003, 08:12 AM
I think the 4.10's with 33's are optimal but they do better with the 35's than the 2:70's did this the stock tires. Lots better. I'd prolly go with 4.56's with 35's for serious muddy playing, but for 90% of the time, 4.10's are great. 4.27's might be a happy medium
Old 05-19-2003, 03:20 PM
Thanks
Adam
Old 05-19-2003, 04:48 PM
imported_Big Red's Avatar
imported_Big Red imported_Big Red is offline
I am running 4.27s with 35s. Love em. Great on the trails and still cruises at 70 without stressing the engine too much.
1979 Cherokee WT, 360 4 barrel T18, Dana 20 twin-stick, SOA with a RB Shackle Flip, 4.27s, Hydroboost brakes, TFI upgrade, J-10 Rear axle w/rear Caddy disc brakes and 37" MTRs
Old 05-20-2003, 01:51 AM
Super Moderator
Ph.D. in FSJ
go 4.27's you'll be happier... just like Big Red said....
Todd
www.ttsfabworks.com
