09-11-2004, 02:43 AM
Is that muffler blowing right on the shock? I would think the heat from that would eventually fry it? It kinda looks like a ricer muffler...lol
Diff covers look great, what are they mad of? Something like 1/4in plate?
09-11-2004, 05:11 AM
Pretty snazzy in a Mad Max/WaterWorld sorta way...
What?
No digital reasout of gear oil level and viscosity vs. hours?
09-11-2004, 05:23 AM
Very nice...I picked up one for the 14 bolt rear and will later get one for the 60 front. I think you should be able to bounce off rocks with no problem.
Have you trimmed that 14 bolt any?
09-11-2004, 12:15 PM
they look like they're made of out tin!
I gather the ring on these things is like 0.5" thick, that the case?
[ September 11, 2004, 06:16 PM: Message edited by: robselina ]
Rob
09-11-2004, 04:29 PM
I see you got the ones where they didn't grind their welds smooth. I like the look of those much better. Well done welds are PRETTY!!!!
1979 waggy, one ton WT conversion going on...
1979 golden eagle buggy...living on through donations across the country
09-12-2004, 01:27 AM
They look awlsome
77 Cherokee 401/400 trans,Holley on edelbrock performer,PT 1339
d44s,detriot rear ,diff guards front and rear
Fabbed front and rear bumpers,Tire carrier
33"BFG KM2's on black spokes
Tadrack
Interior upgraded,Durango console, custom gauge panel,bucket seats
Soa,with 1" shackle up front
Hood vents
09-12-2004, 03:46 AM
What no chrome? [img]smile.gif[/img]
Nice work..yeah the welds look better.. not worth the extra money to have them smooth them.
All It Takes Is Money.
I'm the reason why you can only have Jeeps for Avatars. You're welcome.
09-12-2004, 04:13 AM
psuedo off subject question... with a 14 blt rear, how well is that driveshaft working being all angled like it is..i wanna run a ff 14, and eventually a d300 tcase, but i wanna know how well a 14 would run "temporarily with qtrac...
09-12-2004, 10:17 AM
i have a 14 bolt with q-trac and have no problems, the shaft is so long the offset isn't that bad
09-13-2004, 02:35 AM
Super Moderator Dr. Rockcrawler
The covers have a 3/8 in ring and the cover part is 1/4. I love them. I haven't shaved my diff at all with the 39.5 I have the about same clearance as before with 44 and 37 in tires. As far as the shock haven't had any problems. I just need to rejet the thing is running rich.
Paul Hartman
79 waggoneer
AMC360/TH-400/203/205
www.cbioffroadfab.com
WWW.PLANET4X4.NET
09-13-2004, 09:25 AM
Love the covers! Are there two ubolts holding the front spring on? I only see one in the pic.
09-13-2004, 10:43 AM
There is only on u-bolt the other side has two bolts that go into the housing. This is how the Dana 60 holds the springs onto the housing.
Paul Hartman
79 waggoneer
WWW.PLANET4X4.NET
09-15-2004, 01:27 AM
how much did they set ya back?
77Chero,360,t400,231/d300,d60,c14bolt 5.13's 42"PBR's
84wag,360,tf727,208 stock for now! possiblities are d300 flipped and a ford d44 hp with coils
09-15-2004, 02:32 AM
$280 shipped tp my door.
Paul Hartman
79 waggoneer
WWW.PLANET4X4.NET
09-16-2004, 06:52 PM
those are some tough diff covers.
Rick C.
www.kymc.org
shadowjeep
2003 Chevy Silverado
09-18-2004, 02:08 PM
Slightly off-topic, but... has anyone seen those D44 diff coveres made out of torched-and-drilled Ford TTB housings?
[ September 19, 2004, 09:26 PM: Message edited by: Sycho15 ]
1989 J5 "Murphy"
4.0L / AX15 / NP231 / GW D44s
3" lift / 31" MTs
09-19-2004, 05:25 AM
The Advisor
Looks awesome man. I've seen those diff covers made in person. Lots of work go into those babies.
Buggy Buildup
Originally Posted by welchct
09-19-2004, 11:36 AM
those are nice how thick are they?
82 wagoneer, soa with 38.5, will have 14 bolt with 4.88\'s. taking most of the body off and tubing. hope to get this heep in progress
09-19-2004, 12:59 PM
3/8 ring and 1/4in plate for the actual cover.
Paul Hartman
79 waggoneer
WWW.PLANET4X4.NET
