Old 11-10-2005, 07:02 AM
harvgs3177's Avatar
harvgs3177 harvgs3177 is offline
has anyone out there used the cut out flares offered by jc whitney? iknow bush wacker offers them along w/ afew other companies, but personally i think 350-400$ is a bit steep. if you have any other suggestions, i am open to any.
God loves heavy metal and 4x4's.
Old 11-10-2005, 07:45 AM
Ted_Z's Avatar
Ted_Z Ted_Z is offline
Is this for a Wag, Chero N/T or Chero W/T?
On my Chero W/T, its got he factory flares cut out and I'm running 33" with a 2.5" lift.
-Ted Z
'76 Cherokee S
Old 11-10-2005, 10:11 PM
harvgs3177's Avatar
cherokee n/t 1978. i though w/t,n/t fenders were the same, except for larger opening and flares?
Old 11-21-2005, 12:26 PM
Tigger4X's Avatar
Tigger4X Tigger4X is online now
Arrow
I want to hear more about these flares and FSJ's. I have been thinking about playing with my sawzall BUT I want to end up with a good looking finished product and NOT like a hack job.
So let's hear some more about this!
Hi my name is Keith; I have Obsessive–Jeep Disorder (OJD) : a mental disorder characterized by intrusive thoughts that produce anxiety, by repetitive behaviors (buying parts and more Jeeps) aimed at reducing anxiety, or by combinations of such thoughts & behaviors such as but not limited to working on said Jeeps for extended hours.
Old 11-21-2005, 03:03 PM
Super Moderator
Ph.D. in FSJ
Not sure on the Fiberglass flares flares, but there is a alot of fabrication to make them work on the 4 door NT body style.... 2 door model would be much easier without dealing with the doorjam and wheelwell mods....
Cutting about 4" of the bodypanels out... flanging... patching the inner wells... just to name a few major issues...
But... look at it this way... you KNOW it can be done with STEEL FLARES....
Todd
www.ttsfabworks.com
Old 11-21-2005, 03:16 PM
Stuka's Avatar
Stuka Stuka is offline
A 78 cherokee is most likely a 2dr, but they did have 4dr cherokees then. The rear fenders are quite a bit different. The tub and fender flare are one piece, and as todd showed, not easy as one may think to adapt on. Although if you have a 2dr, you dont have to move it back.
Sambo did a WT conversion on his cherokee, he may pop in here and give some more detailed info.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 11-21-2005, 03:19 PM
Gambler68's Avatar
Rabble Rouser
sick sick sick Riverbeast. Get that thing up to Ouray next summer!
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 11-22-2005, 02:04 AM
Super Moderator
Ph.D. in FSJ
I will be in transition of retiring from the Marine Corps and settling in a new carreer at that time... I'll have to see if its at all possible.... but I would LOVE to attend....
Todd
www.ttsfabworks.com
Old 11-22-2005, 02:43 AM
wagger wagger is offline
Todd, will you please give more detail on moving your axle back? Can this also be done to make room for the fiberglass flares? did your steel flares come from a w/t chero.?
Thank you
john
Old 11-22-2005, 07:47 AM
incommando
Posts: n/a
RB, I would like to hijack this thread for a minute to thank you for your service...
Old 11-22-2005, 07:53 AM
Super Moderator
Ph.D. in FSJ
John,
yes.. flares were 'donated' from a W/T chero...
If the flares are made for 2 doors you will need to relocate.. if for the 4 doors.. no... no need. I had never had luck finding the glass flares for the 4 doors....
HEIMEKEN did an AWESOME JOB using XJ Aftermarket Flares on is Waggie...
as for relocating the axle... not sure what you would do if you didn't go SOA... you can probably use the same springs I did ( 96 Burb springs w/o overloads and then relocate the rear shackle boxes further back on the frame to get them to sit correctly...
