Old 09-25-2003, 03:59 AM
scotty's Avatar
scotty scotty is offline
Wink
now,ive welded several carries,so know what i need to do however,as those of us running a 14bolt know,the case halves of the carrier bolt together,making the 4 spider and 2 side gears pretty inacessable.
what seems logical is to weld the 2 side gears to the 4 spider gears very solidly,so that the whole thing will slide out of the 2 case halves. my only concern is getting it all just right so that it goes back together.
ive seen some guys fill in the teeth of the spiders,so that they simply cant turn.im starting with a carrier that has a broken cross,so this isnt really an option.i want to make that sucker 1 solid chunk
just wonderin how those of ya running a welded 14 bolt accomplished it [img]smile.gif[/img]
[ September 25, 2003, 10:02 AM: Message edited by: scotty ]
scotty
85 grand wagoneer
258/t18/d20/10 bolt/14 bolt
38" TSL SXs
chopped,bobbed and caged
Old 09-25-2003, 04:05 AM
FSJeeper FSJeeper is offline
King of Unfinished Projects
Here you go Scotty, every thing you need to know about it.
http://coloradok5.com/welded14bolt.shtml
Old 09-25-2003, 04:13 AM
scotty's Avatar
my cross shaft is broken,so that way is not really an option. id have to start with a good open carrier if i wanted to do the fill-in-the-teeth method,but i dont want to goof up my good open carrier.
even if i had an extra open carrier,i dont like the idea of the gears being able to move alittle. prolly puts alot more stress on the cross shaft and spiders. im too afraid the play could cause shockloads that would snap the cross shaft,or shatter ths spiders.
i want it to be one big solid chunk of non-moving metal inside the carrier
scotty
85 grand wagoneer
38" TSL SXs
Old 09-25-2003, 05:06 AM
blt2krl's Avatar
blt2krl blt2krl is offline
Super Moderator
Dr. Rockcrawler
Hey Scotty have ya searched POR. They have a few great how to's in the BB archives. I know some of them bag on the K5 method. I haven't welded mine yet and am actually leaning toward the detroit.
Paul Hartman
79 waggoneer
AMC360/TH-400/203/205
www.cbioffroadfab.com
WWW.PLANET4X4.NET
Old 09-25-2003, 06:11 AM
robselina robselina is offline
scotty, just intuitively speaking, I'd say try to weld it all together well enough so it doesn't move before disassembling the carrier halves to get a better pass. You can always do the trick where you mash in a couple of bolts and weld them in there too, for a little added resistance.
As far as filling in between the teeth of the spider gears, as far as I know, this for front gears only. Some people complain that when welding the front spider gears to the carrier, they can have trouble getting their hubs to disengage. I guess having a little play from the gears not being welded to each other or the carrier helps. That being said, my front gears on the CJ are welded to each other and the carrier and I haven't had any problems with it.
Rob
Old 09-25-2003, 06:23 AM
Stuka's Avatar
Stuka Stuka is offline
you broke a 14FF cross shaft?!
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 09-25-2003, 11:45 PM
scotty's Avatar
rselina,that is the method i use as well for conventional open carriers-weld the gears to one another and the carrier. this 14 bolt carrier,is however,a different animal. there are not any accessholes big enuff to get the torch inthere and tackthe gears together and pull it apart. trust me,if it were that easy,i wouldnt be asking for tips
im thinking maybe i can gently pull one half,tack the gears,put the half back on,flip it over,poull the other half,tack the other gears,make sure it still bolts together,then pull it apart and finish welding.
i will do a search on pirate and see what any of them have to say.
stuka,no i havent broken a 14 bolt cross shaft. we picked up 2 14 bolts awhile back for $50 apiece,and this carrier came from one of them. not sure what happened to it. funny thing is the wayt the 14 bolt is set up,all the spiders could still turn,and a person could have been driving as truck with the broken carrier for who knows how long and not even known something was wrong
i have this notion that i want to swap my steering brakes to the front,and weld the rear and see how i like that setp. i want to use this broken carrier to weld so its no biggie if i dont like it i can swap my good one back in.
