12-02-2005, 05:43 AM
well, after 5 years of sitting, my wag will finally be moving under it's own power this holiday season. I will be using my christmas break to finish it up and get it all together.
Thanks to grimgaunt for the transmission deal!
all that is really left to get is the engine, or rebuild my blown 396 with later model square port heads for the EFI manifold. I got a good deal on a painless standalone TBI harness, and a 747 ecm, so i now have everything except the engine and the high-steer done. I can't hardly wait! after i get it running, i'm gonna weld the hell out of the diffs and go romping through the woods for a shakedown. then when it stops snowing, i'll slice up the roof.
here's the lowdown on the rest of my drivetrain, all of which is ready to go in except moving the perches and swapping discs onto the 14 bolt.
*rear 14 corp. 14 bolt, 4.10's, discs, welded diff
*dana 60 front, 4.10's, welded
*driveshafts from one-ton truck
*np-205 round pattern, with factory GM th400 adapter
*GM th400, one-ton style with 32 spline shaft
*motor undecided, pending teardown of blown 396
*GM TBI on painless harness
*bumpers nearly finished, warn 8274 for the front till I can get a 12k ramsey, 5k warn rear winch, for anchoring me when pulling.
*2" alcans front with GM SOA perches on dana 60.
*rear shackle flip and hybrid YJ/FSJ springs.
****should net about 8" lift, we shall see****
other mods include (because most of this crap is sitting on my floor waqiting for install, haha):
*crew-cab chopped roof with half-soft back
*full cage, frame & seat tied, bumper & slider tied
*rear 1/4 panels chopped all to hell (in progress now)
*front WT fenders, sans-flare
*tube armor tied to cage, sliders, and bumpers
*rear tuffy tool drawers, fender-top boxes, fuel cell and tire mount in the rear short-bed.
*tuffy center and overhead consoles, with CD, CB, and scanner on board. infinity speakers all around (since I have them sitting there).
*all-metal door panels with after market TJ armrests/door pulls. doors have been welded where the skins and braces always crack (by the vent windows).
*on board air AND delco alternator-welder, for trail fixes.
*hella 8" massive lights on the front bull bar, kc's as needed. tractor-type rock lights.
*gladiator grille, M-715 headlight buckets/rings, hella H4 retrofit glass & silverstar lamps, M-715 turn signal housings in the center holes.
i know it sounds like a lot, but most of this junk is already setup, just needs to be installed. I've had 5 years to collect all this crap, now i have to put it to good use! wish me luck, i'll add pics as i get things installed.
[ December 02, 2005, 12:46 PM: Message edited by: Brad W. ]
Brad W.
1979 wag "Nightmare"
**project shelved indefinetly**
m715 ex-firetruck
**project shelved**
2001 Dodge Ram 2500 "Project Juggernaut"
24v-CTD/NV-4500/quad-cab/4x4
4" straightpipe, rollin on beadlocked 37's.
12-02-2005, 08:39 AM
Good luck on that list...It looks like a lot of work. Hope you have a warm shop to work in
12-02-2005, 08:53 AM
remeber make sure LOTS of pics ,,to help inspire all the rest of us ..lol
77 Cherokee chief ,360 cid,quadra-trac,chopped /bobbed 12" , 8point cage, front exo ,d60frt 14bolt rear ,38.5x14.5x16.5 on beadlocks ,frt & RR winch,OBA ,SOA,shackle flip rear
** Island Rock Crawlers**
4WDABC Member
BCWF Member
12-02-2005, 10:42 AM
Yes, photos are a must!
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
12-04-2005, 12:28 AM
Location: close enuff to Denver, but far enuff from the people
sounds good, hopefully I will see you in a jeep and not a dodge for the first time [img]smile.gif[/img]
12-04-2005, 12:37 AM
Cowboy Up
Sounds like a plan!
Did you ever score a deal on that CO J3000 DRW flatbed?
12-05-2005, 06:46 AM
no, the people with the dually stopped answering my emails. not sure what their deal is, they seemed kinda greedy to me.
I know it's a long list, but the good thing is that most of it just has to be installed. it's not all do-or-die jusnk to get it going either. just gotta get the engine figured out and then it's no sweat after that.
Brad W.
m715 ex-firetruck
**project shelved**
12-05-2005, 11:09 PM
i've been gone and in and out sparaticly (sp?). Is there progress pics? I'm glad you're getting to the end. I'm i nthe same boat. If my back and hadn't ****ted out on me I'd probably be wheelin'. keep it up.
12-06-2005, 12:33 PM
one heck of a setup ya got man.
P.J
Stupidity rules at all times! Famous last words "Hey, watch this" Its 5:00 Somewhere. 1983 J10 In process: 360 ci install
12-06-2005, 03:34 PM
good things come to those who wait.
get some pics.
