07-03-2003, 07:06 AM
Okay when i first got it the accellerator pump was sticking thus it would quite at any thing past half throttle. Well now the truck will run okay when just feathering the throttle but anything above that it just stumbless real bad and has no ooomph for lack of a better term. I can feather and get the truck up to about 70 but something is definantly wrong. As a matter f fact I went and did a little offroading and it did fair at minimal throttle but trying to go up over anything or any kinda low end horspower stuff when I give it the gas it dies. Any suggestions. Oh and I have 4:27 gears and TFI.
Jason
KingJason <a href=\"http://www.fullsizejeeps.com/jeeps/files/1963-1983-Wagoneers/Frankenstien04.jpeg\" target=\"_blank\">http://www.fullsizejeeps.com/jeeps/files/1963-1983-Wagoneers/Frankenstien04.jpeg</a><br /><br /><a href=\"http://www.fullsizejeeps.com/jeeps/files/1963-1983-Wagoneers/Frankenstien01.jpeg\" target=\"_blank\">http://www.fullsizejee
07-03-2003, 07:17 AM
same problem im having, sortof. i called holley tech and they told me to adjust the nut that operates the pump, i did that and it helped a bit. he said that if that doesnt fix the problem then get a more radical pump cam, (said its the black one) also to increase the pump nozzle size to .030. im going to try this tomorrow and see how things work out.
07-03-2003, 07:27 AM
Hmm let me know cuase its driving me up the wall. Truck cranks perfect and runs smooth but the power thing is wierd. Really irritates me that this is the best carb they offer and yoiu hve to start really tinkering with it. It should at least be close from the factory.
Jason
07-03-2003, 01:09 PM
i love holley's, they are really an owner oriented carb!!! every holley ive ever had has needed adjustment from the factory, on the 4160's i always just took of the rear metering plate and put a jettable metering plate in place and converted to dual feed. but now to the new offroad carb i am new to (well i actually havent even seen it yet) but im sure ill figgure it out. and after you get this carb right it should be the sweetest running carb you got.
my jeep has gone to that great big salvage yard in the sky
07-06-2003, 01:49 PM
Jason maybe we should hook up and scratch our heads together...oh and so I can check out that rig!!!
1994 YJ
Amc 360
TF727
Stak 3 speed
44" Pitbull Rockers on Trailworthy H1's
Rockwells
76' Wagoneer
401....new project
Tow Rig Daily Driver// 2007 6.7 CTD Dually
07-06-2003, 04:46 PM
Micheal your not trying to get spy shots are you. lol I really need to get me a web site up and going. Im putting my freshly recoverd headliner in tommorrow and my new glove box. I should be ready to put up some nice pics then. I was gonna wait till I dropped my trick little stereo in butt I thinnk its close enough.
Jason
07-07-2003, 12:07 PM
Hey now now. If I can help I will. Oh and I want to see that rig. I will not take any pictures if that makes you feel better. Maybe we can have a ....mine is taller than yours competition!!!LOL Let me know if you need anything. We all are too close not to help in person.
1994 YJ
Amc 360
TF727
Stak 3 speed
Rockwells
76' Wagoneer
401....new project
07-07-2003, 12:26 PM
Frankenstein, I have the .30 squirter in mine from the stock .28 with the Blue pumpcam on the #1 setting and it rips. I also have a new motor and all other accessories too. When I ran it with my old beat motor, I used a .3o squirte and the stock orange cam on the #2 setting(probably would have been better with the blue one I am running now). Check your float levels and make sure you know the correct way to measure ythe clearance between the accelerator pump levcer and spring, don't just start messing with the adjustment on it.
SOLD the 88GW and replaced with an Expedition. Still love JEEPS and will get another soon.
07-08-2003, 12:33 PM
So 88 gw how did it run when you first got it i mean exactly. When I first got mine it would not even open up past half way without dying, turned out the accelerater pump was not working at all. But now it just is crap at low end. Stumbles and spits but at about 45 it starts to run alright. On any incline were it needs some juice it will die. Floats are right per holley specs.
07-08-2003, 01:00 PM
Mine ran pretty good out of the box. It was a tad lean off the line, which required some feathering of the throttle until it got up off idle and to about 1500 rpms. I did not have as much trouble as you described. What is your timing at, mine at first required some timing adjustments before it ran well. Also check your vacuum advance is not advancing or is not too retarded causing it to act that way. I remember adjusting my vacuum advance with the old motor. Have you checked the specs on the accelerator pump? Is it possible that the diaphragm is toast?
The set up that works well now on my new motor is as follows: New distributor don't mess with it, set at 14 degreees, idle screws are out about 1.5 to 2 turns, the pump cam is blue set on #1 and the squirter is a .30. I also switched over to manual choke(nothing to do with how it runs though).
07-08-2003, 04:13 PM
I may have to check the Diaphram but if its that i will be very dissapointed with my new carb.
07-08-2003, 04:14 PM
Oh and ive played with the timing alot.
07-12-2003, 02:40 PM
The holley must dieeee. I tinkered all morning to no avail then me and dad swapped on my mothers Edelbrock from her street rod. Well boys it was like a whole different truck. Holley goes back to Summit tommorrow. Edelbrock AVS Offroad series coming soon.
Jason
07-15-2003, 12:42 AM
Sorry to hear that. The AVS is really no different than the standard Edlebrock except for looks and "off-road" needle and seats which do not work. Hope you don't do too much wheelin with it.
07-16-2003, 02:21 PM
MY NEW TRUCK AVENGER WORKS AWSOME SO FAR IN EVERY RESPECT EXCEPT THAT I CANT GET A VERY SMOOTH IDLE BUT THAT MAY BE FROM NOT ACTUALLY GOING ANYWHERE EXCEPT OUR SHOP.ILL HAVE TO CHECK THE PLUGS AGAIN
mark<br />76 cherokee chief<br />chevy 502 t-400 np-205<br />dana 60 front corp 14 bolt rear<br />fiberglass fenders and quarters<br />(ABOVE THE LAW)(AND UNDER CONSTRUCTION)<br /> [IMG]<br />[url=http://www.fsjworld.com/mygallery.ten?id=3481[/URL]<br />[/IMG]
07-16-2003, 05:33 PM
ok i finally got home and put that intiake i got off a fellow member and the new truck avenger, i love it!!! it rau great out of the box!! the best i've ever had a holley run out of the box. i had to do very little to it to get it going really well i still got a little electric chokeissue the i have yet to put any effort into fixing it though. i doubt i will before i leave again.
07-17-2003, 08:36 AM
I had bad trouble with 2 edelbrocks, same problems Petersen magazine had when they did the carb shootout a couple of years ago... Fooey on edelbrock...
Jeep Red Jeep Blue I got one how bout you
07-18-2003, 03:59 AM
I got one of the first Holleys so it may be some Tech issue they figured out who knows. However as far as edelbrock goes I will do some testing as soon as I get it and we shall see.