thanx for the responses thus far,keep em comin [img]smile.gif[/img]
scotty
85 grand wagoneer
38" TSL SXs
Old 09-26-2003, 12:49 AM
scotty's Avatar
found this on pirate,this is how im gonna do it:
http://www.pirate4x4.com/forum/showthread.php?s=&threadid=161891&highlight=14+bol t+ and+weld
basically make the spider and side gears into a minispool
thot id share it with yas [img]smile.gif[/img]
[ September 26, 2003, 06:51 AM: Message edited by: scotty ]
scotty
85 grand wagoneer
38" TSL SXs
Old 09-26-2003, 02:36 AM
blt2krl's Avatar
Super Moderator
Dr. Rockcrawler
That is the article I was think off. I agree it looks like the best way to weld it together.
Paul Hartman
79 waggoneer
WWW.PLANET4X4.NET
Old 09-26-2003, 02:55 AM
Gwamp's Avatar
Gwamp Gwamp is offline
High Tech Redneck
Let us know how it goes as I am considering doing this to the 14 bolt in my basement.
Roll up on you like Eastwood...
Old 09-27-2003, 02:35 PM
Stolen76 Stolen76 is offline
while you guys are hangin around this thread... anyone have the link to the write up on the D44 lincoln locker ? there was a guy here that did a great write up on it and I lost it with a computer crash.
76 Wag, 360, TH400, 3.55\'s<br />Q-Trac P/T, 16%OD, 2\" AAL<br />Uniroyal LT265/75-16\'s on 16x7\'s
Old 09-27-2003, 06:23 PM
orangecherokee's Avatar
irbob welded up his AMC20 and it was the technique that's used. it should be in his sig if you look him up. welding a 44 ain't squat a monkey can do it. that should give you plenty of condfidence.
Old 09-28-2003, 04:31 AM
jeepsr4ever's Avatar
www.Bulltear.com Chief
FSJ jeeper is that for real?? dont you think thats a weal way of welding the diff, amn i would never do it like that
AMC/Jeep Forum
Old 09-28-2003, 04:32 AM
i dunno man, that puts all the stress on one tooth
AMC/Jeep Forum
Old 09-28-2003, 04:33 AM
how i do it is to weld the spiders together and then the spiders to the diff case
AMC/Jeep Forum
Old 09-28-2003, 05:58 AM
irbob's Avatar
irbob irbob is offline
Welding diff's...never heard of doing such a thing...
Bob (irbob)
My Homepage:
http://fsjeep.homestead.com
IFSJA Decal:
http://fsjeep.homestead.com/stickerpage.html
83 Wagoneer Limited won the toss to be "Woooof II". 83 Wagoneer Brougham Status: Parts rig for "Woooof II"!!!
Old 09-28-2003, 05:59 AM
irbob's Avatar
Oh BTW it is now called a "Miller Locker"
Bob (irbob)
My Homepage:
IFSJA Decal:
Old 09-28-2003, 01:08 PM
scotty's Avatar
ok heres what i came up with today
scotty
85 grand wagoneer
38" TSL SXs
Old 09-28-2003, 04:07 PM
Jeep Doctor
Looks Good!
Now, want to do one for me??? [img]smile.gif[/img]
The trick, I gather, is to keep the four shafts in perfect orientation, so that the two halves of the carrier will bolt back together. Just a little warpage from welding, and those shafts aren't going to sit in there properly.
I'm surprised that nobody offers a drop-in spool for this pumpkin. The right CNC program should be able to whittle one out of a single block in a short time.
Old 09-29-2003, 03:02 AM
blt2krl's Avatar
Super Moderator
Dr. Rockcrawler
I have seen one offered from west coast differential.
Paul Hartman
79 waggoneer
WWW.PLANET4X4.NET
