Old 11-10-2004, 01:09 PM
will e's Avatar
will e will e is offline
Always Broke
I have a differnt thread going in the general tech area but you all may have more experience.
I am having a shop replace my ring and pinion gears (pray for me). They tell me I have to go through a break in period before I can go wheeling. Does this sound right? I am not going to do anything 'hard core' but I was planning on taking my truck out this weekend.
500 mile break in.
It is a 'Genuine Gear' set.
opinions?
http://www.ifsja.org/cgi-bin/ubbcgi/...c;f=2;t=030326
81 Wagoneer - 'WILL E' Retired
82 Cherokee WT - SOA/SF/cross over/high steer/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/awesome Rstep custom bumpers and roll bar/Tad steering brace
Old 11-11-2004, 01:46 AM
Super Moderator
Ph.D. in FSJ
http://www.4x4now.com/gt0999.htm
Todd
www.ttsfabworks.com
Old 11-11-2004, 02:24 AM
zmjeeps's Avatar
zmjeeps zmjeeps is offline
I have read the article RB posted before and it sounds good. I printed it out and passed it around to my colleagues here at work and we agree it sounds like sound advice. For those of you that don't know, I work in Advanced Engineering at Dana Axle.
Zack Heisey
Z&M Jeeps
419.893.4JEEP (4533)
www.zmjeeps.com
zack@zmjeeps.com
Old 11-11-2004, 04:48 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Work hardening was the only thing I could think of being an issue since it's either set up correctly or not.
Old 11-12-2004, 05:51 AM
will e's Avatar
Always Broke
Good advice.
I run 3.31 gears and 31" tires. No towing so not alot of excessive heat.
I have been taking it on short trips and will go on a longer trip today.
So far so good. Thanks for the advice.
Old 11-12-2004, 07:02 AM
blt2krl's Avatar
blt2krl blt2krl is offline
Super Moderator
Dr. Rockcrawler
GG gear sets are cheap for a reason. I have personally seen three sets let go. They were all set up by repuable shops.... I am a firm believer of you get what you pay for in this sport....
Paul Hartman
79 waggoneer
AMC360/TH-400/203/205
www.cbioffroadfab.com
WWW.PLANET4X4.NET
Old 11-12-2004, 08:17 AM
Elliott's Avatar
Cowboy Up
blt2krl, any opinion on the Wolverine gear sets RR&P sells?
Old 11-12-2004, 09:18 AM
blt2krl's Avatar
Super Moderator
Dr. Rockcrawler
Never heard of them, Elliot. I'm running Percision gears. I know they are pricey but other than Dana or Precision, I wouldn't run anything else Quality counts big time. I have seen the yukon stuff, Precision gear in a yukon box. I believe yukon buys overstock and then resells it under their brand. What is the price they are asking for them? That will usually tell you what the quality is..
Paul Hartman
79 waggoneer
WWW.PLANET4X4.NET
Old 11-12-2004, 12:04 PM
will e's Avatar
Always Broke
Thanks for the info on the GG sets. I honestly didn't know My truck was in getting the locker installed and they found some broken teeth in the stock gears.
We will see what happens. Fortunatly I am not hard core....
Old 11-12-2004, 12:26 PM
2MANY4X'S2FIX 2MANY4X'S2FIX is offline
Location: Southwest Oklahoma, not near as pretty as North Texas.
I've had quite a few axles regeared. I just picked up the truck and started driving and wheeling. I changed the diff lube every 1,000 miles until 3,000 then every 10,000 after that. My 2 cents. I tend to view it as a plug and play mod.
"Women are a lot like engines. Long as they both suck, squeeze, bang, and blow they're worth keeping around"
MKMC Doan
Old 11-12-2004, 01:12 PM
Elliott's Avatar
Cowboy Up
Originally posted by blt2krl:
</font><blockquote>quote:</font><hr />Originally posted by Elliott:
Never heard of them, Elliot. I'm running Percision gears. I know they are pricey but other than Dana or Precision, I wouldn't run anything else Quality counts big time. I have seen the yukon stuff, Precision gear in a yukon box. I believe yukon buys overstock and then resells it under their brand. What is the price they are asking for them? That will usually tell you what the quality is..</font>[/quote]Wolverine... OK, Yukon... that's right, don't remember what I paid for them with the Detroits n'all.
Old 11-12-2004, 03:39 PM
78indian 78indian is offline
i just helped my dad install my 4.11 gears in my d44s and we had a fun 2 hours shimming the rear detroit so the back lash was in between 6 and 10thousands and we got it to 8thousands. he smiled at me and said "now its happy" he is an ase certified master tech and has been for about 20 years now. he didn't mention any breakin but did say i made a good choice when spending the extra $ on yukon gears other than the less expensive ones i was thinking about buying.
ps: i paid $1040.00 for 2 4.11 r&p, 2 master install kits(all bearings, seals, shims, nuts and bolts), opern carrier for front and a detroit locker for rear.
[ November 12, 2004, 10:45 PM: Message edited by: 78indian ]
78 Cherokee WT
Old 11-13-2004, 06:02 AM
Stuka's Avatar
Stuka Stuka is offline
I installed Yukon gears in my cherokee when I put in the detroit. Was a back yard install 2 years ago, and is still holdingup fine. I drove 150 miles, then changed the fluid and cleaned out the dif housing inside. Put new fluid in, been fine ever since.
I have also seen many GG go poof, they are made in korea.
Yukoen isnt the best either, they are more in middle. But a good product overall.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 11-16-2004, 11:19 AM
FullsizeWagon FullsizeWagon is offline
When I regeared through a shop in Metro Detroit that Reider Racing refered me to (they are a big drivetrain supplier in MI), those guys said to drive under 55 mph for at least 500 miles with going easy on the skinny pedal, no wheeling, etc. So the gears break in correctly. If I were you, I would let the gears break in like the shop told you, it is pricey to have them installed again. Also, you wouldn't want to mess up the new locker with gear teeth breaking in the future.
Old 11-18-2004, 12:40 AM
will e's Avatar
Always Broke
good point.
So far so good on the locker.
Old 11-18-2004, 03:52 PM
rockcandy rockcandy is offline
was it what you hoped for?
1979 waggy, one ton WT conversion going on...
1979 golden eagle buggy...living on through donations across the country
Old 11-18-2004, 04:22 PM
Big difference when I got mine! Will E did good last weekend!
Old 11-21-2004, 12:41 AM
will e's Avatar
Always Broke
Yep, it was what I hoped for and more. More confidence and let momemtem going up hills and around stuff. Makes me want to put one up front too!
