Old 02-06-2005, 03:07 AM
rednek in a jeep rednek in a jeep is offline
ok what lenth shock do i need to get for a 85GW with SOA ????
85 GW 360 727 np229 slect trac, tt\'s fab works SOA kit, 4.56 gears, locked front and rear, 33 12.50\'s 1969 RAMBLER WAGON 232
Old 02-06-2005, 03:41 AM
robselina robselina is offline
Rancho 5012s front and rear are about right from what I recall..
Rob
Old 02-06-2005, 03:47 AM
youngjeeper's Avatar
youngjeeper youngjeeper is offline
measure after!!
i got the rancho 5012's for the choptop and they didnt have enough compression and too much droop.i returned them. take the measurement from bolt to bolt and talk to your local 4wheel shop.
88' GW Stock & Mint
77' CJ-7
http://gfsj.org/forums
Choptop/Crew Cab Build-up
http://www.ifsja.org/forums/vb/showthread.php?t=93389
Old 02-06-2005, 03:03 PM
btt
Old 02-06-2005, 03:20 PM
jode's Avatar
jode jode is offline
JB Welder
Dan's advice is the best you are going to get.
Since all SOA's are custom, and since the amount of height of the springs varies by application, spring age, vehicle weight, etc. The only surefire way is to take some measurements after you get the lift done.
Even assuming you are using stock springs, they could be saggy or you could have built up a higher area for your spring perches than someone else or something that would also affect the shock length you need. Also, are you leaving all the shock mounts stock?
IMHO, if you end up with too much droop and not enough compression, your second option would be to just fab some new shock towers to compensate for it. How hard could that be after all the fab work for the SOA?
No FSJs for the time being - "I'm working on it, I'm working on it" (think Mike Meyers' SNL skit about the gut)
Old 02-06-2005, 03:25 PM
ok ill just have to wait on the shocks then. thanks guys.
Old 02-06-2005, 11:21 PM
Super Moderator
Ph.D. in FSJ
I agree and tell everyone the same thing...
'normally' Rancho 5012's are used up ...but wait and measure.... AFTER the SOA
Todd
www.ttsfabworks.com
Old 02-10-2005, 02:57 AM
Peter Matusov Peter Matusov is offline
Rancho has an outstanding catalog of their shocks in PDF format, broken down by application or/and sizes and mounting patterns. I've used Rancho's catalog to find the right-sized shock for my intended application (Rover axle under an FSJ), found the stock application for it (in my case, it was '81-87 Blazer with OEM Quad shock front suspension, inner shock) and then went to Monroe's website to find the right part # for that stock application. Kragen just had what I needed.
Peter Matusov /68 Wag/95 Range Rovers - SWB & LWB/96 Discovery - white and green/01 XC70
AK6PM
Old 02-10-2005, 08:48 AM
ill go look there thanks
