Old 08-16-2005, 02:09 AM
jode's Avatar
jode jode is offline
JB Welder
It comes with the truck and the mathcing rear D60
It looks like a great deal, but I wonder what kind of damage to expect from the accident?
This is all they say
1979 Dodge pickup was involved in a crash May 2005.
It has a good 360ci and 4-speed tranny (with new clutch). The 203 t/c is busted. Front & rear Dana 60's. The front needs a new tie-rod. But, no other exterior damage. Most of the impact was the bumper area. The frame bent shearing the u-bolts and pushing the axle back. The gear ratio is your gamble. The upper & lower radiator hoses are cut and the fan shroud is also busted. I didn't pay attention to the tires, but the pics show decent condition. The carpet & seats are worn, but the dash & glass were in great shape.
What should I do - the 60 is what I want, but I worry about the damage.....
No FSJs for the time being - "I'm working on it, I'm working on it" (think Mike Meyers' SNL skit about the gut)
Old 08-16-2005, 02:24 AM
FSJeeper FSJeeper is offline
King of Unfinished Projects
I would jump on that so quick!
First, I doubt the axle is damaged. If it is damaged beyond repair which I doubt cause you would have seen it, the SRW hubs/rotors are worth $250, the knuckles are worth $250, and you can sell the rest of the parts probably for $200 or so. That NP203 is perfect for a doubler for a FSJ. 23 spline input. You could swap in a Ford input shaft and use that transmission too. Finally, the rear dana 60 is a bolt in for wags and Cherokee's. No way you can loose on this deal buddy.
Old 08-16-2005, 02:56 AM
jode's Avatar
JB Welder
Thanks for the input - I already jumped in line to get it, so now only time will tell....but your thoughts make me feel a whole lot better about the deal
Thx
It sounds like the 203 tc is "busted", but supposedly the 360 still runs good, so it may be worth a few dollars too
Now if only the gear ratio was 4.10 or better
I can't imagine them putting in anything worse than a 3.54 though...
Ronson Ronson is offline
Are you sure thats a D60. It looks kinda small in the picture(Hard to tell though!)
"Technological progress is like an axe in the hands of a pathological criminal"-Albert Einstein
Old 08-16-2005, 03:00 AM
jode's Avatar
JB Welder
Well, he says front and rear 60s, so I am going off that. It would definitely queer the deal if it was a 44.
Old 08-16-2005, 03:09 AM
NP203's had chain stretch problems. I seriously doubt that the gear reduction box is damaged. They are total beef and all you would want is the gear reduction box off of the NP203, not the tcase itself.
Old 08-16-2005, 05:08 AM
Brad W.'s Avatar
Brad W. Brad W. is offline
if the lockouts are the same size as the ones (or the drive flanges) on your FSj, it's not a D60. looks kinda tiny to me. i'd try to get the rear end and do more looking into the front. it just looks too dang little to be a d60.
Brad W.
1979 wag "Nightmare"
**project shelved indefinetly**
m715 ex-firetruck
**project shelved**
2001 Dodge Ram 2500 "Project Juggernaut"
24v-CTD/NV-4500/quad-cab/4x4
4" straightpipe, rollin on beadlocked 37's.
Old 08-16-2005, 05:38 AM
I have been told that all one tons have the lights on the roof. I know that all of the D60 stock trucks I have seen have. I'm sure that so many swaps have been done throught the years that it is a very loose rule. I have also seen trucks with the cab lights that had a HD-44 in it.
Old 08-16-2005, 06:07 AM
jode's Avatar
JB Welder
I bet the TC is busted from having the driveline get pushed back into it. Dunno if that would affect the reduction unit.
RE the D60 - I can tell the difference when I see them in person, so I am not too concerned with that - they did say that it is a 60...I'm just going off what they said.
Looks like a few people may have gotten in line before me, so I may be out of luck anyway
Old 08-16-2005, 06:11 AM
Stuka's Avatar
Stuka Stuka is offline
Thats an D44HD, not a D60. Notice how the hub necks down right outside the wheel. Plus didnt Dodge use a D70 as the rear axle for 1 tons?
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 08-16-2005, 06:15 AM
Sure looks like a D60 to me. Not all 3/4 tons had lights on top, especially back in the late 70's. I seriously doubt nothing is wrong with the gear reduction box, those things are total beef.
Hope you get it. I would have been all over it.
Old 08-16-2005, 06:54 AM
FSJnovice FSJnovice is offline
that is a mid 80's truck unless someone put a newer front clip on it
Mike
88 GW stock
360/727/229
project
Old 08-16-2005, 07:50 AM
blt2krl's Avatar
blt2krl blt2krl is offline
Super Moderator
Dr. Rockcrawler
Jode,
That is a Dana 44HD. Guy posted on the site that he was wrong. I hate it when people get you all excited for nothing.
Paul Hartman
79 waggoneer
AMC360/TH-400/203/205
www.cbioffroadfab.com
WWW.PLANET4X4.NET
Old 08-16-2005, 09:03 AM
jode's Avatar
JB Welder
Thanks Paul - that definitely makes things look a little less attractive...
...on with the search for the elusive $250 D60
Old 08-16-2005, 10:55 AM
rampagefsj's Avatar
rampagefsj rampagefsj is offline
A dodge 203 input matches a jeep th400? So all I would need is an adaptor?
Old 08-16-2005, 11:06 AM
Originally posted by rampagefsj:
</font><blockquote>quote:</font><hr />Originally posted by FSJeeper:
A dodge 203 input matches a jeep th400? So all I would need is an adaptor?</font>[/quote]It would match up to an 80 or later 737 or manual except T-18 which has a 32 spline output.
Old 08-16-2005, 11:27 AM
rampagefsj's Avatar
Awww, Pooo
Old 08-26-2005, 06:35 AM
Twinpinion's Avatar
Twinpinion Twinpinion is offline
It's a Dana 44. Hub and lower ball joint (driver side) say so. But even if 203 t-case is snapped in half range box should be fine.
I'm not mean. You're just a sissy.
Old 08-26-2005, 06:43 AM
rockcandy rockcandy is offline
hub yes...ball joint no. There are plenty of ball joint 60's.
1979 waggy, one ton WT conversion going on...
1979 golden eagle buggy...living on through donations across the country
Old 08-26-2005, 01:24 PM
Stuka's Avatar
There wasnt any ball joint D60's in that era. The first ball joint D60 had unit bearings and no hub at all, just a drive flange. The D60 with ball joints and a hub came out in the 90's.