Since I was SOA already, and had my shackle flip installed... I just swapped left and right flip brackets and adjusted accordingly....
original FSJ springs..
comparison of springs ( overloads removed)
With front eyes aligned... the axle location is 4.5" to the rear
AFter swaping left and right shackle flip brackets and installing/adjusting....
These springs gain about 2" of additional lift...
[ November 22, 2005, 03:11 PM: Message edited by: River Beast ]
Todd
www.ttsfabworks.com
Old 11-22-2005, 08:04 AM
Super Moderator
Ph.D. in FSJ
Thanks....
Todd
www.ttsfabworks.com
Old 11-23-2005, 04:10 PM
oldcj5guy oldcj5guy is offline
Another hijack, but RB, which unit are you retiring from? For some reason I thought you were already over and done.
'86 grand wag - Under construction
'79 j10 - 350tbi, th400 dana 20
'84 cj7/yj Have the engine and tranny now M103A3 - Under construction
Old 11-23-2005, 11:50 PM
Super Moderator
Ph.D. in FSJ
MALS-11 in Miramar...
No ... I just moved north to buy a house and settle.. that way I wont have to again after I retire... the 140 miles daily commute isnt all that bad... after you do it a while...
[ November 24, 2005, 06:52 AM: Message edited by: River Beast ]
Todd
www.ttsfabworks.com
Old 11-30-2005, 02:45 PM
Tigger4X's Avatar
Originally posted by River Beast:
yes ... flares were 'donated' from a W/T chero ...
Hey Todd, First off I also wanted to say thanks for your service in the Corps. My nephew Rick is in the Corps in Iraq and I have a few friends serving as well. Thanks again for your service!
Secondly I had some questions about the flares and the springs you used. I'm pretty sure that my '76 Chero 2 door is a NT, but either way I have been wanting flares so I don't have to run with mudflaps. How far out do the steel flares stick out away from the body?
Thirdly I'm going to attempt to send you a PM with pics of my home-grown block eliminator so you can tell me if I could run the rear springs you used. Besides the 2" of lift they offer, it might be nice if they set my rear axle back a lil bit for an ever so slightly better departure angle. I have the same axle set-up as yours and with my eliminator it sits level to maybe a 1/2" rise in the rear. The rear looks like it has an AAL, not sure if that accounts for the 1/2" rise or not.
Oh yeah, what springs did you use up front?
Thanks
Old 12-02-2005, 02:55 AM
Super Moderator
Ph.D. in FSJ
I got your email and replied... thanks
Todd
www.ttsfabworks.com
Old 12-02-2005, 09:05 AM
mark mark is offline
thats a beautiful and unique job todd!
"No ... I just moved north to buy a house and settle"
how far north?
mark<br />76 cherokee chief<br />chevy 502 t-400 np-205<br />dana 60 front corp 14 bolt rear<br />fiberglass fenders and quarters<br />(ABOVE THE LAW)(AND UNDER CONSTRUCTION)<br /> [IMG]<br />[url=http://www.fsjworld.com/mygallery.ten?id=3481[/URL]<br />[/IMG]
Old 12-02-2005, 01:31 PM
Super Moderator
Ph.D. in FSJ
Mark,
Been and long time... Thanks for the attaboy!
65 miles north of San Diego... Sun City off the 215....
Todd
www.ttsfabworks.com
Old 12-03-2005, 02:39 PM
Tigger4X's Avatar
Got it ... and replied back! Thanks
I was going to send you a hand drawn scale picture of the rear fender along with the dimensions but I only had the front fender in my computer and my dadgum scanner is bein' a PITA.
BTW, how do you like the extended wheelbase over the stock?
Old 12-04-2005, 09:15 AM
Super Moderator
Ph.D. in FSJ
It's not that noticeable since I did so much at once.. only 4.5"
THATS A LOOONG EMAIL!!!! LMAO!!! let me gather my thoughts and answer... lol
Todd
www.ttsfabworks.com
