Old 08-01-2003, 04:46 PM
KYJ10 KYJ10 is offline
I was putting it all together today, finally, and realized that enlarging the holes from my 44 bottom plate wouldnt work. It worked fine on my 14ff. So anyway, I need to come up with a plate to place oveer the top of my leafs, and send the ubolts through. Will just a thick gage, rectangled piece of plate work? Just drill out the ubolt holes and the centering pin hole. What do everyone else do? I dont want to run the ubolt downward, so must come up with something? Dennis
Starting to miss the addiction!
Old 08-01-2003, 04:47 PM
too tired to edit my mistakes!
Old 08-01-2003, 10:05 PM
scotty's Avatar
scotty scotty is offline
when my friend installed a ford d60 in his xj,he was able to reuse not only the plates,but the u bolts as well from his front 44. he hid have to do some clearancing on the driver side of the housing,tho it was minimal.
scotty
85 grand wagoneer
258/t18/d20/10 bolt/14 bolt
38" TSL SXs
chopped,bobbed and caged
Old 08-02-2003, 01:34 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
My D60 didn't come with plates. Had thick plate punched for the holes.
Old 08-02-2003, 01:58 AM
Rockwagon Rockwagon is offline
I was able to reuse my stock plates front and rear!! Infact I used the old sway bar mounts for new shock mounts..
<a href=\"http://www.muddevils4x4.com/forum/\" target=\"_blank\">http://www.muddevils4x4.com/forum/</a>
Old 08-02-2003, 02:27 AM
Will Morris Will Morris is offline
I just went to a local fab shop and had them cut some 1/2" steel plate and drill holes in my specified locations. It doesn't look that spiffy, but I imagine the spring mounts would be ripped off the frame before my plate cracks.
Will
'78 Cherokee NT in GA
'79 J10 Golden Eagle in UT
Old 08-05-2003, 11:36 AM
Wood's Wagon Wood's Wagon is offline
Who cares if the U bolt plate looks like crap. All it has to do is serve its function. I love home fabrication.
74\' J10 parts truck<br />70 wagoneer with 8 point rollcage, dauntless v-8. soon to have a 460.....
