Old 05-25-2004, 06:00 PM
72wag 72wag is offline
hey, i noticed that a lot of you have pictures of your jeeps without the doors on when you are wheeling, but lots of other picks with the doors still on. did you remove the doors permanently, or did you find an easy way to take them on and off? i took my drivers door off once to fix something and had a hell of a time getting it back on correctly so it wouldn't scrape the doorjam.
also, does anyone know of an easy way to make soft-doors or perhaps half doors? my doors suck so much that it would be nice to be able to just take them off when its nice out (i live in seattle, so most of the year i can't drive it without doors because of the weather).
thanks for any advice you guys can give me.
72Wag<br />-------------------------<br />Cameron<br />1972 Wagoneer<br />360/2bbl/th400/twin stick d20/<br />31x10.5/15 Pro Comp MT\'s on AE 589\'s<br />Rhino Grill<br />Custom Dash
Old 05-25-2004, 10:40 PM
Robber80's Avatar
Robber80 Robber80 is offline
they aren't that hard to take off, but i will never put them back on.
*Sold to move* off the frame tube buggy, front 35spline HPd60, rear 35 spline D60. Np203/205 doubled with 3.2 to 1 gear in the 203. TBI 350/th400. Full hydro. and 44s. come get some.
Old 05-26-2004, 12:06 AM
KYJ10 KYJ10 is offline
I thought about making some lightweight doors, but ended up just cutting off all my body. But I was thinking of taking some 1" square tubing, real thin wall, cut and rough it in, then weld it together. Then either sheet metal or canvass to for the outside. Maybe put a piece of lexan in the top half. But that was just an idea I had without much thought. Im sure there are better. Dennis
Starting to miss the addiction!
Old 05-26-2004, 01:08 AM
robselina robselina is offline
to pull them on and off:
1- replace all torx bolts with regular hex bolts
2- get quick connects for any wires to the door so they can be hooked/unhooked easily
3- have a helper when you install them or use a floor jack to keep the door level. I know some folk have it down to 15 minutes to install their doors, just need some practice [img]smile.gif[/img]
Rob
Old 05-26-2004, 02:06 AM
orangecherokee's Avatar
i working on a new design for my tube doors but hopefully when i'm done i could sell a few pairs.
Old 05-26-2004, 05:31 AM
timmirvin timmirvin is offline
Have a couple thought on this. I am thinking of 1/2 doors, BTW.
1. Borrow a friend's CJ door to use as an example. Get some small round stock or maybe even rebar. Bend and weld up the frame. Use CJ style hinges or fab some by welding small piece of pipe to body and weld piece to door that slide into pipe. Still thinking on the latching mechanism. Once it swings and latches, take it to a upholstery shop to have some sort of canvas fitted and sewn on.
2. Take stock door. Gut it, leaving only latching mechanism. Cut down in middle to a good "armrest" height. Take thin aluminum diamond plating and form over top around then down the inside. Fab CJ type hinges. The idea is to have a stock looking door that is light enough for one person to do the on/off stuff and latches.
Just what I have been tossing around in the noggin'.........
\'88 GW...<b>Harley</b><br />Truck Avenger, Performer Intake, TFI, Dual Exhaust, 31x10.50 Goodyear MTR\'s, 15x10 American Racing, Planned: Mossy Oak Camo Clad instead of wood grain!!! Daily Driver<br /><br />\'82 Wag......<b>Sherman</b><br />360/727/NP208/AMC20r/D44f, TFI, Dual Exhaust, 15x10s with 31x10.50s, Homemade 4\" lift, Lincoln Locked Front & Rear...Hunting Vehicle<br /><br />Several Parts Wags<br /><br />Experience is something you don\'t get until right after you need it...
Old 05-26-2004, 03:37 PM
Sambo's Avatar
Sambo Sambo is offline
i swap to my half door during teh summer months! liek rob said i can put a door on in as little as 10 mins apiece
77Chero,360,t400,231/d300,d60,c14bolt 5.13's 42"PBR's
84wag,360,tf727,208 stock for now! possiblities are d300 flipped and a ford d44 hp with coils
Old 05-26-2004, 05:24 PM
Sambo,
what do your half doors look like? i'd be interested to see pictures if you have any.
Old 05-26-2004, 06:01 PM
rockcandy rockcandy is offline
doors....what's a door????
1979 waggy, one ton WT conversion going on...
1979 golden eagle buggy...living on through donations across the country
Old 05-27-2004, 01:33 AM
Slim's Avatar
Slim Slim is offline
im doing a set of 1/2 doors right now ,myself and will also be swappin the doors on and off with the full doors,, i will prob be eliminating the stock latch on the 1/2 doors, cause they are such a biatch to line up .....i will go with the simple "YJ" style of hood hold down ,,,,,but the rubber ones ,,,
77 Cherokee chief ,360 cid,quadra-trac,chopped /bobbed 12" , 8point cage, front exo ,d60frt 14bolt rear ,38.5x14.5x16.5 on beadlocks ,frt & RR winch,OBA ,SOA,shackle flip rear
** Island Rock Crawlers**
4WDABC Member
BCWF Member
Old 05-27-2004, 03:21 PM
Slim, that sounds like an excellent idea!
And IMHO, you live in one of the most beautiful places on the earth, I freakin' love it up there!!
regards....
TI
Old 05-27-2004, 05:59 PM
Slim's Avatar
[quote]Originally posted by timmirvin:
regards....
TI
ty guy ,,,,,this Island is an unreal adventure,,got to love it ... from ocean to Mountains ,,,to lakes,,, all so close around us here
4WDABC Member
BCWF Member
